Which caps for serial com?
Hi All,
What type of caps do folks like for the programming input on a BS2p,
meaning the 100V/.1uF ones? I'll probably use DigiKey, if anyone has a part
# handy. Through hole mount as small as possible would be ideal.
Jonathan
www.madlabs.info
Jonathan
www.madlabs.info
jpeakall@m... writes:
> Thanks,
BC1160CT, .1uf, 50WVDC, .100 centers
Sid Weaver
W4EKQ
Port Richey, FL
So it is ok to use a cap rated for 50V? What about 35V? I have some tantalum
.1uF/35V caps handy.
Thanks for the help!
Jonathan
www.madlabs.info
Sent: Wednesday, August 13, 2003 1:13 PM
Subject: Re: [noparse][[/noparse]basicstamps] Which caps for serial com?
> In a message dated 8/13/2003 3:49:54 PM Eastern Standard Time,
part
> > Thanks,
> Sid Weaver
> W4EKQ
> Port Richey, FL
> tantalum
Jonathan, do NOT use tantalum. One of the caps is for coupling, the other
for by-pass. Use a ceramic or metal film cap that is not polarized. The part
numbers I gave you works well in all my applications.
Sid
Jonathan
www.madlabs.info
Sent: Wednesday, August 13, 2003 1:36 PM
> In a message dated 8/13/2003 4:34:10 PM Eastern Standard Time,
> > tantalum
part
> Sid
> Thanks Sid!
You're welcome, Jonathan. Anytime.
Sid
> other
Maybe you could fill in the blanks for those us who don't know about
tantalum VS. other caps.
Ben
writes:
Tantalums are basically electrolytics and as such are polarized. They should
never be used in a circuit where the "positive" lead could be subjected to a
voltage below ground, i.e., any negative voltage. They are normally used as
filter caps in circuits where the voltage is a pulsating DC, i.e. again, where
the voltage never goes below ground. Reverse polarity, if of sufficient
magnitude can cause a tantalum - or any other electrolytic - to explode. If you
look at the tops of aluminum or tantalum caps in the larger sizes, you will see
crossed indentations in the metal top. These are to allow the cap to expand
and vent when reverse voltage is applied and avoid an actual "explosion". This
works pretty well except in cases of extreme over-voltage.
Non-polarized capacitors - ceramic, film, foil - are not polarity sensitive
and they don't care which leads go to ground. This type should be used
whenever a coupling or bypass requirement exists, or in any
frequency-determining
circuit.
I hope this helps.
Sid
For A.C. passing audio applications, an electrolytic in the wrong place will
cause asymmetrical current to flow, with awful sounding audio the result.
And those little relief vents on electrolytic caps won't work in a
high-current reversal, which can result in molten aluminum confetti all over
your circuit. The reason why is that electrolytic caps pack a lot of farads
in a small space due to an oxide layer between the two foil segments. This
forms an insulating barrier between the conductive plates which can be is
very thin.... But this oxide layer will short out with any reverse polarity
resulting in catastrophic(!) failure.
Also be aware that for high-frequency switched power supplies, the
jelly-roll winding of a standard electrolytic has too much inductance to
work. So a folded high-frequency capacitor that's usable to 50 kHz or so is
selected for the job. Never substitute a standard electrolytic for a
switcher power supply capacitor. Bad things will happen....
Mike Sokol
Sent: Wednesday, August 13, 2003 7:12 PM
> In a message dated 8/13/2003 6:51:26 PM Eastern Standard Time,
ben@c...
> writes:
should
a
as
where
If you
will see
expand
This
sensitive
> circuit.
> I hope this helps.
> Sid
