visual basic.net comm control
Here is what I have found in VB.net:
Platform SDK: TAPI
comm
The comm device class consists of communications ports. You access these
devices by using the Win32 file and communications functions.
The lineGetID function fills a VARSTRING structure, setting the
dwStringFormat member to the STRINGFORMAT_ASCII value and appending a
null-terminated string that specifies the name of the communication device
(such as the modem name).
From: basicstamps@yahoogroups.com [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TqpJaA_F9KNJs-mWdHRcunS04nOaewyNz_HfL0i4768Cihk6aW9X7yEpOrIsBzUIwpO4ZWwPDx7lpi8jGSUHsCMbVG8]basicstamps@yahoogroups.com[/url
Sent: Monday, August 18, 2003 5:38 AM
Subject: [noparse][[/noparse]basicstamps] Digest Number 1963
There are 4 messages in this issue.
Topics in this digest:
1. RE: sorry this is off topic but...
2. Re: fuses & stamp protection
3. Re: fuses & stamp protection
4. Anyone have code to directly read a pckeyboard into a stamp? TIA
________________________________________________________________________
Message: 1
Date: Sun, 17 Aug 2003 07:50:49 -0400
Subject: RE: sorry this is off topic but...
Thanks for responding, however I know where it would be and its not
there. There is one component called COM Classes, I'm going to find out
about that
Today. Thanks again.
-Mike
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ox5qu7Xj-ajisdtLEbl5IaaQLTESqw-BGJEcgWKxe1opi6dcS14xQ5Mb7mU9PUUdrThB-XKSfRY]smartdim@a...[/url
Sent: Saturday, August 16, 2003 10:05 PM
Subject: Re: [noparse][[/noparse]basicstamps] sorry this is off topic but...
In a message dated 8/16/2003 6:14:06 PM Pacific Daylight Time,
laxboy687@e... writes:
> Hi all,
> I know this is off topic but I asked this question to the vbbeginners
> list and so far no one has answered
> Does visual basic.net have the mscomm component built in, and if not
can
> I download it somewhere? I
> have the msdn library and installed it all, but I can't find the
> component. Thanks for your time, especially
> since this is so off topic.
Not sure, but to find out, do the following:
1) Right click in the tools area
2) click components
3) Under the controls tab, check Microsoft Comm Control 6.0
Your use of Yahoo! Groups is subject to
Message: 2
Date: Sun, 17 Aug 2003 11:26:18 EDT
Subject: Re: fuses & stamp protection
In a message dated 8/17/2003 12:24:15 AM Pacific Daylight Time,
manwithapipe@y... writes:
> I am curious how you more experienced stampers out there protect your
> stamp from accidentally kicking out too much current? I realize that
> ideally the program should prevent this from happening, but during
> debugging occasionally I run into the "Oh sh@#" situation when a Dirs
> command or some piece of logic ends up sourcing all 16 pins at once.
> I'm considering a fuse on the power supply prior to reaching the
> stamp. Is there a better way?
I have often read in this forrm users connect a 220 ohm resistor in series
with every pin. In many applications, this will not affect the input or
output.
Message: 3
Date: Sun, 17 Aug 2003 10:28:17 -0500
A fuse may not react quick enough. By the time the fuse blows, the out pin
may
be destroyed. A resistor in line with the output to limit current to a safe
value, might be a better choice.
Leroy
From: "[noparse][[/noparse].........................................]" <manwithapipe@y...>
Sent: Sunday, August 17, 2003 2:22 AM
Subject: [noparse][[/noparse]basicstamps] fuses & stamp protection
: I am curious how you more experienced stampers out there protect your
: stamp from accidentally kicking out too much current? I realize that
: ideally the program should prevent this from happening, but during
: debugging occasionally I run into the "Oh sh@#" situation when a Dirs
: command or some piece of logic ends up sourcing all 16 pins at once.
: I'm considering a fuse on the power supply prior to reaching the
: stamp. Is there a better way?
: To UNSUBSCRIBE, just send mail to:
: basicstamps-unsubscribe@yahoogroups.com
: from the same email address that you subscribed. Text in the Subject and
Body
: Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Message: 4
Date: Mon, 18 Aug 2003 04:00:31 -0000
Subject: Anyone have code to directly read a pckeyboard into a stamp? TIA
I mis-posted earlier. Sorry. But thank you to all who replied.
I am looking for the opposite. I need to read a PS/2 keyboard
directly into a stamp..
Thanks Tom...
Platform SDK: TAPI
comm
Message: 1
about that
-Mike
> Hi all,
can
2) click components
Message: 2
output.
Message: 3
may
Leroy
Body
Message: 4
Thanks Tom...
