Pause
hi.........
I am new in BS2
Can I use Pause for 1 Hour with this comand?
PAUSE 1000 * 60000
thank you
Edson
I am new in BS2
PAUSE 1000 * 60000
thank you
Edson
answer, search the archive for the thread "time delay". One of the best
answers on how to do extended wait times comes from Jon (not
surprisingly! [noparse]:)[/noparse] and I quote it here:
>This is fairly simple. Pick a *base* delay (1 second, for example),
>then run it in a loop. Here's a quick subroutine that will work
>for you.
>Pause_1Sec:
> FOR timer = 1 TO seconds
> PAUSE 1000
> NEXT
> RETURN
>If you declare seconds as a Word variable, you can have delay of
>up to 18 hours, 12 minutes, 15 seconds.
>-- Jon Williams
>-- Parallax
Vern [noparse]:)[/noparse]
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
vern@t... www.txis.com | is up, then we obviously don't need
Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
h40miami said:
> hi.........
> I am new in BS2
> PAUSE 1000 * 60000
> thank you
> Edson
> Body of the message will be ignored.
h40miami@y... writes:
> hi.........
> I am new in BS2
> PAUSE 1000 * 60000
No you cannot do that.
But you can set up a "FOR NEXT" loop to pause for 1000, 60000 times.
The reason is that the maximum value one byte can hold is 65,535
The basic stamp is not super acurate for time keeping. you MIGHT have less
error if you pause 60000, and do that 10 times
hold up to 65535. All computations are done [noparse][[/noparse]internally] with 16-bit
variables so you must be careful that any intermediate result does not
exceed 65535.
-- Jon Williams
-- Parallax
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cOp_cgEANCS49XYJZPPjQDk-pG2-C152FwDr90LAPtmEdO3crXiYr9fFrIQc0WtFmITegKp7wNej7Vg]smartdim@a...[/url
Sent: Tuesday, August 12, 2003 2:27 PM
Subject: Re: [noparse][[/noparse]basicstamps] PAUSE
In a message dated 8/12/2003 11:47:00 AM Pacific Daylight Time,
> hi.........
> I am new in BS2
> PAUSE 1000 * 60000
less
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
jwilliams@p... writes:
> Sorry to nitpick ... one Byte can hold a value up to 255 -- a Word can
> exceed 65535.
> -- Jon Williams
> -- Parallax
I don't consider it nitpicking, if something is incorrect, by all means,
correction is in order..... I know better ( a byte can hold 255). I made a
simple
goof.......thanks for the post so "new-combers" don't get mislead...<grin>
in a single pause.
However, you CAN easily do:
NumMinutes VAR BYTE
NextHour:
NumMinutes = 0
TimeLoop:
PAUSE 60000
NumMinutes = NumMinutes + 1
IF NumMinutes < 60 THEN TimeLoop
' Put code to run every 60 minutes here...
END ' End of Program
--- In basicstamps@yahoogroups.com, "h40miami" <h40miami@y...> wrote:
> hi.........
> I am new in BS2
> PAUSE 1000 * 60000
> thank you
> Edson
