c++ serial not reading bs2
Hello all,
I am using Visual Studio.NET c++ to interface with my stamp, however
my code is not reading what my bs2 is sending (possibly a timeout
error?) The code I am using is essentially what is found on MSDN for
serial communications. I have also modified my carrier board
correctly (i know this because other com port testing programs pick
up my stamp and read my from the stamp fine).
I was hoping someone could read through the short c++ code to see if
I am initializing anything wrong.
The code can be found at:
http://www.geocities.com/zatakur/cpp/serial.txt
And my BS2 code is simply:
'{$STAMP BS2}
serData VAR BYTE
serData = 10
Main:
SEROUT 16, 16780,[noparse][[/noparse]serData]
End
-Dave Boz
'{$STAMP BS2}
serData VAR BYTE
serData = 10
Main:
End
-Dave Boz
of development involving stamps and PCs... here's the code I use. It's part of
a class I wrote, which I'd be happy to send you if you'd like it. The important
part of the code follows. Note that it was written for a UNICODE system, which
is why it uses wide chars and the TEXT() macro. It should be easy enough for
you to convert. It's been working like a charm for me for more than 2 years...
WCHAR Buffer[noparse][[/noparse]80];
swprintf(Buffer, TEXT("COM%d:"), PortNum)[noparse];)[/noparse]
// Open the serial port.
hPort = CreateFile(Buffer, GENERIC_READ | GENERIC_WRITE, 0, NULL,
OPEN_EXISTING, 0, NULL);
if (hPort == INVALID_HANDLE_VALUE)
//LastError = ERR_PORT;
//WriteLog(TEXT("Unable to open the COM port"), true,
TEXT("CSerialComm::Open()"));
return false;
//swprintf(Buffer, TEXT("Serial connection opened on COM%d"), PortNum);
//WriteLog(Buffer);
PortDCB.DCBlength = sizeof(DCB);
GetCommState(hPort, &PortDCB); // Get the default port setting information.
// Change the port settings for no flow control
PortDCB.BaudRate = 9600; // Current baud
PortDCB.fBinary = TRUE; // Binary mode; no EOF check
PortDCB.fParity = FALSE; // Enable parity checking.
PortDCB.fOutxCtsFlow = FALSE; // No CTS output flow control
PortDCB.fOutxDsrFlow = FALSE; // No DSR output flow control
PortDCB.fDtrControl = DTR_CONTROL_DISABLE; // DTR flow control type
PortDCB.fDsrSensitivity = FALSE; // DSR sensitivity
PortDCB.fTXContinueOnXoff = TRUE; // XOFF continues Tx
PortDCB.fOutX = FALSE; // No XON/XOFF out flow control
PortDCB.fInX = FALSE; // No XON/XOFF in flow control
PortDCB.fErrorChar = FALSE; // Disable error replacement.
PortDCB.fNull = FALSE; // Disable null stripping.
PortDCB.fRtsControl = RTS_CONTROL_DISABLE; // RTS flow control
PortDCB.fAbortOnError = FALSE; // Do not abort reads/writes on error.
PortDCB.ByteSize = 8; // Number of bits/bytes, 4-8
PortDCB.Parity = NOPARITY; // 0-4=no,odd,even,mark,space
PortDCB.StopBits = TWOSTOPBITS; // 0,1,2 = 1, 1.5, 2
if (!SetCommState(hPort, &PortDCB))
Close();
return false;
// modify timeouts
GetCommTimeouts(hPort, &CommTimeouts);
CommTimeouts.ReadIntervalTimeout = 2; // at 9600 baud, should be only 0.83, so
this is sufficient
CommTimeouts.ReadTotalTimeoutMultiplier = 0;
CommTimeouts.ReadTotalTimeoutConstant = 20;
CommTimeouts.WriteTotalTimeoutMultiplier = 0;
CommTimeouts.WriteTotalTimeoutConstant = 0;
if (!SetCommTimeouts(hPort, &CommTimeouts))
LastError = ERR_TIMEOUT;
Close();
//WriteLog(TEXT("Unable to set COM time-out parameters"), true,
return false;
return true;
From: zatakur [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=A0E7_my223s7GLJFQO9M17ve9iWn34sdHd1XLmum5S8L-my8fwzAClIwSGLxjgxUdm9pKkXRbx2lDg]zatakur@y...[/url
Sent: Thursday, July 31, 2003 2:23 AM
Subject: [noparse][[/noparse]basicstamps] c++ serial not reading bs2
Hello all,
'{$STAMP BS2}
serData VAR BYTE
serData = 10
Main:
End
-Dave Boz
from the same email address that you subscribed. Text in the Subject and Body
I think the reason your code doesn't work is that a colon is required after the
port name when you pass it to CreateFile(). You should be passing "COM1:".
Check the MSDN docs.
From: zatakur [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ND3NK2rsx7RmT_l6RdjWA0gTEk3BluPUxieXz3L2FZdHBNWICppuGSE1OoyPwOyOO-QipcR0Vg]zatakur@y...[/url
Hello all,
'{$STAMP BS2}
serData VAR BYTE
serData = 10
Main:
End
-Dave Boz
noticed it was a time out error. Here is how i fixed it:
// Change the COMMTIMEOUTS structure settings.
// I set them all to zero.
CommTimeouts.ReadIntervalTimeout = 0;
CommTimeouts.ReadTotalTimeoutConstant = 0;
CommTimeouts.WriteTotalTimeoutMultiplier =0;
-Dave Boz
--- In basicstamps@yahoogroups.com, "Meador, Ryan D ERDC-CRREL-NH"
<Ryan.D.Meador@e...> wrote:
> If I'd only been a little slower hitting that send button... I
had a brainwave. I think the reason your code doesn't work is that
a colon is required after the port name when you pass it to
CreateFile(). You should be passing "COM1:". Check the MSDN docs.
> From: zatakur [noparse][[/noparse]mailto:zatakur@y...]
> Hello all,
however
for
pick
if
> '{$STAMP BS2}
> serData VAR BYTE
> serData = 10
> Main:
> End
> -Dave Boz
Subject and Body of the message will be ignored.
