Chattering relay - RC Bot — Parallax Forums
edited 2003-07-31 01:16 in General Discussion
I'm playing with my 1st RC Bot, its a sickly little thing, but I had to
start somewhere.
Everything is working so far, with the exception of the relays I'm using to
turn the gear reduced motors on and off. If they are under too much load
(like rapidly reversing direction) they seem to 'shut off' and back on a
couple of times a second until the load is reduced.
Its too late to change them now, I might as well start over if that's the
case. Everything worked fine on the bench, but when I drove it, the
problem developed. 1st lesson in building a robot, test it before you
finish it!
I'm using 5 volts to turn the coil on and off, and I'm switching about 20
volts DC. The load is less than 1 amp, and the relay is rated for 3 amps.
Any ideas? Anything additional I can do to the current setup to save it?
My stamp isn't going to stay in this one very long anyway, but I would like
to have a little fun with it first!
-John
    edited 2003-07-28 04:56
    In a message dated 7/27/2003 8:45:04 PM Pacific Daylight Time,
    john@l... writes:
    Exactly how are you energizing the relay coil? Are you powering the coil with
    5V directly from the stamp?
    Or is the stamp driving a transistor, that grounds the coil?
    Also, does your relay coil have a doide across it (cathdoe end to the + side
    of coil)?
    Is the relay being driven from the stamp 5v power supply or auxillary voltage
    source?
    Please give details on exactly how your relay is wired / interfaced to the
    stamp....
    edited 2003-07-28 06:10
    Hi John,
    Here's what may be happening... When your motors experience heavy load,
    they draw more current from your batteries. This is probably reducing the
    available battery voltage to the point where the relay coils can no longer
    hold the contacts closed. Once the relay contacts open, the motor is no
    longer loading down the battery voltage so the voltage goes back up and the
    relays can turn on once again. Now the motors are back in the circuit and
    the battery voltage goes back down....
    Another possibility is that the battery voltage is going low enough that the
    Stamp power is going below 5 volts and the Stamp is resetting and starting
    your program over once the voltage returns to an adequate level. It sounds
    more like the former, though.
    Try monitoring the battery voltage when the motors are heavily loaded to see
    what happens. If you are running the Stamp and the motors from the same
    battery, you can try temporarily running the Stamp from a separate 9V
    battery to see if that makes a difference. At least then you know that the
    Stamp has adequate voltage to run properly.
    If the problem isn't the Stamp resetting you have a few choices... Increase
    the current capacity of the battery, reduce the maximum current drawn by the
    motors, or avoid the operating condition that puts so much load on the
    motors.
    Another possibility... a bad connection to the battery may be causing a high
    resistance, which would result in a voltage drop under load. If you find
    that the voltage at the relay coils does dip enough to cause the relay
    contacts to open, check the voltage at the battery pack under the same
    conditions. If it is nearly the same, voltage drops in the wiring aren't
    the problem. If it is significantly higher at the battery, you need to
    check for high resistance in the wiring and connections between the battery
    and the relays/motors. Adequate wire size and good connections should not
    allow much voltage drop from the batteries to the loads they power (motors
    in this case).
    Hope this helps,
    Randy
    www.glitchbuster.com
    > start somewhere.
    to
    > finish it!
    like
    > -John
    edited 2003-07-28 13:56
    usually this type of problem is not caused by the load, but by the control
    voltage dropping below the level required to hold the relay on. Also it
    could be noise feeding back into the micro causing erratic control to the
    relay. Check your ground connections and relay control lines for cold
    solder joints. An oscilloscope is very helpful for finding this kind of
    problem because a meter is too slow to detect some of these kinds of
    problems.
    jim
    http://www.geocities.com/jimforkin2003/
    From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1SvIKJwK9nBcKgcIG6BrNeueP8I7Fn-rSKQNF8j5mDf8lJXIHqWXOjccrqmCPR0_k5qHTiFG40lCZA]john@l...[/url
    Sent: Sunday, July 27, 2003 11:44 PM
    Subject: [noparse][[/noparse]basicstamps] Chattering relay - RC Bot
    start somewhere.
    finish it!
    -John
    edited 2003-07-28 17:07
    Thanks for the replies everyone, I know I owe some of you some more
    details, but I'm at work now... I'll give the suggestions a try, if I
    can't narrow it down I'll post more.
    You guys are great.
    -John
    From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gbSv2qzxHjfPzn_Je4z_VSBpHbchzKV-hpdBCJJTURzZmVCKQsX2-AKCkPnkMkO0z_dEsxVj]jjf@p...[/url
    Sent: Monday, July 28, 2003 7:56 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Chattering relay - RC Bot
    control
    the
    problems.
    jim
    From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=crrkfUYA02KH6aBhrVxhsMc2mheZsw8Y2P0AXJbDkjUtQ65KF99AhZti5CMM0HTFBs_1FGZlVQo]john@l...[/url
    start somewhere.
    to
    load
    the
    finish it!
    20
    amps.
    it?
    like
    -John
    and
    edited 2003-07-31 01:11
    Hi John,
    I'm not sure if this has been suggested, or if your
    problem has been solved, but capacitors may be a cheap
    solution.
    Whenever you have relays, motors, batteries, and
    control electronics, you have voltage sags and
    momentery drop-outs. I would suggest "decoupling the
    hell" out of your different voltages. For your 5V
    line, I'd put a 4,700uF, 10V cap in parallel with it.
    For the 20V source, I'd put a 2,200uF, 25V cap on it.
    Big surplus caps are cheap and can make a huge
    difference durring transient conditions. Unless your
    battery or power supply can deliver 5,000AH, a large
    cap can significantly lower the impeadance of your
    supply rail.
    I see lots of threads about "chattering" this, or
    "pulsing" that. Then I see recommendations of 1uF or
    maybe 47uF caps to help. In professional applications
    where PCBs are used and low impeadance power supplies
    are in place, this may be fine. But for point-to-point
    construction, or proto-boards, I'd highly recommend
    large caps (i.e. 1,000uF to 10,000uF @ 20% higher
    voltage than what's being filtered). Unless timing is
    being set, large caps on power supply circuits
    generally can never hurt.
    Dr. Diode
    > of you some more
    > You guys are great.
    > -John
    > From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MP3YWeaOX4df7p2iBSchr25ToBFVJT21oKnuzej6h8wom5ntdBAG6ZBRiCAgeiMgNv72eJjB]jjf@p...[/url
    > load, but by the
    > control
    > erratic control to
    > the
    > of these kinds of
    > problems.
    > jim
    > From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tHa9MN7ILO8Ot3fYMfhUb_dU5_5R_8pd2HN7ML3YHjXPQXZaXSmCxJHgMam6n2Jn-tqIo_go]john@l...[/url
    > thing, but I had to
    > start somewhere.
    > to
    > are under too much
    > load
    > the
    > I drove it, the
    > test it before you
    > finish it!
    > I'm switching about
    > 20
    > amps.
    > it?
    > anyway, but I would
    > like
    > -John
    > Text in the Subject
    > and
    > Text in the Subject
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________
    Do you Yahoo!?
    Yahoo! SiteBuilder - Free, easy-to-use web site design software
    http://sitebuilder.yahoo.com
    Oops. . .
    I meant 5,000mAH (5AH) - 5,000AH would be for welding.
    --- PH <drdiode2002@y...> wrote:
    > Hi John,
    > cheap
    > solution.
    > it.
    > it.
    > supply rail.
    > applications
    > supplies
    > point-to-point
    > is
    > Regards,
    > Dr. Diode
    > > of you some more
    > > You guys are great.
    > > -John
    > > From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=slWk6NZyjkFFF7Rg3J3sIgJQyV4H6nVGZBVFPKcmX8FRcGe31nCkJg2JM8YyuI-HEvqn8Jxecw]jjf@p...[/url
    > Bot
    > > load, but by the
    > > control
    > > erratic control to
    > > the
    > for
    > > of these kinds of
    > > problems.
    > > jim
    > > From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sr7Hbc3CcANpaigw-6E9UgQwj-BLBf1ad7cFCSh8LFPcaB7GDx7a6bFDMoSo9sCj8aSA3r_791ix]john@l...[/url
    > little
    > > thing, but I had to
    > > start somewhere.
    > of
    > > to
    > > are under too much
    > > load
    > reduced.
    > > the
    > when
    > > I drove it, the
    > robot,
    > > test it before you
    > > finish it!
    > > I'm switching about
    > > 20
    > > amps.
    > > it?
    > > anyway, but I would
    > > like
    > > -John
    > > Text in the Subject
    > > and
    > > Text in the Subject
    > be
    > > ignored.
    > Do you Yahoo!?
    > design software
    > ignored.
    Do you Yahoo!?
