R/C pulse processing?
I've mostly been a lurker on this list but am venturing out of the
woodwork with a question for y'all:
Is a Stamp fast enough to measure the output of a four-channel R/C
model airplane receiver, perform a little bit of math on one of the
pulse widths, and regenerate the entire pulse frame, reliably and
accurately? In other words I want to insert a Stamp in between an FM
receiver chip's output and an existing servo processing circuit. The
only signal I can get at is the pulse stream right out of the
receiver, which has all four servo pulses sent one after the other on
one wire. It's the standard 1-2 msec pulse width modulated format,
with the start of a frame signalled by a low level much longer than 2
msec, and frames repeating about every 50 msec. I need to regenerate
a similar pulse stream rather than drive individual servos
separately, which I've done before. I'm guessing I might need to use
an assembly coded PIC for this, or some external hardware to keep the
timing accurate enough.
If anyone has tried something like this, I would love to hear about
how well it worked!
thanks,
Alex Stahl
Pixar Animation Studios
alex@p...
how well it worked!
thanks,
Alex Stahl
alex@p...
can monitor via PulseIN on each channel, but 4 at the same time might be pushing
it.
Nuts and Volts had an article on RC Failsafes that might interest you. He used
a PIC....
http://tinyurl.com/jbd7
And you work for Pixar!! How cool is that! What is the crew like? I'd imagine
the group as being spunky based on the fun stuff you guys put out!
Hope that helps,
Tim
>>> alex@p... 08/07/03 11:45AM >>>
how well it worked!
thanks,
Alex Stahl
alex@p...
from the same email address that you subscribed. Text in the Subject and Body
at 3AM trying to reboot all 2000 rendering processors :-)
>I don't think the stamp can monitor all 4 channels at the same time.
>I know you can monitor via PulseIN on each channel, but 4 at the
>same time might be pushing it.
>you. He used a PIC....
>I'd imagine the group as being spunky based on the fun stuff you
>guys put out!
>Hope that helps,
>Tim
>Hi,
>how well it worked!
>thanks,
>Alex Stahl
>alex@p...
>Subject and Body of the message will be ignored.
If the time between pulses is also at least a couple of millisecond
and not a critical parameter in the data stream you have to send,
then it should be possible with the Stamp. There is enough time to
capture each pulse with 5 successive PULSIN commands, and do the
math, and resend the stream, and be ready and waiting to receive the
next frame. You can do a lot in 50 milliseconds.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>Hi,
>how well it worked!
>thanks,
>Alex Stahl
>alex@p...
critical (doesn't need to be measured or preserved). Do you think
that's too fast for successive PULSIN's to capture? I'll find out
soon enough :-)
Also the frames repeat at 50 Hz, not every 50msec, that was a brain
fart on my part. Still, there's about 13 msec 'dead air' between
frames and the math is minimal, so I guess I'll give it a try with a
2sx Stamp.
thanks for all the replies so far,
Alex S.
>Within each frame, how long is the time between each 1-2 ms pulse?
> -- best regards
> Tracy Allen
> mailto:tracy@e...
>>Hi,
>>how well it worked!
>>thanks,
>>Alex Stahl
>>alex@p...
only be about 100 microseconds on the '2sx. So one full millisecond
between pulses should be plenty. 50 hz, 20 milliseconds per frame.
There should be time in there to squeeze in the calculation. But it
is going to take some time to transmit it all, too, and maybe you
can't miss the start of the next frame.
-- Tracy
>The time between each pulse is barely one millisecond, but it isn't
>soon enough :-)
>2sx Stamp.
>Alex S.
>> -- best regards
>> Tracy Allen
>> mailto:tracy@e...
>>>Hi,
>>>how well it worked!
>>>thanks,
>>>Alex Stahl
>>>alex@p...
Yeah, that's what I'm afraid of. Although come to think of it, I
probably can afford to miss every other frame, as long as I can
detect the long low pulse in between frames and never get mixed up on
where frame start is.
thanks,
Alex
> -- Tracy
>>soon enough :-)
>>2sx Stamp.
>>Alex S.
>>> -- best regards
>>> Tracy Allen
>>> mailto:tracy@e...
>>>>Hi,
>>>>how well it worked!
>>>>thanks,
>>>>Alex Stahl
>>>>alex@p...
