Newbie! Speed questions...
Hello!
I just finished a little music (sequencer) project using the OOPic.
The OOPic has proven interesting, but a little slow. When programmed
without using "virtual circuits", there's a noticable delay between
the input and output(~ 1.5 hudredths of a second) in simple programs
like this:
[noparse][[/noparse]pseudocode:]
do
copy value from input_pin to output_pin
loop
The project is a little unnusual in that I wish to allow the
microcontroller to be programmed by your average hacker. The gear
will have a 9 pin serial port right on it.
I'm considering either using the basic stamp, or the atmel
microcontroller. The Atmel, however, seems far less "friendly" to
program. Plus, I think I might have to include a complicated
programmer circuit right in my project, which adds a lot of overhead.
My question is... what type of delay should I expect from the basic
stamp (let's say the BASIC Stamp 2p) for simply copying a value from
an input to an output?
Thanks a ton!!
- Bret
like this:
do
loop
Thanks a ton!!
- Bret
range. I haven't measured myself (can you help here, Tracy), but most
simple instructions load and execute fairly quickly.
-- Jon Williams
-- Dallas Office
From: c45a6 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=R8LddSHF-yMVvRWucbOIjNKkSGSwUY7D19OCq_QcDIx2faXU9Ne4roOZ6GS2zyVtqySYCn6idtUlvw0c]clone45@h...[/url
Sent: Sunday, August 10, 2003 8:25 PM
Subject: [noparse][[/noparse]basicstamps] Newbie! Speed questions...
Hello!
like this:
do
loop
Thanks a ton!!
- Bret
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
(and valuable time) to write a tiny program that copies a logic input
line to an output line and measure the delay involved? I'd love to
get confirmation on that figure!!
If not, no worries. It's worth it for me to buy the basic stamp and
try it myself. :-)
Thank you so much for the speedy response!! Jon, if I do buy the
basic stamp, I'll try to remind myself to send you a visual comparison
of the basic stamp vs. the OOPic for this experiment. {PS: I'm not
dissing the OOPic.}
- Bret
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Depending on the instruction, it should be in the 100 - 200
microsecond
most
> -- Jon Williams
> -- Dallas Office
> From: c45a6 [noparse][[/noparse]mailto:clone45@h...]
> Hello!
programmed
programs
> like this:
> do
> loop
overhead.
from
> Thanks a ton!!
> - Bret
Subject
> abuse@p...
clone45@h... writes:
> Wow, that would be a vast improvement. Does anyone have the means
> try it myself. :-)
Yes, I will do it.....
let me confirm what you want to measure.....
Read a transistion on an input (low to high or high to low) then make an
output line go high.
If that is not what you want, clarify.......if that is good, email me soon, I
can do it tonight.
> try it myself. :-)
> dissing the OOPic.}
> - Bret
Bret,
I wrote a simple program for the BS2 to test the speed of an input to be
recognized and the act on an output. I think I read that the BS2sx is about 2.5
times faster than the BS2
dirs = $fe 'pin 0 input, all others outputs
out1 = 0 'make pin 1 logic zero
loop
if in0 = 1 then loop 'wait for pin 0 to go high
out1 = 1 'make pin 1 high
out1 = 0 'make pin1 low
goto loop ' do it again
I connected pin 0 to +5v via 1k ohms
Connected a signal generator to pin 1 at a frequency of 0.5 hertz
Connected a dual trace o-scope on pins 1 and 2, set for single trigger
and pin 0 the trigger source
About 20 trials produced the following results:
When pin 0 makes a low to high transition, the minimum time for pin 1 to go
high measured 550 uS, and the maximum time measured 920 uS.
The time varies due to not having control of exactly where the processor is
within the two instructions.
loop
I assume that the minimum time occurs if the low to high transition on pin 0
occurs when the JUST BEFORE checking the state of pin 0, and the maximum time
occurs if the low to high transition on pin 0 occurs JUST AFTER the processor
is finished checking the state of pin 0.
Also, once I made pin 1 high, I immediately make the pin low. The time of the
pulse on pin 1 measured 188 uS.
Hope this helps.
I belong to two user groups, this one and the SX sold by Unicom (Parallax
distributor) and it is unlikely you will find a user group with as much support
as this one (BS2).
If the Basic Stamp or BS2sx is not fast enough, the SX (not BS2sx) will be
plenty fast enough. Clocked at 50 Mhz, each instruction takes only 20nS, yes,
20nS. Most intructions take 2 or 3 clock cycles, so the same test on an SX will
take either 60ns or 80ns, depending on jump back to loop or not. Worst case,
the SX is ~6,800 times faster.
The instructions would look like this:
BS2 version
loop
out1 = 1
out1 = 0
SX version
loop
jnb ra.0,loop ;if pin ra.0 is low jmp to loop
setb ra.1 ;make pin ra.1 high
The SX distributed from Parallax is not nearly as user friendly as the Basic
Stamps, but Parallax has good tutorials on the device. The SX is about 1/10
the cost of the BS2sx and lighting fast by comparison.
DO
outH=INL ' copy 8 bits from inputs 0-7 to outputs 8-15
outH=INL ' again
LOOP
On the BS2p will take about 70 microseconds between the first one and
second one. It takes longer to get from the bottom of the loop back
to the top, 75 microseconds on the BS2p. That makes 145 microseconds
from the completion of the second transfer, around the loop to
completion of the first one again.
If you need more computations, more complicated mapping, or more
fancy steps, it will of course take longer. Here is a speed
reference...
http://www.emesystems.com/BS2speed.htm
-- Tracy
>Depending on the instruction, it should be in the 100 - 200 microsecond
>-- Jon Williams
>-- Dallas Office
>From: c45a6 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yxRs2IHNUwIO82aWGZri9grnTv9g24z63OZ6QvvLriMn3645mIN5rqWA173BMYIUhmxJujRvqY0Wm7dn9vY]clone45@h...[/url
>Hello!
>like this:
>do
>loop
>Thanks a ton!!
>- Bret
>abuse@p....
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
You were comparing Stamp to Atmel so only the latter is missing. I know a
little about the AVR and just wrote exactly the same as Tracy but in a BASic
COMpiler:
Do
IN R1, PortD
OUT PortC,R1
Loop
I looked at the compiled code in AVR Studio (free from Atmel) and it had
produced exactly what I would have written in assembler, just 3
instructions, total of 4 cycles.
4 cycles at standard 16 MHz is 250 nano secs - not micro secs.
That is almost the same as 'Hardwired'.
David Lawrence
www.rhombus-tek.com
Sent: Monday, August 11, 2003 2:35 AM
Subject: RE: [noparse][[/noparse]basicstamps] Newbie! Speed questions...
> Copying inputs to outputs, say:
> DO
> outH=INL ' again
> LOOP
> reference...
> -- Tracy
> >-- Jon Williams
> >-- Dallas Office
> >From: c45a6 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x9LEYTXekowKi0IJl-La7H6t70XYEBgd3AgrI-JYNr5_kOK_4-I0rQjqDDRHAz3kkbDgr1Wp2Gdb_NmE]clone45@h...[/url
> >Hello!
> >like this:
> >do
> >loop
> >Thanks a ton!!
> >- Bret
> >abuse@p....
