RESET pin on Basic Stamp - leave it open or connect to+5V
If I don't plan to use the reset button, is it better to leave it
unconnected or connect to +5V in the basic stamp?
Mohammed
Mohammed
to externally reset the Stamp, you may do so by momentarily taking this
pin low. You can do this with a N.O. switch to ground, or in special
cases you might use some kind of external watchdog circuit.
-- Jon Williams
-- Dallas Office
From: mohammedrasiq [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1n0a7TPERoc7DwlkBGYmpmm9tMyANPNaQl-hOh4yJRaTxyq8iYDWk0BC8V2wOdtmVAFVjyAKVbzd6MfrY1jVTv6R]mohammedrasiq@y...[/url
Sent: Friday, August 15, 2003 11:31 AM
Subject: [noparse][[/noparse]basicstamps] RESET pin on Basic Stamp - leave it open or
connect to+5V
Mohammed
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
mohammedrasiq@y... writes:
> Thanks
> Mohammed
As the reset pin is an input, it is never a good idea to leave open. Tie
reset to +5v via 10K ohms
there is no need to connec to anything; it is safe to leave alone.
-- Jon Williams
-- Dallas Office
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4qV9dNBWeuq_DgbDx6fU8ucLviadnaSvJIHjeS2F2sFEAmODomcQ6pLxXmzgCSEtCnyhTJMz3Hmx8do]smartdim@a...[/url
Sent: Friday, August 15, 2003 2:12 PM
Subject: Re: [noparse][[/noparse]basicstamps] RESET pin on Basic Stamp - leave it open or
connect to+5V
In a message dated 8/15/2003 9:31:55 AM Pacific Daylight Time,
> Thanks
> Mohammed
abuse@p....
jwilliams@p... writes:
> As discussed earilier, that pin is pulled-up onboard the BS2 module, so
> -- Jon Williams
> -- Dallas Office
And if you build your stamp from a discrete component kit, it is advisable to
use a pull up (or pull down) resistor on any unused input.
Ken
> Thanks
> Mohammed
Are you building a stamp on your own circuit board from discrete components?
If the answer is yes, it is advisable to use a pull up resistor.
say, it is alright to leave the RESET pin open, right?
> > Thanks
> > Mohammed
components?
reset, then you simply pull that pin down for a moment and release it.
-- Jon Williams
-- Dallas Office
From: mohammedrasiq [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xF1u1A1o78FNUe1t2CxEbAIczvrmIiPnl1VgDh9lGEk3vgOi3ul5n6nAQBbiOZLKJcpZS8zSXU7_jaWLR5ci4Q]mohammedrasiq@y...[/url
Sent: Monday, August 18, 2003 12:58 PM
Subject: [noparse][[/noparse]basicstamps] Re: RESET pin on Basic Stamp - leave it open or
connect to+5V
Thanks. I am using the BS2p24 module into a PCB. In this case, you
> > Thanks
> > Mohammed
components?
abuse@p....
