DC to DC voltage conversions — Parallax Forums
edited 2003-08-03 17:29 in General Discussion
Hi out there-
I am interested in utilizing a Dallas Semiconductor 1-wire (an i-button,
actually) ADD-
ONLY memory in a project that I am working on.
The application note indicates that to 'set' the information into the EEPROM,
a 12-
volt, 10 ma pulse must be generated for about 500 microseconds on the data line
of
the memory. I know that this can be done using a DC to DC converter, but I
remember that, for low current applications, one can put together a rather
simple
voltage doubler circuit. Is anybody familiar with that? Better yet, is anyone
familiar
with the circuit that handles 1-wire ADD-ONLY EEPROMS? Or can someone refer me
to
an app note that covers the hardware side of the 1-wire EEPROMS?
Thanks in advance,
-Mark
    edited 2003-08-02 02:29
    Hi out there-
    actually) ADD-
    a 12-
    of
    simple
    familiar
    to
    Thanks in advance,
    -Mark
    edited 2003-08-02 11:21
    AppNote 74 from Maxim, page 17, shows a diagram named 'TTL R/W all
    circuit' for programming the iButtom Add-Only EPROM. link:
    http://pdfserv.maxim-ic.com/an/en/app74.pdf
    SWFitz
    --- In basicstamps@yahoogroups.com, "mmarpet" <marpetm@s...> wrote:
    > Hi out there-
    i-button, actually) ADD-
    the EEPROM, a 12-
    the data line of
    but I
    rather simple
    is anyone familiar
    someone refer me to
    > Thanks in advance,
    > -Mark
    edited 2003-08-02 11:34
    Do you absolutely have to use the add-only eprom? An eeprom would
    simplify thing tremendously. See the BS2p demo board and the BS2p
    plus pack documentation - on the parallax site - for wiring and
    program examples using the iButton EEPROM.
    SWFitz
    > Hi out there-
    the EEPROM, a 12-
    the data line of
    but I
    rather simple
    is anyone familiar
    someone refer me to
    > Thanks in advance,
    > -Mark
    edited 2003-08-02 16:05
    SWF-
    I do indeed need an ADD-ONLY EPROM (actually, multiple ADD-ONLYs) , as
    the application involves audit integrity, and I can't see how to set up
    another device that is simply unalterable. Thanks for the app note 74
    reference. I'll study it and see if I can make heads or tails out of it.
    -MIM
    > SWFitz
    >> Hi out there-
    > the EEPROM, a 12-
    > the data line of
    > but I
    > rather simple
    > is anyone familiar
    > someone refer me to
    >> Thanks in advance,
    >> -Mark
    > from the same email address that you subscribed. Text in the Subject
    > and Body of the message will be ignored.
    edited 2003-08-03 11:14
    In that case check out:
    http://dbserv.maxim-ic.com/quick_view2.cfm/qv_pk/1736/ln/en
    The link above is for a voltage doubler IC with 125 ma. output current.
    For lower currents look at the MAX1719/MAX1720/MAX1721.
    These devices are commonly called 'charge pumps', and there are many
    configurations to choose from.
    Also, for the programming circuitry look at:
    http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2923
    This link is for a Serial to 1-wire driver IC that will apply the 12v
    programming voltage for you - using serial commands, of course. It
    handles all 1-wire devices.
    SWFitz
    --- In basicstamps@yahoogroups.com, Mark Marpet <marpetm@s...> wrote:
    > SWF-
    > -MIM
    > > SWFitz
    > >> Hi out there-
    > > the EEPROM, a 12-
    > > the data line of
    > > but I
    > > rather simple
    > > is anyone familiar
    > > someone refer me to
    > >> Thanks in advance,
    > >> -Mark
    edited 2003-08-03 11:43
    Just realized that the Maxim ICs I mentioned in the last message may
    not provide the voltage you need. Look at the ICL7660 by Intersil.
    http://www.intersil.com/design/parametric/deviceinfo.asp?pn=ICL7660
    This device has an input volatge range of 1.5V to 10V and can double
    up to 18V. Has a max output current of 45ma. Can be cascaded for
    higher output voltages from low input voltages. Circuit examples in
    the datasheet.
    > SWF-
    > -MIM
    > > SWFitz
    > >> Hi out there-
    > > the EEPROM, a 12-
    > > the data line of
    > > but I
    > > rather simple
    > > is anyone familiar
    > > someone refer me to
    > >> Thanks in advance,
    > >> -Mark
    The IC recommended in APP Note 74 (and thanks again for that reference)
    is The Linear Technology 1109, which can be seen at
    http://www.linear.com/prod/datasheet.html?datasheet=237
    > the datasheet.
    >> SWF-
    >> up
    >> it.
    >> -MIM
    >>> SWFitz
    >>>> Hi out there-
    >>> the EEPROM, a 12-
    >>> the data line of
    >>> but I
    >>> rather simple
    >>> is anyone familiar
    >>> someone refer me to
    >>>> Thanks in advance,
    >>>> -Mark
