using a cmos 4066 with basic stamp
Hey All,
I have been able to hook a 4066 control lines to a basic stamp and the
I'm able to turn on/off the 4066's I/Os.
I'm using the voltage and ground from the basic stamp.
My question is should I be using resistors or another component to
improve the reliability?
Ben
Ben
writes:
Ben
Resistors or other components where? Is the 4066 multiplexing lines
unrelated to the stamp?
If you are talking about resistors or other components on the power/ground
line of the 4066, one recomendation is a 0.1 uf capacitor from vdd to vss of
your 4066.
Hope this answers your question.
> Hey All,
the
> Thanks,
> Ben
Depending on how you are switching, switch 1 then 2 then 3 then 4
then read 1 and switch it,
read 2 and switch it.
that allows some time for the readings to settle between readings.
switch and read may not offer stabile or accurate results.
Dave
> Ben
Yes I'm controlling a remote control. Currently I have it configured so
that I'm completing the circuit with the 4066 with the controls
attached to the basic stamp. The remote is currently powered by
batteries.
> power/ground
> line of the 4066
Yes I'm using 10k ohm resistors between the basic stamp's Vdd and the
basic stamp's I/O to debounce some buttons I have wired to the basic
stamp. I wanted to know if I should be using the same type of
configuration to improve the reliability of the 4066 connections.
> your 4066.
Does this mean that I place the capacitor between both the vdd and vss
connection in other words use 2 caps per 4066?
Should the vss and vdd share a cap in between either the stamps vdd
distribution and the 4066?
Should the capacitor go between the vss distribution of the stamp and
4066?
Finally what is the function the capacitor would be performing?
Thanks so much for all the great advice that everyone on the list is so
kind to provide.
Answers 1 question and creates more [noparse]:)[/noparse]
Ben
writes:
On Tuesday, August 19, 2003, at 08:49 PM, smartdim@a... wrote:
> Ben
batteries.
> power/ground
> line of the 4066
> your 4066.
4066?
kind to provide.
Ben
See the link below for the purpose of the caps.
http://www.seattlerobotics.org/encoder/jun97/basics.html
The 0.1 uF cap goes from vdd to vss, One cap per 4066.
The 4066 is basically just a switch, so no resistors are needed from the
input or output to Vdd.
Hope this helps.
