Full BS2, change to BS2e? — Parallax Forums
edited 2003-08-15 21:29 in General Discussion
I have a BS2 in which the programming EEPROM is basically full (it
has about 10 locations left according to the Memory Map). I am
using Pbasic 2.5, and the programmer is Windows 2.0 Beta 2.1. The
program had the correct directives on the first line. I purchased a
BS2e, since it has a larger program space. I changed the program
directives to indicate the BS2e. However, the memory map still
shows the same amount of memory remaining.
Am I missing something? The BS2e should have 3 times the
programming space of the BS2, yet the Memory Map shows different.
Any help would be appreciated.
Tracy
    edited 2003-08-15 15:13
    In a message dated 8/15/2003 9:56:19 AM Eastern Standard Time,
    Tracy.Hooker@p... writes:
    Your are looking at the memory map of Bank 0. The BS2E has 8 memory banks,
    each with a capacity of 2KB. Move part of your program into Bank 1 and you
    will see the difference>
    Sid Weaver
    W4EKQ
    Port Richey, FL
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-08-15 15:29
    OK, but do you mean that I should use the 'program slots' which are
    alluded to in the Pbasic manual, pg. 38 where they talk about
    multiple files?
    TIA
    Tracy
    memory banks,
    1 and you
    > Sid Weaver
    > W4EKQ
    > Port Richey, FL
    > Sid Weaver
    > W4EKQ
    > Port Richey, FL
    edited 2003-08-15 16:09
    In a message dated 8/15/2003 10:30:55 AM Eastern Standard Time,
    > multiple files?
    Absolutely. Create a file, i.e., compone.bse. Put something in the file
    then tokenize it.
    Go back to your original file, and in the directive line, write:
    '{Stamp BS2E, compone.bse}
    Save and exit the Editor, then reopen your original file. You will now see
    two tabs at the top, one for Bank 0 and one for Bank 1.
    Tip: ALL of the constants and variables must appear in both files and
    EXACTLY in the same order. This holds true for any banks you might add.
    To go to "compone", type "run 1". To go back to your orginal program, type
    "run 0".
    Sid
    edited 2003-08-15 16:10
    Section 3 of the manual discusses loading multiple slots with the same
    project. The RUN command will give you details on launching another
    program slot. PUT can be used to move data to the ScratchPad RAM and
    GET to retrieve it -- that way you can pass data between program slots.
    I wrote an article for Nuts & Volts on multi-bank programming, #87. You
    can download the PDF from this link:
    http://www.parallax.com/dl/docs/cols/nv/vol3/col/NV87-Multi_Bank_Program
    ming.pdf
    -- Jon Williams
    -- Dallas Office
    From: lcradio2002 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=U2vpYh1uqm015J0hOTu9ULUz--0cLDLRiyuFl1avT34nGYDec-1qM9yXEaQkpMjY0YxMJTAXXpU9YcdPhs0wsAI]Tracy.Hooker@p...[/url
    Sent: Friday, August 15, 2003 9:30 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Full BS2, change to BS2e?
    multiple files?
    TIA
    Tracy
    memory banks,
    1 and you
    > Sid Weaver
    > W4EKQ
    > Port Richey, FL
    > Sid Weaver
    > W4EKQ
    > Port Richey, FL
    Your use of Yahoo! Groups is subject to
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-08-15 16:15
    You don't have to do this unless you're trying to mimic one contiguous
    space. That said, you can't GOSUB into another program slot. What I do
    is use extra slots for support routines (displays, etc.) and pass data
    to them via the ScratchPad RAM. I also store a task pointer for my main
    slot so that when I return from a support slot, I can pick up where I
    left off.
    This technique is detailed in my N&V article.
    -- Jon Williams
    -- Dallas Office
    From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Al0y_zsFvYQsZZeY6pCknZ8ZPmoFUE3qG4sj-wirPEv0wxSF1KAFmYWeBsPTJ8qB02V9ANyY2w]Newzed@a...[/url
    Sent: Friday, August 15, 2003 10:09 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: Full BS2, change to BS2e?
    [noparse][[/noparse]SNIP]
    edited 2003-08-15 19:37
    This is just an additional comment on the issue of migration up from
    the BS2. If you plan to do much in the way of multibank programming,
    I would highly recommend springing the extra dough for a BS2p or
    BS2pe.
    The STORE command, available only on the 'p and 'pe, is invaluable
    for cross bank programming. I can't emphasize that enough! It
    allows a program running in one bank to read and write to the eeprom
    in another bank. Just think about it. A table of phone numbers. A
    lookup table for altitude conversions. A data logger. Prompts or
    text for a display. Motion map for a 'bot. Operating parameters or
    schedule for a machine. etc. etc. A programming running in one bank
    can read and change all that in another bank, which is very
    convoluted to do with the earlier stamps.
    Again, spring for the 'p or 'pe!
    -- Tracy
    >left off.
    >-- Jon Williams
    >-- Dallas Office
    >From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HnDPtAjRZSHHdo6NDHkfqWQ9wDy0fvjHlsZIsAltaCXkEuXOQvZF5IMP7hmptJHRu2qLyzRA8w]Newzed@a...[/url
    >Subject and Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
    I absolutely agree with Tracy. I am in the middle of building a GPS
    datalogger for my car to track the route of my vacation drive next week
    (Dallas to Columbus). The BS2p helps me in several areas:
    1. Speed -- 3x BS2 speed
    2. SPSTR function of SERIN so I can capture GPS string for parsing after
    3. STORE will let me run from slot 0, using slots 1 - 7 for trip data
    (would have more with pe)
    For those of you that happen to follow my Nuts & Volts column this
    project will appear in November or December.
    Every one of the items that Tracy discusses below have been incorporated
    into one or more of my projects. Yes, I know I work for Parallax so
    this seems self-serving, but the BS2p really is a great choice for many
    applications. One only has to see the cool things Tracy has built with
    it to bear that out.
    -- Jon Williams
    -- Dallas Office
    From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9aty7OI3P8D3igbktGat1r-Hg1K5UBfIbvf46h8oolGZLKoB-CNxFOf6UDxUI9_-gd_Z9g7TSmCq538]tracy@e...[/url
    Sent: Friday, August 15, 2003 1:38 PM
    Subject: RE: [noparse][[/noparse]basicstamps] Re: Full BS2, change to BS2e?
    BS2pe.
    -- Tracy
    >do is use extra slots for support routines (displays, etc.) and pass
    >data to them via the ScratchPad RAM. I also store a task pointer for
    >my main slot so that when I return from a support slot, I can pick up
    >where I left off.
    >-- Jon Williams
    >-- Dallas Office
    >From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tSnMMPYOoJv29SL2yDxZ6Ks6ugkCqvCMtNXEuZ85_Q8srsVRVE7IGnVv8lBdERpsqxsA8-0azw]Newzed@a...[/url
    >add.
    abuse@p....
