bs2p40 DIRS — Parallax Forums
bs2p40 DIRS
edited 2003-07-29 06:06 in General Discussion
>Hello...
>I'm having a bit of trouble initially setting the DIRS
>of all 32 I/O pins. If I start my program with
>DIRS = %1111111111111111
>It only does the MAINIO set. If I change it to
>MAINIO
>AUXIO
>Then the program just gets into a wierd neverending
>loop. Any ideas?
There is no reason there to put it into a loop.
Maybe setting one of those auxio pins to output is turning on some
external device that causes a glitch on the power supply that causes
it to reset. Put a
debug "top"
statement at the top of the program.
What kind of weird loop?
    edited 2003-07-29 02:46
    >It's strange, I've messed around with it a bit and it only happens if
    >I set the entire pin register to output on both IO's.
    >Init:
    > Debug "Initializing...", CR
    > MAINIO
    > DIRS = $FFFF ' or whatever
    > AUXIO
    > DIRS = $FFFF
    >Any other value less than 65535 will not cause this to happen. It's
    >hard to see what exactly is happening because I can't really debug
    >what's going on. The program just keeps looping thru Init and strange
    >characters are spit out in between the debug.
    >hmm....?
    Is that the entire program, the six lines above? What is the BS2p40
    connected to, in terms of a power supply and the i/o pins? There is
    something funny going on! The debugging process here will certainly
    take a process of elimination. Have you actually eliminated all
    values less than 65535 simultaneously on mainio and auxio, or could
    there be other combinations you haven't tried yet?
    -- Tracy
    edited 2003-07-29 05:13
    I changed your code a little as indicated below. You are resetting your stamp
    due to a high output load probably coming from the Opto relays. They draw
    about 3 to 10 ma on the input side per relay. That means the stamp have to
    output
    as much as 150 ma which could cause a power reduction and reset condition. I
    ran your code without relays and it works fine. Hope this help.
    Chuck
    '{$STAMP BS2p}
    '{$PBASIC 2.5}
    x VAR Bit
    Init:
    DEBUG "init", CR
    x = 0
    MAINIO
    DIRS = $FFFF
    auxio
    DIRS = $FFFF
    Main:
    OUTS = $FFFF
    DEBUG "OUTS: ", BIN16 OUTS, CR
    PAUSE 500
    OUTS = $0000
    PAUSE 500
    x = ~x
    debug ? x
    IOTERM x
    GOTO main
    Well, just a guess, but it takes about 12 ma to drive the LED in each
    module at 5 volts, and when all 16 modules are being driven at once,
    the current limit of the Stamp is exceeded. The BS2p specs 30 ma per
    pin, but, 60 ma total per each group of 8 pins.
    Maybe it works, barely, to drive 15. Why the weird debug? Maybe the
    Stamp takes a fraction of a second to "realize" that it is
    overloaded, and then it resets, and tries again. Or the power supply
    filter capacitor for the Stamp is part of the time delay.
    The spec for the OPTO22 G4 series is 12 ma at 5 volts--the input
    circuit of the module is simply a 220 ohm resistor in series with the
    visible indicator led and the IR isolation led.
    For better results, maybe use an emitter follower or buffer on each
    Stamp pin, or use one of the 32-output Allegro shift register/power
    drivers. Or don't drive more than about 3 modules at a time from
    each group of 8 on the Stamp.
    -- Tracy
    >BS2p40
    >is
    >certainly
    > > -- Tracy
    >I have the stamp connected to an OPTO22 32-module I/O rack. Each pin
    >is controlling the logic for a separate module. At the moment, the
    >modules are not actually switching anything on or off, but since they
    >are optically isolated it really doesn't matter much. I've just been
    >testing via the LEDs on the backs of the I/O modules.
    >I have verified there are no shorts, and the module rack is grounded
    >properly. Much more sophisticated programs (based on the Toddler
    >state program) have worked without a hitch, and actually this problem
    >forced me to rethink my program structure - resulting in a much better
    >flow.
    >The program I initially tested on was ultra-simple:
    >'{$STAMP BS2p}
    >'{$PBASIC 2.5}
    >x VAR Bit
    >Init:
    > DEBUG "init", CR
    > x = 0
    > MAINIO
    > DIRS = $FFFF
    > auxio
    > DIRS = $FFFF
    >Main:
    > OUTS = $FFFF
    > DEBUG "OUTS: ", BIN OUTS, CR
    > PAUSE 500
    > OUTS = $0000
    > PAUSE 500
    > x = ~x
    > IOTERM x
    > GOTO main
    >DEBUG looks like this:
    >init
    >OUTS: 1111111111111111
    >OUinit
    >OUinit
    >OUTS: init
    >OUTinit
    >OUþinit
    >any ideas ?
    >from the same email address that you subscribed. Text in the
    >Subject and Body of the message will be ignored.
    >Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
