Time
Can Someone help me to on this.
I Want to turn a LED on for 5 min and off for 10 Min
What is the code using FORNEXT?
Or any another way for that big time
Thank you
Edson
Thank you
Edson
h40miami@y... writes:
> Thank you
> Edson
In a message dated 8/6/2003 3:57:55 PM Pacific Daylight Time,
> Thank you for your Help.
> Could you give a code Exemplo for 7 Min?
> Thank you
> --- Jon Williams <jwilliams@p...> wrote:
> >This is fairly simple. Pick a *base* delay (1
> >second, for example), then
> >run it in a loop.· Here's a quick subroutine that
> >will work for you.
> >Pause_1Sec:
> >· FOR timer = 1 TO seconds
> >·· PAUSE 1000
> >· NEXT
> >· RETURN
> >If you declare seconds as a Word variable, you can
> >have delay of up to
> >18 hours, 12 minutes, 15 seconds.
> >-- Jon Williams
> >-- Parallax
I don't remember how to declare variables but.....
For 5 minutes set seconds to 300
For 10 minutes set seconds to 600
seconds var word
seconds = 300·· (I think....if this is wrong, other stampers will chime
in....)
Pause_1Sec:
PAUSE 1000
NEXT
RETURN
This will consume a little more than 7 minutes because the "NEXT" and "FOR
timer = 1 TO seconds" do consume a small amount of time.
should be pretty close to say something like:
Top:
HIGH LED
FOR i=1 to 5
PAUSE 60000 ' 60000 = 1 minute
NEXT
LOW LED
FOR i= 1 to 10
PAUSE 60000
NEXT
GOTO Top
You need to define i (a nib or byte) and LED. If your LED lights when
low, reverse the HIGH and the LOW. You could get fancy:
Top:
HIGH LED
Minutes=5
Gosub PauseMin
I'll let you work that one out yourself.
Hope that helps!
Al Williams
AWC
* NEW Kits:
http://www.al-williams.com/kits.htm
> From: h40miami [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WGCT68couOvl8k311OmoPB57GBUh5QJSoutpdcDnYcOKQi4EzwUXqdqjQJzmTEYJ4k5ZyiZr6QWefQ]h40miami@y...[/url
> Sent: Wednesday, August 06, 2003 8:03 PM
> Subject: [noparse][[/noparse]basicstamps] Time
> Thank you
> Edson
> from the same email address that you subscribed. Text in the
Thank you for your help..
It help me alot.
--- Al Williams <alw@a...> wrote:
> Well, the Stamp isn't very time accurate over long
> periods, but it
> Top:
> HIGH LED
> FOR i=1 to 5
> NEXT
> LOW LED
> FOR i= 1 to 10
> PAUSE 60000
> NEXT
> GOTO Top
> fancy:
> Top:
> HIGH LED
> Minutes=5
> Gosub PauseMin
> Hope that helps!
> Al Williams
> AWC
> * NEW Kits:
> > From: h40miami [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HJS5Jva626-AC6sSnkUPwqwupamoHYJxGGii3kSB4MC6nozvveFOygYuVbGHZ8bjIemg6IsFpWVaYYs]h40miami@y...[/url
> Min
> > Thank you
> > Edson
> Text in the
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
