Compound conditions with new IF/Else statement
Hi all,
Does anybody know if you can use compound condition statements
with the new IF/Else (v2.5) statement? This code is acting real
strange, it will allow values of say "250" to drop thru the
first test and trigger the bad value else clause at the end of
the statement.
IF (IR_pulse(i) > 200 AND IR_pulse(i) < 350) THEN
IrMessage = IrMessage << 1
'--- test for 1 bit
ELSEIF (IR_pulse(i) > 550 AND IR_pulse(i) < 650) THEN
irMessage = (IrMessage << 1) + 1
ELSE
IrMessage = 0 <---- VALUES LIKE "250" ARE GETTING HERE!
DEBUG "Ir is bad -- ", DEC3 IR_pulse(i), CR
GOTO ScanIrExit
ENDIF
Is it me doing something stupid, or is there something else
going on here? Any help would be greatly appreciated. The
manual doesn't say explicitly that you can't, but only gives
examples of simple conditional tests.
Michael Burr
the statement.
'--- test for 1 bit
ELSE
GOTO ScanIrExit
ENDIF
Michael Burr
What size variable (byte, word,...) is IR-pulse?
Steve
On 4 Aug 03 at 11:23, Michael Burr wrote:
> Hi all,
> Does anybody know if you can use compound condition statements with
> the new IF/Else (v2.5) statement? This code is acting real strange,
> it will allow values of say "250" to drop thru the first test and
> trigger the bad value else clause at the end of the statement.
SELECT IR_pulse(i)
CASE 200 TO 350
CASE 550 TO 650
CASE ELSE
IrMessage = 0
GOTO ScanIrExit
ENDSELECT
I don't see anything flawed in your logic, so I'm going to forward it to
our Engineering staff.
-- Jon Williams
-- Parallax
From: Michael Burr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mHAsoYv5Z2gjr3Aqe-c_cRzfdPzKH_9pO-GX8xqYzK_gPp6DuLVq22PN3r6rnn15kS_5bkXJ]mburr@b...[/url
Sent: Monday, August 04, 2003 1:24 PM
Subject: [noparse][[/noparse]basicstamps] Compound conditions with new IF/Else statement
Hi all,
the statement.
'--- test for 1 bit
ELSE
GOTO ScanIrExit
ENDIF
Michael Burr
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
On Monday, August 4, 2003, at 02:23 PM, Michael Burr wrote:
> Hi all,
> the statement.
> '--- test for 1 bit
> ELSE
> GOTO ScanIrExit
> ENDIF
> Thanks,
> Michael Burr
> Michael-
> Steve
Thanks for the response, IR_pulse is a 16-bit word.
Michael
of things on my end and send Jeff a more complete piece of code
if need be. Your Case example is another very good option.
Btw: Is there a specific place to register issues with the new
2.5 editor? I've come across a couple of items you might want
on your to do list (one was an infinite loop that I had to kill
the editor to get out of).
Michael
Jon Williams wrote:
> SELECT-CASE is probably better suited for what you're attempting to do:
> SELECT IR_pulse(i)
> CASE 200 TO 350
> CASE 550 TO 650
> CASE ELSE
> IrMessage = 0
> GOTO ScanIrExit
> ENDSELECT
-- Jon Williams
-- Parallax
From: Michael Burr [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=bSTcG9oiarz8nEbgsilcCQKNsH90XsXkm6lxjkqmiGsHdjxFt4-mXZCCzU8_Z5AG5jmxSOBBIpse]mburr@b...[/url
Sent: Monday, August 04, 2003 4:42 PM
Subject: Re: [noparse][[/noparse]basicstamps] Compound conditions with new IF/Else
statement
Thanks for the input Jon and Jeff. I will double check a couple
Michael
> do:
> SELECT IR_pulse(i)
> CASE 200 TO 350
> CASE 550 TO 650
> CASE ELSE
> IrMessage = 0
> GOTO ScanIrExit
> ENDSELECT
> to our Engineering staff.
abuse@p....
