Basic Stamp Alarm Clock Project- ControlAudio Levels?
Spurred by your hint....I found they have many "Colors" of NOISE! I think your
neighbors might fall under Orange noise [noparse]:)[/noparse]
http://www.msaxon.com/colors.htm
Thanks for the info!
Found a neat clock that does the White Noise and even has a "sunrise!"....he
he...
http://biobrite.com/Cart/clocks.php3
Tim
>>> guydb@t... 08/06/03 01:47PM >>>
an OT remark...I guess you mean pink noise...it is what is being used in
noise 'cancellators' or whatever they are called...white noise is harsher,
rather unpleasant to listen to, pink noise is closer to surf sounds...I
have been using it to block out tens of students practising simultaneously
in the music across the street of a room where I do a lot of reading
guy
At 11:50 AM 8/6/2003 -0400, you wrote:
>To ramp up or down sound you could use a Motorized POT! With a Simple
>LM386 or similar the volume is controlled by a pot. Have the Stamp
>control the pot.....
>For you white noise....why not record the Analog unit via your PC....then
>burn a CD? Or use Software to generate White noise...and burn that to CD....[noparse]:)[/noparse]
>Does the White Noise really help that much? My office uses it and I it
>makes me wonder why the AC is so noisy!
>Good luck,
>Tim
> >>> vern@t... 08/06/03 10:16AM >>>
>Ok, I have a project I've been slowly advancing over time, and I thought
>I would throw my two pondering points out to see if someone can give me a
>shove in the right direction.
>Background: I have a Basic Stamp II with a Serial LCD module and the
>Pocketwatch unit, all from Parallax. I have it configured as a basic
>bedside alarm clock. Yeah, I know I could have gotten one for a lot less
>$$$, but it was a fun project to learn about the stamp when I was
>building a robot for my son (http://www.robocide.com) and when I finished
>with the BSII I ended up needing more horsepower so I got a IIsx that
>went into the robot so I had some spare parts and... but I digress... [noparse]:)[/noparse]
>Pondering Point 1: I have envisioned moving the "alarm clock" project
>forward by having it control the volume of a radio/cd/mp3 player. The
>idea would be to have the stamp slowly fade the sound in when the alarm
>goes off rather than just closing a relay and blasting me out of bed, as
>it does now. [noparse]:)[/noparse] I was toying with using the PWM out of the BSII to a cap
>that then slowly bias a transistor or....?, but before I went down that
>path, I wanted to see if anyone else has used a stamp to control an audio
>volume source, and if so might they be willing to share a schematic to
>keep me from re-inventing the wheel?
>For all I know there may be a One Wire or Scott Edwards widget called a
>"Serial Sound Controller" that I could just put in line and be done! [noparse]:)[/noparse]
>Pondering Point 2: I like to sleep with "White Noise" playing in my room
>to make my sleep more stable. (For those of you interested, white noise
>like rain sounds or waterfalls raise the "noise floor" that your mind
>uses as the threshold for what is loud enough to require your attention.
>Makes it easier to sleep through the night in the event that your spouse
>rises for the call of nature or the cat knocks over your son's large
>Power Ranger Action Figure in the middle of the night!)
>Anyway, I have an old analog unit that makes very good white noise. I
>wanted to have a 2nd unit to use when I traveled, so I bought one form
>the Sharper Image company. Unfortunately, this unit uses a digital
>generator that isn't as "random" as the analog unit I have and I can hear
>"loop" points in the noise that are very distracting when trying to fall
>asleep.
>So, since I would like to add some audio to my Basic Stamp Alarm Clock, I
>thought about including a white noise generator in the new design as
>another source for the stamp to control. For example, fade out the white
>noise while fading in the music. So, has anyone used the stamp to create
>white noise directly or does anyone have a circuit design that creates
>"analog" white noise the stamp could subsequently control?
>Any feedback/questions/suggestions humbly received. TIA! [noparse]:)[/noparse]
>Vern
>Vern Graner CNE/CNA/SSE | "If the network is down, then you're
>Senior Systems Engineer | obviously incompetent so why are we
>Texas Information Services | paying you? Of course, if the network
>vern@t... www.txis.com | is up, then we obviously don't need
>Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
from the same email address that you subscribed. Text in the Subject and Body
he...
Tim
guy
>Good luck,
>Tim
>asleep.
>Vern
