SV: [basicstamps] Re: BS2-sx
Greetings
Ideally you should use the BS2P or the BS2Pe if you want to use 1-Wire
since these have the necessary commands built-in, but...
You can also use a DS2480 chip which is a 'serial to 1-Wire' interface.
Then you'd talk to the chips using the normal Serial commands at 9600bps
(That's the lowest speed it can work on)
You still need the actual 1-wire commands, but they are documented in
the .PDF's available on DalSemi's site.
Trygve
Opprinnelig melding
Fra: dasstamp [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LJnscStqvNpB3HdMfEQy1r8c73hgwtwjYyD834mI6-GWVoFTKD3uXK7scK-l-amTEnOiHAhcwzLWJoXj]dave@t...[/url
Sendt: 28. juli 2003 14:59
Til: basicstamps@yahoogroups.com
Emne: [noparse][[/noparse]basicstamps] Re: BS2-sx
Hello,
I have a BS2SX and would like to play around with 1-wire. I understand
it might
require a coprocessor to do this. Are you familiar with what kinds of
coprocessor it
might require?
David
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> has many more features (LCD, I2C [noparse][[/noparse]my
> favorite!], 1-Wire, the ability to read and write EEPROM across
banks...).
Your use of Yahoo! Groups is subject to
Trygve
Opprinnelig melding
Hello,
it might
coprocessor it
might require?
David
banks...).
