CMU cam and 7.5 Kgxcm servos don''t work with HomeWork Boards
The 220 ohm resistors are probably not the issue. The standard BOE has
caps on the supply that prevent servo surging from resetting the Stamp;
they are not on the Homework board (as there are no servo connectors).
Put a 1000 uF or larger cap between Vdd and Vss and I think you'll
probably see the problem go away.
-- Jon Williams
-- Parallax
From: Joe Terk [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=h3lk04wr2Ov9e4KI5bfmrdwADnI5Y0alFPas-t8ZxH4OUhdsaItt_67R-pPTIvMaY_rsvjn1jpaxons]joeterk@y...[/url
Sent: Tuesday, August 05, 2003 9:43 PM
Subject: [noparse][[/noparse]basicstamps] CMU cam and 7.5 Kgxcm servos don't work with
HomeWork Boards
Stampers:
I tried to use a
CMU cam and 7.5 Kgxcm servos with the HomeWork
Board
(item 28158) and they don't work.
Then I used and standard Basic Stamp 2 (item
BS2-IC)
whit BASIC Stamp 2 Carrier Board (item 27120) and
all
worked fine.
Even I used a second HomeWork Board but I have
the same problems.
I know that HomeWork Board has 220 resistors
but is this the problem?
Any help is welcome.
Thanks: Joe
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
-- Jon Williams
-- Parallax
HomeWork Boards
Stampers:
I tried to use a
Board
BS2-IC)
all
worked fine.
the same problems.
Thanks: Joe
Do you Yahoo!?
abuse@p....
