Precision Timing with SMt
Archiver
Wahoo, I've got the little beast (8-pins, 4 components,
and 6 wires) installed. It does give a very nice
square wave -- 50 mSec high, 50 mSec low -- which the
BS2 can read and keep up with quite nicely.
However -- it does use a Resonator, and so a clock
based on this (which I did in BS2 code, BTW) is only
as accurate as the Resonator. Mine runs fast by
about 1 second every 5 minutes. Note if I had
an accurate crystal, I could get time-stamps
accurate to .050 sec.
Having said that, there's ways of getting a more
accurate oscillator frequency I'll be pursuing.
Overall, I still think this is a very clever way
of providing the BS2 with a 'tick', so its actions
can be synchronized to wall time.
I simply have a short 'idle' loop, which waits
for the 50 mSec 'tick' state to change. It remembers
this state, then goes off to execute some code.
Having executed a little, it then calls the
'idle' loop again, and waits for the next 'tick'.
Currently my code simply increments some time
variables by 50 mSec each time. (Hr, Min, Sec, mSec).
and displays the resulting time. This is a very
nice way to demonstrate multi-tasking on an
introductory level.
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> DOH, that's 'Simple Multi-task' (SMt) solution.
> wrote:
> > David has a very nice 8-pin 'SMt'
> > 'Simple Real-Time' solution. I'm
> > currently evaluating these for use.
> > More later.
<allan.lane@h...>
> > wrote:
> > > Wow, very impressive.
> > > A selectable, accurate 'tick' generator
> > > in an 8-pin package, WITH a receive-only
> > > UART, no MAX232 needed. With this,
> > > a BS2 can time-stamp its own readings
> > > just by waiting for the 'tick'.
> > > However, I couldn't find the link for
> > > ordering your AVR package.
> > > --- In basicstamps@yahoogroups.com, "David Lawrence"
<david@r...>
> > > wrote:
> > > > Yes!
> > > > This will give your Stamp 'ticks' at intervals ranging from
5mS
> > up
> > > to 1+
> > > > secs in 5mS increments - use Stamp 'Shiftout' to setup the 8
> pin
> > > device - it
> > > > also buffers 57k baud in parallel, and costs <$12.
> > > > http://www.rhombus-tek.com/co-processors.html
> > > > http://www.rhombus-tek.com/SMt.htm
> > > > If that does not meet your speed needs, this definitely will:
> > > > http://www.rhombus-tek.com/avr-starter.html
> > > > and without the complexities of a BasicX 'RTOS'.
> > > > David Lawrence
> > > > Rhombus
> > > > From: Allan Lane <allan.lane@h...>
> > > > To: <basicstamps@yahoogroups.com>
> > > > Sent: Wednesday, July 30, 2003 2:41 PM
> > > > Subject: [noparse][[/noparse]basicstamps] Re: precision timer and the bs2p
> > > > > I believe the BasicX processor has its own
> > > > > real-time clock in it -- but you should ask
> > > > > on their Forum.
> > > > > --- In basicstamps@yahoogroups.com, "Christian Wentz"
> > > <cwentz86@h...>
> > > > > wrote:
> > > > > > my setup is running a BS2P (12,000 instructions/sec) with
> an
> > > array
> > > > > of
> > > > > > relatively fast ADC's (200,000sps), but i'm considering
> > running
> > > a
> > > > > basicx-01
> > > > > > chip from netmedia at 60,000 instructions/sec. Given those
> > > > > constraints, is
> > > > > > there an IC that can give .01-.001 resolution?
introductory level.
> > More later.
<allan.lane@h...>
<david@r...>
> > > wrote:
> > > > Yes!
5mS
> > up
> > > to 1+
> pin
> > > device - it
> > > > David Lawrence
> > > > Rhombus
> > > > > on their Forum.
> > > <cwentz86@h...>
> an
> > > array
> > > > > of
> > running
> > > a
> > > > > basicx-01
> > > > > constraints, is
very accurately to 60 Hz. Just sample it and generate a timing pulse 60
times a second and there is your accurate clock which require only a
capacitor and two resistors.
jim
http://www.geocities.com/jimforkin2003/
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WqCxYpyqteUukAZxJW8qupdM-ZDC04C_WFrlbFoM_x4cwQ7SuUbsdmNMW3KmYXieNs_tUdLUzamzje8QqgddCkqf6z0]allan.lane@h...[/url
Sent: Wednesday, August 06, 2003 4:05 PM
Subject: [noparse][[/noparse]basicstamps] Precision Timing with SMt
introductory level.
> > More later.
<allan.lane@h...>
<david@r...>
> > > wrote:
> > > > Yes!
5mS
> > up
> > > to 1+
> pin
> > > device - it
> > > > David Lawrence
> > > > Rhombus
> > > > > on their Forum.
> > > <cwentz86@h...>
> an
> > > array
> > > > > of
> > running
> > > a
> > > > > basicx-01
> > > > > constraints, is
connecting directly to 120 volts AC. Or did
you forget to mention the voltage drop-down
transformer?
Oh, wait, I've never looked at the ripple coming
out of my 'unregulated' DC adapters -- will that
give me 60 Hz?
I've now done more work with the SMt. It's a
really good idea -- but I think perhaps the
serial port needs some work. I'm unable to
figure out how to get 232 data out of it once
it's sent into it. I also havn't been able
to figure out (yet) how to ask it if it has
232 data, without waiting for it to get 232
data.
Later, AllanL.
--- In basicstamps@yahoogroups.com, "Jim Forkin" <jjf@p...> wrote:
> Don't forget that, in the USA anyway, the power line frequency is
regulated
pulse 60
> jim
> From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
> introductory level.
> > > More later.
> <allan.lane@h...>
> <david@r...>
> > > > wrote:
> > > > > Yes!
> 5mS
> > > up
> > > > to 1+
> > pin
> > > > device - it
will:
> > > > > David Lawrence
> > > > > Rhombus
> > > > > > on their Forum.
> > > > <cwentz86@h...>
with
> > an
> > > > array
> > > > > > of
> > > running
> > > > a
> > > > > > basicx-01
those
> > > > > > constraints, is
Subject and
--- In basicstamps@yahoogroups.com, "David Lawrence" <david@r...>
wrote:
> Hi Allan:
> The Examples below were taken directly from the CD supplied with
your Simple
> Multi-tasking Co-Processor.
> '--- Robotics Template (& PLC Template & PLC/Robotics Demos)
> If NotRdy = 1 Then SkipShift
> ShiftIn DPin, C1Pin, MsbPost, [noparse][[/noparse]L_Servo,R_Servo,DBugSws]
> PulsOut C1Pin, EOXfer
> SkipShift:
> Answer 1 - If the data is not ready then Skip as above example
> Answer 2 - ShiftIn as above
> I counted a total of 9 examples that cover everything from
receiving with,
> without Qualifiers, Checksums, Header Length etc.. Even templates
for both
> Robotics and PLC type applications. So that should get you started
for
> virtually anything you wish to tackle.
> I stripped out all the code for this post and here are some Example
> headings:
> 'RECEIVING A PRE-DETERMINDED PACKET LENGTH
> 'RECEIVING A VARIABLE PACKET LENGTH
> 'USING A QUALIFIER, FIXED LENGTH PACKETS & BYPASSING ALL OTHER DATA
> 'VALIDATING FIXED LENGTH PACKETS WITH A CHECKSUM
> 'USING A QUALIFIER, FIXED LENGTH PACKETS & VALIDATING WITH A
CHECKSUM
> All on the existing CD - now that is comprehensive!
> An enormous amount of time has been spent in preparing examples not
just for
> the Simple Multi-tasking chip
> http://www.rhombus-tek.com/SMt_PLC.htm
> http://www.rhombus-tek.com/SMt_Rob.htm
> but also for:
> http://www.rhombus-tek.com/FP.htm
> (Floating Point with Calculator style stored programs)
> http://www.rhombus-tek.com/OneWire.htm
> (1-Wire interface for the BS2)
> The thinking is the User starts with an example that is close to
what is
> needed, 'And It Works', then starts adjusting and re-testing at
each stage -
> easy to backtrack and learn from any errors. Much faster than
trying to
> start from scratch.
> David Lawrence
> > data.
> > Later, AllanL.
The Examples below were taken directly from the CD supplied with your Simple
SkipShift:
I counted a total of 9 examples that cover everything from receiving with,
without Qualifiers, Checksums, Header Length etc.. Even templates for both
Robotics and PLC type applications. So that should get you started for
headings:
'USING A QUALIFIER, FIXED LENGTH PACKETS & VALIDATING WITH A CHECKSUM
An enormous amount of time has been spent in preparing examples not just for
but also for:
The thinking is the User starts with an example that is close to what is
needed, 'And It Works', then starts adjusting and re-testing at each stage -
easy to backtrack and learn from any errors. Much faster than trying to
start from scratch.
David Lawrence
> data.
> Later, AllanL.
circuit will make 120 Hz ripple (100 Hz in Europe at 50 Hz) and a single
diode rectifier will make 60 Hz ripple. If you can guarantee the line cord
never gets flipped, then you can certainly use a series resistor with a
diode to make a poor-man's 60 Hz square wave generator with a .6 volt peak.
Remember this diode will need to block the full peak of the reverse sine wav
of the line voltage, so it needs to be a 200 Volt minimum diode, or 400
volts if it's seeing a full 170 volts from a full charged cap on the
positive side. I always used 600 volt PIV diodes for safety in my own
experiments. Again, transformer isolation is a good thing since it will
lower the voltage and limit the peak currents involved in a wiring mishap.
Mike Sokol
www.modernrecording.com
mikes@m...
Sent: Monday, August 11, 2003 10:52 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: Precision Timing with SMt
> The resistors are wired as a voltage divider to drop the AC down to a safe
> level and the capacitor couples the low level AC to your circuitry. You
> could then rectify it to product a dc level which follows the 60 hz and
> square it up with a one-shot or even ttl circuitry (sn7404) and you then
> have a precision 60 hz time base.
> jim
> From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qif0EaCxq7hUetR8Wl2615DKc6TPDdBBjY0reS0m0ROCQdIewJI2_RdBkxn1OX-jSme63Rgd_h8LCOazjGtz_cBx15XS]allan.lane@h...[/url
> Sent: Friday, August 08, 2003 7:50 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Precision Timing with SMt
> Well, yes, a capacitor and two resistors, and
> transformer?
> give me 60 Hz?
> data.
> Later, AllanL.
> regulated
> pulse 60
> > jim
> > introductory level.
> > > > More later.
> > <allan.lane@h...>
> > <david@r...>
> > > > > wrote:
> > > > > > Yes!
> > 5mS
> > > > up
> > > > > to 1+
> > > pin
> > > > > device - it
> will:
> > > > > > David Lawrence
> > > > > > Rhombus
> > > > > > > on their Forum.
> > > > > <cwentz86@h...>
> with
> > > an
> > > > > array
> > > > > > > of
> > > > running
> > > > > a
> > > > > > > basicx-01
> those
> > > > > > > constraints, is
> Subject and
forgot to mention that you can put a 5-volt Zener in series with the
rectifier resistor to make this circuit do a 5 V square wave. You can't use
a Zener diode to block the reverse part of the sine wave since they're
already in reverse biased avalanche mode when doing their job.
Mike Sokol
mikes@m...
Sent: Monday, August 11, 2003 10:17 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Precision Timing with SMt
> Also remember that full-wave bridge rectifiers hooked on an American wall
peak.
wav
> Mike Sokol
> mikes@m...
> From: "Jim Forkin" <jjf@p...>
safe
> > jim
> > From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3atyIm5paNjyiDqmxVeMSYJg_fhDQZm1mxjDhlykdrrPz5Nq7Y-x50bGrVAcYsOshH7fSufGQkVrrdVtt0648g1nZxwG0A]allan.lane@h...[/url
> > transformer?
> > give me 60 Hz?
> > data.
> > Later, AllanL.
> > regulated
> > pulse 60
> > > jim
> > > introductory level.
> > > > > More later.
> > > <allan.lane@h...>
> > > <david@r...>
> > > > > > wrote:
> > > > > > > Yes!
> > > 5mS
> > > > > up
> > > > > > to 1+
> > > > pin
> > > > > > device - it
> > will:
> > > > > > > David Lawrence
> > > > > > > Rhombus
> > > > > > > > on their Forum.
> > > > > > <cwentz86@h...>
> > with
> > > > an
> > > > > > array
> > > > > > > > of
> > > > > running
> > > > > > a
> > > > > > > > basicx-01
> > those
> > > > > > > > constraints, is
> > Subject and
and
and
jim
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iMulhLeOv-nKb1tOvVhXPLqfRTExSKPvBbnocD9CbEQWwANYRLshQncuxUD--3IT7dkyMnvRdZoHdnVM0JhM3S5msIOs]allan.lane@h...[/url
transformer?
give me 60 Hz?
data.
Later, AllanL.
regulated
pulse 60
> jim
> introductory level.
> > > More later.
> <allan.lane@h...>
> <david@r...>
> > > > wrote:
> > > > > Yes!
> 5mS
> > > up
> > > > to 1+
> > pin
> > > > device - it
will:
> > > > > David Lawrence
> > > > > Rhombus
> > > > > > on their Forum.
> > > > <cwentz86@h...>
with
> > an
> > > > array
> > > > > > of
> > > running
> > > > a
> > > > > > basicx-01
those
> > > > > > constraints, is
Subject and
