fuses & stamp protection — Parallax Forums
edited 2003-08-18 20:20 in General Discussion
What do you mean kicking out? The current that will be given by your
BAsic Stamp will depend on the value of load. Remeber the basic
I=V/R, Ohm's Law. To avoid giving out too much cuurnt try to use
isolators or high side drivers in driving low resistance loads.
Example in your relays, you use transistors. Read the datasheet of
the Stamp if how much current (MAXIMUM) it can drive a load. If your
computation gives an output of more than the maximum, you will surely
get a burned I/O port pin or the worst burned BS2 IC.
Btw, the Voltage peak I think of the BS2 is 5V, so I=5V/R, R is your
load resistance.
Glenjoy [noparse]:)[/noparse]
--- In
basicstamps@yahoogroups.com, "[noparse][[/noparse].......................................
..]" <manwithapipe@y...> wrote:
> I am curious how you more experienced stampers out there protect
your
> stamp from accidentally kicking out too much current? I realize
that
> ideally the program should prevent this from happening, but during
> debugging occasionally I run into the "Oh sh@#" situation when a
Dirs
> command or some piece of logic ends up sourcing all 16 pins at
once.
> I'm considering a fuse on the power supply prior to reaching the
> stamp. Is there a better way?
    edited 2003-08-17 16:26
    In a message dated 8/17/2003 12:24:15 AM Pacific Daylight Time,
    manwithapipe@y... writes:
    > I am curious how you more experienced stampers out there protect your
    > stamp from accidentally kicking out too much current? I realize that
    > debugging occasionally I run into the "Oh sh@#" situation when a Dirs
    > command or some piece of logic ends up sourcing all 16 pins at once.
    I have often read in this forrm users connect a 220 ohm resistor in series
    with every pin. In many applications, this will not affect the input or output.
    edited 2003-08-17 16:28
    A fuse may not react quick enough. By the time the fuse blows, the out pin may
    be destroyed. A resistor in line with the output to limit current to a safe
    value, might be a better choice.
    Leroy
    From: "[noparse][[/noparse].........................................]" <manwithapipe@y...>
    Sent: Sunday, August 17, 2003 2:22 AM
    Subject: [noparse][[/noparse]basicstamps] fuses & stamp protection
    : I am curious how you more experienced stampers out there protect your
    : stamp from accidentally kicking out too much current? I realize that
    : ideally the program should prevent this from happening, but during
    : debugging occasionally I run into the "Oh sh@#" situation when a Dirs
    : command or some piece of logic ends up sourcing all 16 pins at once.
    : I'm considering a fuse on the power supply prior to reaching the
    : stamp. Is there a better way?
    : To UNSUBSCRIBE, just send mail to:
    : basicstamps-unsubscribe@yahoogroups.com
    : from the same email address that you subscribed. Text in the Subject and Body
    : Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    The 220 ohm SERIES resistor (in-line with
    the BS2 pin) is needed to limit current
    source/sink should the pin be connected
    directly to ground or +5, and then the
    pin configured as an output.
    If the pin is outputting +5 volts, and is
    then connected to a ground, the 220 resistor
    limits the resulting current to 22.7 mA,
    which won't damage the pin's driver.
    Pull-ups or pull-downs provide a 'default'
    voltage on the pin -- this should be
    'outside' the 220 ohm protection resistor.
    Note if you configure a pin as an INPUT,
    then the pin goes to a 'high-impedance'
    state (10 Meg Ohms?), where it should only
    sink micro-amps, if any current at all.
    A pin set to an OUTPUT state, then set to
    0, will sink current to try to 'pull' the
    voltage on its pin to 0. If you attach it
    to a non-zero (or non-matching) voltage
    source, some current will definitely flow.
    --- In
    > I've done a little more investigating and it seems I may have other
    > semi-related questions. (btw thanks to the answers so far).
    > Part of my earlier issues (not voltage-re;ated) stem from the fact
    > that the Opto22 relay boards are logically inverted. Does anyone
    have
    > a good reason why this is?
    > Also, if I am toggling one pin at a time, and have all my output
    pins
    > set, all pins that are not HIGH seem so soak up a little tiny itsy
    > bitsy bit of current. I've checked for shorts and the circuit is
    > sound. THey're just not completely off; I can see a little glow in
    > their LEDs. The thing is, with a 32 channel I/O board and only
    using
    > one pin at a time, a little bit spread over 32 is hardly detectable
    > but a great drain on the stamp. Am I in need of pullups?
    > In regards to my earlier post, I'm now using a 7805 to regulate V
    and
    > now working on the other end to make my current load safe. Are
    > pullups not needed if I simply put a 220-Ohm on each pin?
    > (confused semi-noob)
