diy programming board?
Hello!
My basic stamp came in today! Woop! However, I didn't buy a
programming board. Is the basic stamp similar to the oopic in that it
has a built in RS232 level shifter built in? AHHH!! Wait, wait,
wait. I think I found it. All I need to do is build that happy
little circuit shown in the schematic called "PC - to - BS2p40-IC
connection"! That's it?!? :-)
One more question.. does the basic stamp have it's own built in power
regulator?
Thanks a ton!!
- Bret
regulator?
Thanks a ton!!
- Bret
places, works like a charm.
It does have a regulator built in but DONT use it to power much. Regulator
has something like 50mA max capability. Refer to the parallax website for
experiments to do etc.
Hello!
regulator?
Thanks a ton!!
- Bret
Basic stamp?
In that case, the programming boards is useful equipment for
beginners since the Stamp can be programmed in a socket and have
access to I/O pins as well. A serial cable is connected from your PC
to the BS (Pin1-4). Study the book of this connection and look for
the two 0,1 uF caps. They have a special function. Your are
referring to a schematic: PC to BS2p. This is not a schematic to use
when you shall send the program from the PC to stamp, but used if a
PC-program (e.g. Visual basic) shall communicate with a stamp.
Remember: Port 16 (Pin 1-4) is a true serial connection using
12volt. I/O-port 0-15 is also capable of sending serial information,
but only at 0-5 volt. Don't connect P0-15 from your Basic Stamp
directly to the PC. If you use a RS232 driver (like MAX 323) you can
power up the TTL signal (0-5V) from the Basic Stamp to 12V level.
Take care of your Basic Stamp. Go to the store and get the extra
equipment as well a serial cable. Read the book. Don't try the hard
app-kit first.
Study the different Basic Stamp models in the book: BS1 BS2 and on,
so you don't get confused when you see a code from a BS2p, but only
have a BS2. (I was confused for a long time)
Stein.
--- In basicstamps@yahoogroups.com, PatM <pmeloy@s...> wrote:
> Yeah, just hack apart a serial cable and poke the wires into the
appropriate
Regulator
website for
> Hello!
that it
power
> regulator?
> Thanks a ton!!
> - Bret
on-chip. Be aware it uses the +12 from the
PC 232 TX wire to drive the +12 RX signal
back to the PC.
Yes, it does have an on-chip regulator. It
is limited to 50 mA, but means you can feed
the chip 6 volts to 9 volts on its 'Vin' pin,
and it won't fry.
Perhaps you can go as high as 12 volts, I
havn't wanted to risk it. I assume the
regulator would go into thermal shutdown
to protect itself if you used too high a
voltage. Note 24 volts probably would
destroy it.
--- In basicstamps@yahoogroups.com, "c45a6" <clone45@h...> wrote:
> Hello!
it
power
> regulator?
> Thanks a ton!!
> - Bret
