BS2p inbuilt LCD-function question
I’m a new user to BS2p, jumping all the way from BS2.
I want to use the inbuilt LCD-functions on the BS2p (LCDCMD,LCDOUT),
but my Parallel LCD is a 4x40 char SEIKO LCD, with two Enable pins, E1 for
the upper two lines and E2 for lower two lines.
Then how can I use LCDCMD pin, command for the 2 first lines and then
use the same function for the next two lines. Or is it another clever way to do
this?
The datasheet tell me to use the LCD as two separate display, so line 1-2 must
be
Initialized, and then line 3-4 afterwards.
I could of course make an electronic mux to control where to guide the signal
eider to E1
Or E2, but that would be brutal.
Hope for a solutions from somebody.
____________________________________________________________
Get advanced SPAM filtering on Webmail or POP Mail ... Get Lycos Mail!
http://login.mail.lycos.com/r/referral?aid=27005
this?
be
eider to E1
either pin 0 or pin 1 as the Enable pin, you can use both. Like this:
LCDOUT 0, 1, [noparse][[/noparse]"Display 1"] ' clear display and write string
LCDOUT 1, 1, [noparse][[/noparse]"Display 2"]
Connect the other lines as described in the help file. As you've
indicated, you'll have to double-up on your initialization routine, but
you can simplify it with a loop:
FOR ePin = 0 TO 1
LCDCMD ePin, .....
NEXT
-- Jon Williams
-- Parallax
From: xystein frostad [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Pyz1yUi2fDI_gvbqIjTHlBklwNpfaqBF6F-Ap7qlhb6DShxWEwoiMB04pBhiIKWsxJGGGEAKuH9tYR5XriosLlt7D8FY]Stein_Frostad@m...[/url
Sent: Sunday, August 03, 2003 6:22 PM
Subject: [noparse][[/noparse]basicstamps] BS2p inbuilt LCD-function question
I'm a new user to BS2p, jumping all the way from BS2.
I want to use the inbuilt LCD-functions on the BS2p (LCDCMD,LCDOUT), but
way to do this?
1-2 must be Initialized, and then line 3-4 afterwards.
signal eider to E1
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
two distinct LCDs sharing all connections except the E* strobe input.
I'd suggest a simple, OR gate x2 arrangement so that E* strobe is
directed to one or the other (or possibly even both for
initialization or other common actions) E* inputs. One input on
each OR comes from a Stamp pin (so that's two pins, one for each OR
gate) to determine which input sees the strobe. The Stamp's E*
output drives both of the other OR inputs. A LOW on the selection
pin will allow the EN* strobe to pass to the selected LCD.
Steve
> E1 for the upper two lines and E2 for lower two lines.
> then use the same function for the next two lines. Or is it another
> clever way to do this?
> line 1-2 must be Initialized, and then line 3-4 afterwards.
> the signal eider to E1 Or E2, but that would be brutal.
> Mail! http://login.mail.lycos.com/r/referral?aid=27005
Special Thanx to Jon.
And to Steve as well.
--- In basicstamps@yahoogroups.com, "S Parkis" <parkiss@e...> wrote:
> It may be helpful (and factually accurate) to think of youe LCD as
input.
OR
> Regards,
> Steve
(LCDCMD,LCDOUT),
pins,
another
guide
