IR Circuit Question
I've adapted the tachometer excercise from the StampsInClass
Industrial Control text to serve as a simple proximity detector. It
is wired exactly as the example in the text.
I can get the design to function, but the adjustment is *so*
sensitive that I don't think it would work once it leaves my bench.
I can only get it to work when the reference voltage into the op-amp
is exactly 4.88 volts. 1/100th up or down, and it does not work.
I'm using a radio-shack 10K pot as the voltage divider to provide
this reference voltage. The IR Detector is wired:
+5--/\/\/\----|
Coll Emit
Gnd
100K | B
OpAmp
Does this sound right?
Ideally, I'm trying to create a near-field motion sensor (about 12-
18") to serve as a trigger. It should not be impacted by day/night
operations (which is a problem with the IR application). Any other
suggestions would be appreciated.
Rob
+5--/\/\/\----|
Coll Emit
Gnd
100K | B
OpAmp
Rob
multiturn pot of the same value it shouldn't be so
sensitive then
> StampsInClass
> is *so*
> leaves my bench.
> into the op-amp
> does not work.
> divider to provide
> +5--/\/\/\----|
Coll Emit
Gnd
> 100K | B
> OpAmp
> sensor (about 12-
> Thanks,
> Rob
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
IF you don't need to adjust throughout the entire range of the 10K, then it'd
offer a bit of sensitivity....I'm guessing (didn't do the math..grr).
sb
Date: Thursday, July 24, 2003 7:21 am
Subject: Re: [noparse][[/noparse]basicstamps] IR Circuit Question
> just a idea i would replace the 10k pot with a
> sensitive then
> > StampsInClass
> > is *so*
> > leaves my bench.
> > into the op-amp
> > does not work.
> > divider to provide
> > +5--/\/\/\----|
Coll Emit
Gnd
> > 100K | B
> > OpAmp
> > sensor (about 12-
> > Thanks,
> > Rob
> > ignored.
> Do you Yahoo!?
> from the same email address that you subscribed. Text in the
Why is the detection of IR by the transistor only amounting to
1/100th of a voltage change being fed to the OP-AMP? No matter how
strong/weak the IR source is, the most change I can induce is 1/100th
of a volt... This is the part that is too sensitive, I think, since
the reference voltage has no buffer zone.
If the IR intensity resulted in a larger range, then the op-amp could
be better tuned as a comparator. No?
Tx,
Rob
--- In basicstamps@yahoogroups.com, buht_krak@s... wrote:
> Or what about putting a 20K pot in parallel with a 20K resistor.
then it'd offer a bit of sensitivity....I'm guessing (didn't do the
math..grr).
> sb
> From: kenneth magers <kenneth_m_73149@y...>
> > sensitive then
> > > StampsInClass
> > > is *so*
> > > leaves my bench.
> > > into the op-amp
> > > does not work.
> > > divider to provide
> > > +5--/\/\/\----|
Coll Emit
Gnd
> > > 100K | B
> > > OpAmp
> > > sensor (about 12-
> > > Thanks,
> > > Rob
> > > ignored.
> > Do you Yahoo!?
transition pretty rapidly from 5 volts down to less than one volt as
light intensity increases past a certain level. What happens if you
expose it to a 100w light bulb or sunlight? If it doesn't go down
to less than one volt, there is something wired wrong. Did it work
okay in the Industrial Control experiment?
Detection of a weak light source against a strong background is a
problem. Depending on the situation, it might take shielding the
receiver in a tube, an IR filter over it to block ambient, modulation
of the source and AC amplification in the detector, and a photodiode
instead of a transistor for wider dynamic range.
If the object to be detected is moving, you might be able to check
better for *change* in level, by coupling the signal from the
photo-transistor through a capacitor to the comparator. Passive
infrared (PIR) might also be an option.
-- Tracy
>I can certainly try this. However, I think my question really is:
>Tx,
>Rob
>> > > +5--/\/\/\----|
Coll Emit
Gnd
>> > > 100K | B
>> > > OpAmp
measurements.
Since I'm very new to this, I was careful to follow the schematic...
However, I will say that some of the documentation for the components
wasn't very good (ie, RShack). In particular, the IR tranistor
lacked meaningful documentation (to me) --- so I went with "long lead
to positive" which is what the StampsInClass docs say. Now if this
is wrong, that might explain it.
I'll keep plugging along.... Thanks again.
Rob
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> That circuit at the junction of the 100k and the Coll should
as
you
modulation
photodiode
> -- Tracy
how
1/100th
could
> >Tx,
> >Rob
> >> > > +5--/\/\/\----|
Coll Emit
Gnd
> >> > > 100K | B
> >> > > OpAmp
