Linux utilities and the stamp --- help!
I downloaded the sourcecode for the linux stamp utils. I ran make
and make install. It compiled fine.
Tokenizing works
but when i run the program i get the following:
[noparse][[/noparse]root@l... bstamp]# ./bstamp_run stepper.tok
Error: Could not open /dev/bstamp for reading/writing!
Any ideas how to open the /dev/bstamp device?
Tokenizing works
> Tokenizing works
--- In basicstamps@yahoogroups.com, Bill Boyer <daweasel@s...> wrote:
> Do you have permission to write to the device?
make
> > Tokenizing works
change the permissions on the serial port.
> I did this as root. So I should have the rights.
> make
> > > Tokenizing works
utility. I never tried to get the one you are using to work. I had
good luck with the other one off the parallax site.
Regarding the program you are using, it sounds to me like /dev/bstamp
never got created on your machine. Check to see if it is there. If
not, look at the documation for your program about how to create it. If
the documentation doesn't help you, I would then try making a symbolic
link to your serial port device.
> make
>>>Tokenizing works
--- In basicstamps@yahoogroups.com, Bob Reite <bobr@t...> wrote:
> Look through some of my early posts about running a different Linux
had
like /dev/bstamp
If
it. If
symbolic
> > make
> >>>Tokenizing works
Subject and Body of the message will be ignored.
