How to lock BS2 ? — Parallax Forums
How to lock BS2 ?
edited 2003-07-25 23:12 in General Discussion
How can I lock the program in the BS2 so no one can access it? Need
info on the software procedure and hardware one...thanks.
    edited 2003-07-24 23:06
    There is no procedure because it is not necessary. Your program source
    is compiled to tokens and downloaded to the BASIC Stamp. Once they're
    in the Stamp in token form, the extremely difficult to remove and no one
    -- that we know of -- has produced a decompiler that actually works.
    The only thing you have to protect is your source code file(s).
    -- Jon Williams
    -- Parallax
    From: basilflorida [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9tl5YyMlvJCPoRl3v48K0R01bvpUpEmR7ltLZTIdkubkYAkVEYNFYZUihJe8rK5EP6J3zIwIiI38TVMHFw]basilflorida@y...[/url
    Sent: Thursday, July 24, 2003 4:33 PM
    Subject: [noparse][[/noparse]basicstamps] How to lock BS2 ?
    Your use of Yahoo! Groups is subject to
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2003-07-25 18:55
    This isn't practical or feasible. Your (tokenized) program is stored
    on your Stamp's EEPROM for access via your Stamp's microprocessor. If
    the EEPROM were "locked", the microprocessor itself couldn't fetch
    it, and your program couldn't run. It's a fact of the Stamp's
    architecture.
    As Jon pointed out, it is not possible to recover your Stamp
    program's source code from the EEPROM. The reason is simple--it's
    not stored on the Stamp, it resides on your programmer platform only
    (PC or whatever). However, the tokenized version of the program can
    in fact be recovered--in mere seconds and without leaving any
    sign--then easily cloned in other Stamps, and/or analyzed to produce
    a functionally equivalent set of source code. This isn't speculation
    or theory--it's been done. While Parallax may not acknowledge this
    possibility, you may want to know it exists.
    Bottom line: very sensitive information (e.g., high cost proprietary
    code, DATA statements containing location of secret moon base, Stamp
    program to steal gold from Fort Knox) can be retrieved and used by
    others.
    Steve
    edited 2003-07-25 21:03
    A radical solution: After you program it, cut off the serial output
    pin, and maybe cover whatever metal that is still visible with epoxy.
    Of course, you will not be able to program it anymore.
    stored
    If
    > architecture.
    speculation
    > others.
    > Regards,
    > Steve
    Need
    edited 2003-07-25 21:23
    Problem with that is you can still access the EEPROM - just solder a wire
    onto the EEPROM or pull the EEPROM from the Stamp board. Only solution there
    is to cut off the pin actually on the EEPROM, but then it becomes useless to
    the Stamp.
    - Robert
    Sent: Friday, July 25, 2003 2:03 PM
    Subject: [noparse][[/noparse]basicstamps] Re: How to lock BS2 ?
    > stored
    > If
    > > architecture.
    > speculation
    > > others.
    > > Regards,
    > > Steve
    > Need
    edited 2003-07-25 22:40
    Microchip PICs can be programmed to set the Code Fuse Bit. When it is
    set, attempts to read the assembled hex code from the PIC will produce
    randomized code. This can be defeated, but it requires a major effort
    and extra hardware.
    In theory, pBASIC could be extended to include this option, but in
    practice there wouldn't be much call for it among the Stamp user group.
    Dennis
    From: Robert Ussery [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-_zpRPXQMhNOXrRccjxoMob6Y9Gwxn3ET9c8EOfueLvvF4JY6T5HPR4-ex33ufniJcbeUkWDEXhgpEyL]uavscience@f...[/url
    Sent: Friday, July 25, 2003 1:24 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: How to lock BS2 ?
    wire onto the EEPROM or pull the EEPROM from the Stamp board. Only
    solution there is to cut off the pin actually on the EEPROM, but then it
    becomes useless to the Stamp.
    - Robert
    <deleted>
    The BS2 on-module PIC stores the PBasic
    interpreter. It stores the P-compiled code
    in an on-module EEPROM as part of the
    download process. So while you
    can't read the PIC's interpreter, you
    still can read the EEPROM.
    As has been mentioned, though, this only
    gets you the compiled version of the code,
    which is of limited use. I suppose
    someone COULD go through all the effort of
    reverse-engineering the source, and there's
    really no way to prevent that. What I ask
    myself is, doesn't this take an awful
    amount of time, effort, (and perhaps money?).
    If you're code is so sensitive that it is
    WORTH the time and money to reverse-engineer
    it, then you probably shouldn't put it in
    a BS2. You could put it directly into a
    PIC, and set the no-read bit, for instance.
    --- In basicstamps@yahoogroups.com, Dennis O'Leary <doleary@e...>
    is
    produce
    effort
    > and extra hardware.
    group.
    > Dennis
    > From: Robert Ussery [noparse][[/noparse]mailto:uavscience@f...]
    then it
    > - Robert
    > <deleted>
