i/o pins shorted to ground
it seems some of my i/o pins have been shorted to ground
(internally).
1. what can cause this?
2. will putting a pull down resistor e.g. 10kOhm prevent the problem?
thanks
paul
(internally).
thanks
paul
This can be caused by tying two outputs together
with no resistance between them, driving one high,
and the other low.
Putting a 220 ohm resistor between the two drivers
will keep damage from happening -- it limits the
current to what the pins will bear. Of course,
it won't repair existing damage...
--- In basicstamps@yahoogroups.com, "justforgoyourmove" <pjw24@c...>
> (internally).
problem?
> thanks
> paul
pull down resistor as in the one shown for serin serout
communications on page 290 of the "Basic Stamp Manual version 2.0"
Will this value for the resistor ohm cause any trouble?
thanks again
paul
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> I'm not sure, but perhaps overcurrent on the pin?
> and the other low.
<pjw24@c...>
> > (internally).
> problem?
> > thanks
> > paul
value. What Allan was pointing out is that if one of your inputs
becomes an output low and you press a button, you'll have a direct short
and can damage a pin. His recommendation for an inline 220 ohm resistor
on the pin is good advice and cheap insurance.
Vdd
o |
o |
Stamp Pin >
[noparse][[/noparse]220]
[noparse][[/noparse]10K]
Vss
-- Jon Williams
-- Parallax
From: justforgoyourmove [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z2rNLlmplA1rw7WAraNNCt2C1DkMb0xAvuRhMy2Fu4mLgJJPx4oNeKQm3OsKmA8KLUF30m5sYXCb]pjw24@c...[/url
Sent: Tuesday, August 05, 2003 4:10 PM
Subject: [noparse][[/noparse]basicstamps] Re: i/o pins shorted to ground
i am using a 10kOhm resistor right now because it also serves as a
thanks again
paul
> and the other low.
<pjw24@c...>
> > (internally).
> problem?
> > thanks
> > paul
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
This is a good thing. The resistor I was talking
about is 'in series', in other words 'in the
signal path', in other words:
BS2Pin_A ----/\/\/\/\
BS2Pin_B
This series resistor should be 220 ohms, to
limit the 'contention current', when
BS2Pin_A is an output, driven HIGH, and
BS2Pin_B is an OUTPUT, driven LOW. You
see, you then have two drivers, both
struggling to control the state of
the line. (Note this is not a normal
state of affairs, but it could happen
accidentally)
BS2Pin_A will act as a current SOURCE,
outputting current into the resistor.
BS2Pin_B will act as a current SINK,
sucking current through the resistor.
With the resistor there, they are
limited to (5 Volts / 220 ohms == 22 mA)
22 milliamps, which is within the
current limit of the Stamp. Without
the resistor there, they try to put
out (5 volts / .01 ohms == 500 AMPS)
a LOT of current. Of course, they
can't put out that much current, but
the attempt WILL burn out the drivers
behind one of the pins if they are
allowed to try long enough.
> thanks again
> paul
> > and the other low.
> <pjw24@c...>
> > > (internally).
> > problem?
> > > thanks
> > > paul
10 VDC rather than the 5 VDC that Vdd is would a 470 ohm resistor do
the trick? (10V/470ohm = 21mAmps)
thanks again
paul
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> No, 10K will not cause any problems as a pull-down; it's a standard
short
resistor
> Vdd
> o |
> o |
> Stamp Pin >
> Vss
> -- Jon Williams
> -- Parallax
> From: justforgoyourmove [noparse][[/noparse]mailto[noparse]:p[/noparse]jw24@c...]
> thanks again
> paul
> > and the other low.
> <pjw24@c...>
> > > (internally).
> > problem?
> > > thanks
> > > paul
Subject
> abuse@p...
Like this:
10v
o |
o |
Stamp Pin >
Vss
Now when the button is pressed, the Stamp will see 5V. The 220 is no
longer necessary as the path to 10v or to ground (Vss) is through 10K.
-- Jon Williams
-- Parallax
From: justforgoyourmove [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z2KTC73rhJDLn1BGkoKfJ62h6QxcPwTuY6uexmV8jWh4sgCy0RbRRVMZYz0Jk-7gbMV5Z4CeJXknijo]pjw24@c...[/url
Sent: Wednesday, August 06, 2003 3:29 PM
thanks you - so likewise if the button were to short the pin to say
thanks again
paul
short
resistor
> Vdd
> o |
> o |
> Stamp Pin >
> Vss
> -- Jon Williams
> -- Parallax
> thanks again
> paul
> > and the other low.
> <pjw24@c...>
> > > (internally).
> > problem?
> > > thanks
> > > paul
Subject
> abuse@p...
abuse@p....
serin/serout information or possibly 10 VDC. Would the voltage
divider with the top 10k resistor between the pin and the input
allow the serial communication to work - and/or would this work
Stamp Pin >
[noparse][[/noparse]470]----+
serin/serout (but possibly 10 VDC)
[noparse][[/noparse]10k]
Vss
or would this again be a voltage divider that would screw up the
serial communication - i.e. would not let logic high be 5 but rather
470/10470 * 5??
thanks again
paul
wrote:
> I would suggest using a voltage divider to make the input Stamp-
safe.
> Like this:
> 10v
> o |
> o |
> Stamp Pin >
> Vss
no
10K.
> -- Jon Williams
> -- Parallax
say
do
> thanks again
> paul
<jwilliams@p...>
standard
inputs
direct
> short
> resistor
> > Vdd
> > o |
> > o |
> > Stamp Pin >
> > Vss
> > -- Jon Williams
> > -- Parallax
a
2.0"
> > thanks again
> > paul
<allan.lane@h...>
> > > and the other low.
> > <pjw24@c...>
> > > > (internally).
> > > problem?
> > > > thanks
> > > > paul
> Subject
to
> > abuse@p...
Subject
> abuse@p...
resistor.
-- Jon Williams
-- Parallax
From: justforgoyourmove [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=noHcPwkA8HHnMC1-b69KYnmnDjo1nEThqbMrBT8D4DEbV1wnCHbRGAGtW8PBKS8MJIsk1GvgZwyq33Y]pjw24@c...[/url
Sent: Wednesday, August 06, 2003 5:13 PM
this is actually the situation - you see the input could either be
Stamp Pin >
Vss
470/10470 * 5??
thanks again
paul
safe.
> Like this:
> 10v
> o |
> o |
> Stamp Pin >
> Vss
no
10K.
> -- Jon Williams
> -- Parallax
say
do
> thanks again
> paul
<jwilliams@p...>
standard
inputs
direct
> short
> resistor
> > Vdd
> > o |
> > o |
> > Stamp Pin >
> > Vss
> > -- Jon Williams
> > -- Parallax
a
2.0"
> > thanks again
> > paul
<allan.lane@h...>
> > > and the other low.
> > <pjw24@c...>
> > > > (internally).
> > > problem?
> > > > thanks
> > > > paul
> Subject
to
> > abuse@p...
Subject
> abuse@p...
abuse@p....
