Basic Stamp and data EEPROM Read/Write
Does anybody have experience with writing data to and
reading data from the Basic Stamp 2 EEPROM?
First I write some data to known positions at the
EEPROM. Then I start reading and checking them in the
debugging window, but only the first two are correct,
and the rest is corrupted. Also in the same moment
there are problems with the program execution, it
loops without an exit...
Has somebody an idea what is going on?
Thank you in advance.
Petar
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
Petar
Do you Yahoo!?
are all stored in the same eeprom). To check where your program code
stored in the eeprom ends, check the memory map. Then start writing
your variables to the eeprom only at addresses after your program
code.
--- In basicstamps@yahoogroups.com, Petar Ljusev <ratep2001@y...>
> Petar
> Do you Yahoo!?
plenty of space at the beginning of the EEPROM map. So
I am sure that I am not overwriting anything - I keep
a look at the EEPROM map all the time.
Is there something else that can be hapenning?
--- Sam <hard-on@t...> wrote:
> you are probably overwriting your program code with
> variables (they
> your program code
> Then start writing
> your program
> code.
> <ratep2001@y...>
> and
> the
> correct,
> > Petar
> > Do you Yahoo!?
> design software
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
Do you Yahoo!?
