Please clarify the syntax of SHIFTOUT command inPBASIC
I am wondering if there is an error in the manual for the PBASIC
command description "SHIFOUT". I quote below the manual (obtained
from help menu in the PBASIC editor 2.0 beta 2.1).
By default, SHIFTOUT transmits eight bits, but you can set it to
shift any number of bits from 1 to 16 with the Bits argument. For
example:
SHIFTOUT 0, 1, MSBFIRST, [noparse][[/noparse]250\4]
Will only output the lowest 4 bits (%1010 in this case).
Some devices require more than 16 bits. To solve this, you can use a
single SHIFTOUT command with multiple values. Each value can be
assigned a particular number of bits with the Bits argument. As in:
SHIFTOUT 0, 1, MSBFIRST, [noparse][[/noparse]250\4, 1045\16]
The above code will first shift out four bits of the number 250 (%
1111) and then 16 bits of the number 1045 (%0000010000010101). The
two values together make up a 20 bit value.
example:
shiftout 0,1,msbfirst,[noparse][[/noparse]250\4]
will shift out the "lowest 4 bits (%1010 in this
case)", that is correct. (The previous version of the manual said
%0000 there, which was incorrect!) In the next paragraph, it states
that [noparse][[/noparse]250\4] will shift out
"four bits of the number 250 (%1111)..."
Which is wrong. What it shifts out is in fact the lowest 4 bits, "1010".
Here is what happens with,
shiftout 0,1,msbfirst,[noparse][[/noparse]variable\n]
...the Stamp grabs the lowest n bits of the variable and pads it to
the left with zeros if necessary. Then it sends
the n bits, most significant bit first. For example
x var word
x = 250 ' = %0000000011111010 in binary
shiftout 0,1,msbfirst,[noparse][[/noparse]x\4]
*sends %1010
shiftout 0,1,msbfirst,[noparse][[/noparse]x\11] ' <-MSB first
*sends %00011111010
shiftout 0,1,lsbfirst,[noparse][[/noparse]x\11] '<--LSB first!
*sends %01011111000
I hope that clarifies it for you.
-- Tracy
>example:
it very easy to understand. I appreciate it very much.I hope the
parallax team is aware of this mistake and has taken steps to correct
it.
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> When the manual says,
states
bits, "1010".
> x var word
> *sends %1010
> *sends %00011111010
> *sends %01011111000
> -- Tracy
> >example:
a
update, I'll make sure it gets taken care of. The help file source is
already fixed and will be recompiled for the next compiler release.
-- Jon Williams
-- Parallax
From: mohammedrasiq [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=w_E0VAAhCdiCSpjjPaZBS90yvZOeyfaOEzcMS85DoRnsjoW8hSCMdKMj1nj5zSbwmDbii1CM2oeH-EBX5BlvDXM]mohammedrasiq@y...[/url
Sent: Tuesday, July 29, 2003 5:35 PM
Subject: [noparse][[/noparse]basicstamps] Re: Please clarify the syntax of SHIFTOUT command
inPBASIC
Thanks a lot, Tracy! Your explanation, as always, is lucid and makes
it.
states
bits, "1010".
> x var word
> *sends %1010
> *sends %00011111010
> *sends %01011111000
> -- Tracy
> >example:
a
> >two values together make up a 20 bit value. "
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
