BS1 Hardware Not Found Error
Archiver
This is my first try at using the BS1 stamp. I have tried this with
three different stamps and two computers. Both of the computers are
running Windows XP. I used the Stamp1_dos_editor to create the
following simple program:
'{$STAMP BS1}
DEBUG "HELLO WORLD"
As soon as I do a Alt R I get the "Error Hardware Not Found" message.
I have checked the continuity of the conections on my cable and they
match the documentation.
I am using the Basic Stamp 1 Carrier Board powered by a battery and
only the three pin connection to my parallel port concted to the
board.
I would appriciate any ideas on what may be causing my problems.
Jim
'{$STAMP BS1}
DEBUG "HELLO WORLD"
board.
Jim
> '{$STAMP BS1}
> DEBUG "HELLO WORLD"
>board.
>Jim
Jim -
Make sure your printer port is set for bi-directional data. EPP is fine,
if that's available, otherwise any other bi-directional setting should be okay.
Bruce Bates
thing to do is format a Win98 boot floppy, copy the BS1 software to it
and boot from the floppy. If you use NTFS you won't be able to see your
disk drives, so be sure to copy your programs on the floppy too!
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=0vH_sV4olG41uywfhludgfb6LKDndNUZYt8xcZWu_8JqrxRyfaX70e9MRhdYFvCC84WyxNAD1ePKbmzwzw]bvbates@u...[/url
> Sent: Tuesday, August 19, 2003 10:55 AM
> Subject: Re: [noparse][[/noparse]basicstamps] BS1 Hardware Not Found Error
> > '{$STAMP BS1}
> > DEBUG "HELLO WORLD"
> the board.
> >Jim
> Jim -
> EPP is fine, if that's available, otherwise any other
> Bruce Bates
> from the same email address that you subscribed. Text in the
That's correct - the BS1 may only be programmed in DOS at this time.
For the details, check out page 33 of the BASIC Stamp Manual.
If you need further support, feel free to call or email Parallax
technical support. (support@p...)
There will be support for programming the BS1 in Windows before the end
of this year.
We'll make an announcement when it's ready for you.
Erik Wood
ewood@p...
599 Menlo Dr., Suite #100
Rocklin, CA 95765
(916) 624-8003 Fax
(888) 512-1024 Sales
www.parallax.com
Sent: Tuesday, August 19, 2003 9:04 AM
Subject: RE: [noparse][[/noparse]basicstamps] BS1 Hardware Not Found Error
As far as I know, the BS1 software will not run at all under XP. One
Al Williams
AWC
* Easy RS-232 Prototyping http://www.al-williams.com/awce/rs1.htm
> From: Bruce Bates [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KLl97WJGCLvRWIBqVH5DuCIfWSYuZoug6OcXV-MWJcwLAMQ3QLw6pFUpPtIrROKbVPHx83NYqd93qYr5vi_l6w]bvbates@u...[/url
> > '{$STAMP BS1}
> > DEBUG "HELLO WORLD"
> the board.
> >Jim
> Jim -
> fine, if that's available, otherwise any other bi-directional setting
> should be okay.
> Bruce Bates
> from the same email address that you subscribed. Text in the Subject
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Thanks for the advice. I knew I saved those old Windows 98 emergency
disks for something. I set the printer port to EPP and put the
editor on my WIndows 98 Floppy. I guess I have partial success as I
have moved to a new error. I am now getting a "EEPROM Verify Failed"
error when I hit Alt R.
I have been using the BS2 stamp and was surprised at how easy it was
to get started. I guess the BS2 is what we would call new and
improved. I am working on a very simple problem that's even using
the BS1 is overkill for so I would like to get it working.
Jim
it
your
> Al Williams
> AWC
> > From: Bruce Bates [noparse][[/noparse]mailto:bvbates@u...]
with
are
> > > '{$STAMP BS1}
> > > DEBUG "HELLO WORLD"
message.
they
and
> > the board.
> > >Jim
> > Jim -
> > Bruce Bates
Hardware Not Found" message when I hit Alt R in the BS! DOS editor.
Here is the simple program I am using to test.
'{$STAMP BS1}
DEBUG "Hello World"
I have tried this with three different Stamps and both an HP Notebook
and a desktop computer. I am using a Parallax cable and have checked
the continuity on the three pins.
I would appreciate any suggestions of what to try next.
Jim
1) Is your BS1 powered up?
2) Is the programming connection on the BS1 end connected properly?
-- look for the >> key marking on connector and pcb
3) Are you running in a DOS box under Windows? This does not always
work.
-- If yes to above, consider switching to our latest Windows
editor an serial interface for the BS1
http://www.parallax.com/html_pages/downloads/software/software_Stamp1_Wi
ndows.asp
-- http://www.parallax.com/detail.asp?product_id=27111
-- Jon Williams
-- Dallas Office
From: Jim Richardson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UKCV41eXwLetTG-h30Gs-gwEJc3o7WcGtgvOyMjBo2C85G7JU7-OifB1AeAgHOZxOMVdY9tEZnUQ]n5mu@c...[/url
Sent: Wednesday, January 28, 2004 7:53 PM
Subject: [noparse][[/noparse]basicstamps] BS1 Hardware Not Found Error
This is my first time using a BS1 Stamp. I am getting the "ERROR
Hardware Not Found" message when I hit Alt R in the BS! DOS editor. Here
'{$STAMP BS1}
DEBUG "Hello World"
Jim
