IR Circuit Question (Solved)
Well, it was wrong. Swapping the IR transistor so the long lead went
to ground (ie, the long lead was the emitter which was opposite the
flat spot) fixed the problem. I now get full range deflection in
varying light conditions.
Isn't the flat spot side supposed to be the emitter?
--- In basicstamps@yahoogroups.com, "rrothe64" <rrothe@m...> wrote:
> Thanks, Tracy. I will try it with room light and take some
> measurements.
> Since I'm very new to this, I was careful to follow the
schematic...
> However, I will say that some of the documentation for the
components
> wasn't very good (ie, RShack). In particular, the IR tranistor
> lacked meaningful documentation (to me) --- so I went with "long
lead
> to positive" which is what the StampsInClass docs say. Now if
this
> is wrong, that might explain it.
> I'll keep plugging along.... Thanks again.
> Rob
> --- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> > That circuit at the junction of the 100k and the Coll should
> > transition pretty rapidly from 5 volts down to less than one volt
> as
> > light intensity increases past a certain level. What happens if
> you
> > expose it to a 100w light bulb or sunlight? If it doesn't go
down
> > to less than one volt, there is something wired wrong. Did it
work
> > okay in the Industrial Control experiment?
> > Detection of a weak light source against a strong background is a
> > problem. Depending on the situation, it might take shielding the
> > receiver in a tube, an IR filter over it to block ambient,
> modulation
> > of the source and AC amplification in the detector, and a
> photodiode
> > instead of a transistor for wider dynamic range.
> > If the object to be detected is moving, you might be able to
check
> > better for *change* in level, by coupling the signal from the
> > photo-transistor through a capacitor to the comparator. Passive
> > infrared (PIR) might also be an option.
> > -- Tracy
> > >I can certainly try this. However, I think my question really
is:
> > >Why is the detection of IR by the transistor only amounting to
> > >1/100th of a voltage change being fed to the OP-AMP? No matter
> how
> > >strong/weak the IR source is, the most change I can induce is
> 1/100th
> > >of a volt... This is the part that is too sensitive, I think,
since
> > >the reference voltage has no buffer zone.
> > >If the IR intensity resulted in a larger range, then the op-amp
> could
> > >be better tuned as a comparator. No?
> > >Tx,
> > >Rob
> > >> > > +5--/\/\/\----|
Coll Emit
Gnd
> > >> > > 100K | B
> > >> > > OpAmp
> measurements.
schematic...
components
lead
this
> Rob
> as
> you
down
work
> modulation
> photodiode
check
> > -- Tracy
is:
> how
> 1/100th
since
> could
> > >Tx,
> > >Rob
> > >> > > +5--/\/\/\----|
Coll Emit
Gnd
> > >> > > 100K | B
> > >> > > OpAmp
