slots......was
I agree with Jon, you can use scratchpad ram to pass data between
slots with the Put and Get commands. I have found however that the
constants and varibles don't necessarily be "exactly" the same
variable. If you have a 'x var BYTE' in slot0 its not the same
variable as the 'x var BYTE' in any other slot. What I have found is
you need to assign the same TYPE of varible in each slot. This means
that if you have 3 words, 5 bytes, 7 bit assigned in slot0 then you
MUST assign 3 words, 5 bytes and 7 bits in each slot. (even if you
don't use them all) The 'view memory map' should look the same for
each slot. I've done this with a couple programs now and haven't had
any 'alaising' problems. Did I just get lucky?
Paul
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> You don't have to do this unless you're trying to mimic one
contiguous
> space. That said, you can't GOSUB into another program slot. What
I do
> is use extra slots for support routines (displays, etc.) and pass
data
> to them via the ScratchPad RAM. I also store a task pointer for my
main
> slot so that when I return from a support slot, I can pick up where
I
> left off.
> This technique is detailed in my N&V article.
> -- Jon Williams
> -- Applications Engineer, Parallax
> -- Dallas Office
> From: Newzed@a... [noparse][[/noparse]mailto:Newzed@a...]
> Sent: Friday, August 15, 2003 10:09 AM
> Subject: Re: [noparse][[/noparse]basicstamps] Re: Full BS2, change to BS2e?
> [noparse][[/noparse]SNIP]
> Tip: ALL of the constants and variables must appear in both files
and
> EXACTLY in the same order. This holds true for any banks you might
add.
Paul
contiguous
I do
data
main
I
> left off.
> -- Jon Williams
> -- Dallas Office
and
add.
size. If you do this in slot 0:
jon VAR Byte
paul VAR Byte
jon = 41
paul = 25
then this in slot 1
paul VAR Byte
jon VAR Byte
DEBUG DEC ?jon, DEC ?paul
...you'll end up with the values reversed because the first byte of RAM
will be called "jon" in Slot 0 and it will be called "paul" in Slot 1.
What I think Sid (and Paul) are suggesting is that you copy and paste
your declarations from Slot 0 into your other program slots if you want
to maintain those variables when you jump from one place to another.
Keep in mind that RUN will start the target slot from the top; this is
why I pass a task pointer variable via the ScratchPad and use BRANCH to
start the new slot where I want.
-- Jon Williams
-- Dallas Office
From: Paul [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PSBZzbKZD3Enx0itJ1thDd6K8-mKEnZ_r1prLP9sBQfZ5v6FLvG05CKX5ALMtcYy6_X0BTE]prcoy@y...[/url
Sent: Friday, August 15, 2003 12:35 PM
Subject: [noparse][[/noparse]basicstamps] slots......was"Re: Full BS2, change to BS2e?"
Paul
contiguous
I do
data
main
I
> left off.
> -- Jon Williams
> -- Dallas Office
and
add.
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
prcoy@y... writes:
I respectfully disagree. I have a 5-slot program running my model train, and
x var byte is the same variable in all slots. If is assign a vlue of "24" to
x in slot 0, and then jump to slot 3, x still equals 24. Or did I read your
comment wrong?
Sid
jwilliams@p... writes:
An alternative to the scratch pad - suppose you have sensor detector in slot
4. When it trips, yiu want it to stop Train2, but Train2 is halfway down in
slot 1.
So at the end of the sensor detector you write:
x = 243
run 1
At the very beginning of slot 1 you write:
if x = 243 then Train2
Actually a bit simpler than PUT and GET - besides I think there are only 32
bytes in the Scratchpad - doesn't take long to use that up.
Sid
same for all slots. I frequently write "accessory" programs that live
in a slot by themselves and aren't related to a specific program.
Correction: The Stamp has 32 bytes of RAM (26 for user variables). The
BS2e/BS2sx has 64 bytes of ScratchPad RAM, the BS2p/BS2pe has 128 bytes
of ScratchPad.
-- Jon Williams
-- Dallas Office
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z6boz8d2efvTVeMYKbmP0zWW1gyhjO_FF1EHcl22tq57o1ecrucd2_V8DDexDKaiCNchtEPO]Newzed@a...[/url
Sent: Friday, August 15, 2003 1:32 PM
Subject: Re: [noparse][[/noparse]basicstamps] slots......was"Re: Full BS2, change to BS2e?"
In a message dated 8/15/2003 1:50:08 PM Eastern Standard Time,
> to start the new slot where I want.
slot
down in
slot 1.
x = 243
run 1
32
Sid
abuse@p....
> Yes, that technique works great when your variable definitions are the
Never thought of that. What a great way to use otherwise wasted space !!.
Sid
