IC''s for sale
Device Name Function
ADC0808CCN
CD40106BE
CD40192BE
CD4019BE CMOS Quad AND/OR Select Gate
CD4021BE
CD4059AE CMOS Programmable Divide by N Counter
CD4072BE Dual 4 Input OR Gate
CD4072BE
CD4078BE CMOS 8 Input OR/NOR Gate
CD4094BE CMOS Programmable Divide by N Counter
CD4510BE
CD4520BE CMOS Dual Up Counters
CD4536BE
CD74AC20E Dual 4-Input NAND Gate
CD74AC541E Octal Buffer/Line Drivers
CD74ACT374E OCTAL D-TYPE Flip-Flops
CD74ACT86E
CD74HC390E Dual Decade Ripple Counter
CD74HCT21E Dual 4-Input AND Gate
CD74HCT365E Hex BUFFER/DRIVER TRI STATE
CD74NC4050E Hex None-Invert BUFFER
CLC5632IN
DS5000T
L293DNE Quad HALF-H Driver
LM1084IT-5 5A Positive Regulator
LM1283N
LM1894N Dynamic Noise Reduction System
LM1971N Audio Attenuator w/ Mute
LM2825HN-ADJ
LM285LP-2-5
LM2940CT-5 1A 5V Low Dropout Regulator
LM2940T-5 1A 5V Low Dropout Regulator
LM336BLP-2-5 2.5 V Reference
LM35DT
LM385BZ-1.2 Micropower Voltage Reference
LM385LP-2-5 2.5 V Precision Voltage Reference
LM3914N-1
LM4651N
LM4765T
LMD18200T
LMS1585ACT-ADJ LDO Fast Response Regulator
LMS1585AiT-ADJ LDO Fast Response Regulator
LT1004CLP-2-5 2.5 V Micropower Voltage Reference
SN74ACT373N "OCTAL D-TYPE TRANSPARENT LATCHES
WITH 3-STATE OUTPUTS"
SN74ACT533N D-TYPE TRANSPARENT LATCH
SN74HC165N 8 Bit SHIFT REGISTER
SN74HC266N "QUADRUPLE 2-INPUT EXCLUSIVE-NOR GATES
WITH OPEN-DRAIN OUTPUTS"
SN74HC367N Hex BUFFER/DRIVER TRI STATE
SN74HC682N 8-BIT MAGNITUDE COMPARATORS
SN74HC688N 8-BIT IDENTITY COMPARATORS
SN74HC7002N Quad NOR Gate
SN74LS221N
TL497AIN Switching Voltage Regulator
TL750L05CKC 5V 150mA LDO Regulator
TPIC6C596N 8 Bit SHIFT REGISTER
TPS6755IP Adjustable DC/DC Converter
Phototransistors, Photodiodes, IR LED's, Super Bright LED's, Servo
Motors and other Electronic Stuffs you need are also available.
SMS me: 09194261468
ADC0808CCN
CD40106BE
CD40192BE
CD4021BE
CD4072BE
CD4510BE
CD4536BE
CD74ACT86E
CLC5632IN
DS5000T
LM1283N
LM2825HN-ADJ
LM285LP-2-5
LM35DT
LM3914N-1
LM4651N
LM4765T
LMD18200T
SN74LS221N
SMS me: 09194261468
