multiple stepper motors — Parallax Forums
edited 2003-08-16 02:00 in General Discussion
I want to control three stepper motors initially, (leading to
twelve!). Which is the best way to go?
Can I cascade multiple shift registers
Should I use stepper driver chips - but then I'll still run out of
i/o lines?
How about running stepper driver chips from shift registers?
There will be times when all the motors will need to work
simultaneously, so I'm a little concerned about programming.
Can anyone suggest any examples? Either of circuits or programming.
(Preferably both! Don't want much....)
I've managed to get the first motor running okay, so I'm okay on
driving it, but the rest is a little scary.
Power isn't an issue.
If this is picked up by Dave Mucha? Is there any printed information
where I can read up on some of the stuff you've been posting to the
group. It's fascinating, but a little over my head at the moment.
Many thanks.
Howard
    edited 2003-08-15 04:30
    --- I'm after two steppers. Tell me how you got the fisrt one going.
    Which stamp?, stepper driver chips?
    David
    > i/o lines?
    > Many thanks.
    > Howard
    edited 2003-08-15 08:17
    --- In basicstamps@yahoogroups.com, "howgreen2003" <greenhf@l...>
    > i/o lines?
    information
    > Many thanks.
    > Howard
    Hi Howard,
    first question is how much power do you plan to use ? It is always
    an issue. Each motor may be less than 1 amp, but 12 ? sounds like a
    nice project !
    considder that the Stamp is the controller and you need a stepper
    driver. this can be as simple as a 74hc194 and transistors for the
    power. That would let you select the voltage for motor for each
    motor. great if you have mixed voltage motors.
    second that would need one pulse output for each motor to make steps
    and one direction pin for each motor. unless you use a serial output
    to another chip, or some other way to expand the outputs, the 2 pins
    per motor is needed. (not much help there)
    If you want more power, the need to work in a chopper driver will
    allow you to get a LOT more power out of each motor instead of
    running motors at nameplate voltage.
    the difference is that a full power ON to a coil can only be
    nameplate amps and volts. a chopper monitors the line and chops the
    power to deliver the proper watts to the motor. higer voltage
    delivers higher performance.
    Allegro has bi-polar stepper driver chips, A3977 35 volts, 2.5 amps
    will make your 1.5 volt, 2 amp motor zing ! (still need one step and
    one direction pin)
    The logic to fire the coils on a stepper is to fire each coil
    seperatly. if you connect a set of 4 darlington outputs to the
    Stamp, you use 4 pins and control direction by software. high amp,
    single channel darlingtons like the TIP120 are more common for motors.
    regardless how you do it, considder using a seperate power supply,
    the motors switching all that power will be noisy!
    The one thing I would recomend is to forget unipolar wiring, the
    current resistor will chew up a lot of power when you are using that
    many motors. if you are not worried about power, maybe heat will get
    your attention. do a calc on watts.
    And, if you are not trying to get high speeds from the motors, series
    wire the coils. (isolate the center tap) that requires one half the
    current to get the same power at lower speeds.
    As far as multiple units running at the same time, that reduces
    outputs only if they always run at the same speed and same direction.
    a little lint in the axel and what once ran straght and true does a
    lot of left turns.
    Dave
    edited 2003-08-15 15:45
    David, sorry to tell you this, but it wasn't all my own work. In fact
    very little of it was.
    I've bought a BS2 and Board of education. Also downloaded Stampworks
    from Parallax. The project to run a single stepper is in that. All
    I've done is modify the program ever so slightly.
    However, there is still enough space on the BS2 to run a second
    stepper in the same manner. But that's all. Hence my need for
    expansion.
    Just to explain if you're using a Stamp powered a different way. The
    BS2 is only powered by a 9V battery, regulated to 5 volts on the
    B.O.E. All other components are on a separate prototye board which
    had a regulated 12 power supply attached to it. That was what was
    driving the stepper.
    Incidentally, my project is to run what is essentially a fruit
    machine/one armed bandit type mechanism, but instead of the reels
    displaying fruits etc. it will have rubber stamps attached to the
    reels. This is all because the outfit I work for is composed of
    technophobes who think it's a good idea to have a man manually
    stamping the product as it comes off the production line!
    The initial objective is to get the first three motors able to go
    from 1 to 999. Then once the technophobes know it's a feasible
    project, they'll invest in extra hardware and add the additional
    resources to enable the product code to also be rubber stamped
    automatically.
    Howard.
    > David
    of
    > > i/o lines?
    programming.
    information
    the
    > > Many thanks.
    > > Howard
    edited 2003-08-16 00:59
    If multiple motors have to run simultaneously, consider using Allegro
    driver chips and multiple stamps -- about 3 motors per stamp. If you
    are sending command signals from a PC to your stamp, just send them to
    all the stamps simultaneously, and sort out the control logic at each
    stamp. If the motors don't really have to run simultaneously, reduce
    the number of stamps by using DPDT relays at the ouputs of bipolar
    drivers, and switch the relays with stamps driving ULN2003 chips driving
    the relays. This works -- I've done it.
    Dennis
    From: howgreen2003 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hg4oolnCa0UEzuQN1UgQbnJRfFpwOPioZMlSdVvNOrXmGpwXM0Nik23OIn0g-mOi7E4TuTWbe_zJ4Af7yg]greenhf@l...[/url
    Sent: Thursday, August 14, 2003 1:56 PM
    Subject: [noparse][[/noparse]basicstamps] multiple stepper motors
    i/o lines?
    Many thanks.
    Howard
    Your use of Yahoo! Groups is subject to
    > automatically.
    If you are using the steppers to spin the counters for a serial
    number type of marker, you should be able to use a shift register to
    select which motor gets a signal, and sequence each motor so each
    motor would get a command, move and switch to the next. that would
    reduce the pin count considderably.
    you cannot do something like move an X/Y table and a drill/mill with
    this sort of connection. those require simultaneous moves.
