Sending data to lcd from a bs2-question.
I have a SLI-OEM rev B serial to lcd converter board by Wirtz.
I have an 8944-OP lcd.
I have a BS2 stamp.
I have tried both 2400 baud and 9600 baud.
I put a 1.5 kOhm resistor pull up on the data line as recommended by the
SLI-OEM documentation.
The lcd receives information correctly from the RS-232 line on my
computer.
I have tried several versions of programs to make the lcd repeat out my
ser-out commands. I have also used the simple ser-out program statement
in the stamp book.
All I get is gobbledegook on the lcd. However, the gobbledegook does
change when it is receiving information.
There's got to be something simple that I am missing. Question is, what
is it???
I stand by for incoming rounds<G>.
I have a BS2 stamp.
computer.
in the stamp book.
is it???
place the code in with your question next time.
Also, have you verified that the Serial (SLI-OEM) "backpack" is correctly
receiving serial by sending directly to it with Hyperterm or some other
known-good serial source? This would allow you to determine if this a
stamp coding/interfacing problem or a backpack/lcd problem...
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
vern@t... www.txis.com | is up, then we obviously don't need
Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
> I have a BS2 stamp.
> computer.
> in the stamp book.
> is it???
> Body of the message will be ignored.
same hell.
I finally got mine to work at 1200 or 2400 -- nothing higher. Part of
the problem is holding the data line in a constant state when the module
is powered up -- provided you can switch the power on cleanly. You also
have to delay any commands going to the module until its powered up.
I don't have the modules here to look at, but I believe I used a pull-up
or pull-down resistor and told the Stamp to wait 3-4 seconds before
sending a command. At any rate, its vaguely documented in the
instruction sheet.
> I have a BS2 stamp.
> computer.
> in the stamp book.
> is it???
From: Grover Richardson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PgpZliTtjaIbolQTa-2w4a0UgT_tLueYu8KmOjNL7bpoVWois_vUMSOHOyNQQjAs_PfnxodHBsy-_gMXZGOvPXMM10-BD0Yi0W3iFQ]grover.richardson@g...[/url
computer.
The computer serial port uses +12v and -12v for 1 and 0. The stamp uses +5v
and 0v. The stamp's special serial pin does a bit of trickery to get
computers to talk to it sensibly but serin/out on any other pin isn't going
to work directly with an RS-232 device.
Don't forget that serial and RS-232 is like a rectangle and a square. While
a square is always a rectangle, a rectangle is not always a square. Serial
just means one bit at a time. RS-232 means one bit at a time AT +12/-12.
If your LCD works directly off a PC serial port without frying then its
RS-232, not "just" serial. Use the Stamp's special serial pin or go through
a level converter chip like the Max232 or similar.
with no modifications.
> computer.
'{$STAMP BS2}
'set i/o pin directions
OUTPUT 6 'SERIAL TO LCD from P6 pin
'***** PROGRAM BELOW
' 2400 baud inverted and normal are 16780 396
SEROUT 6, 16780, [noparse][[/noparse]"HELLO XXX WORLD!"]
END
Yes. I wrote a basic program to send data to it, and it works. Though
I did note that when the input pin of the SLI unit was open (not
connected to anything), it received nonsense. I suspect that it's a
very high impedance and picking up room noise.
From: Vernon Graner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=a1n1UEz-1Jng3mOgXPCpvaNW0Wd0Y6FWTVygWCzD6XYOq7LSyAr31ETrJwPhWghevfcyHKALew]vern@t...[/url
Sent: Tuesday, August 19, 2003 4:05 PM
Subject: Re: [noparse][[/noparse]basicstamps] Sending data to lcd from a bs2-question.
If you supply your BS2 test code it will help with diagnosis. [noparse]:)[/noparse] Just
correctly receiving serial by sending directly to it with Hyperterm or
some other known-good serial source? This would allow you to determine
if this a stamp coding/interfacing problem or a backpack/lcd problem...
Vern
vern@t... www.txis.com | is up, then we obviously don't need Cell
> I have a SLI-OEM rev B serial to lcd converter board by Wirtz. I have
> an 8944-OP lcd. I have a BS2 stamp.
the
> computer.
> my ser-out commands. I have also used the simple ser-out program
> statement in the stamp book.
> what is it???
remembered a similar sounding problem I had a while back. I was trying to
power the LCD from an MCU pin (only uses 1.2mA total) and I kept getting
giberish on screen. In the end it turned out that I was sending text before
sending a cursor position (Home command). Try sending a CLS and Home to
initialize the display before sending it text to display. Shot in the dark
but hey, sometimes its the really simple stuff that kills us [noparse]:D[/noparse]
From: Bill Boyer [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BP15P6_tzCjAl5P5L_yfed_IUYMdCTrILo_BlBYGKTI-w0QuUSu-p6ikg5owa6FTzRsrSF_Ht3HqS9s]daweasel@s...[/url
Sent: August 19, 2003 7:59 PM
To: Basic Stamp List
Subject: RE: [noparse][[/noparse]basicstamps] Sending data to lcd from a bs2-question.
The SLI-OEM module is supposed to work with both TTL and PC level RS232
Arg!! I know that, but forgot. Program below:
'{$STAMP BS2}
END
