Electronic Grenades
Archiver
Hello, list.
I play a game called "airsoft." Essentially, we're a bunch of guys
for whom paintball wasn't realistic enough, so we use fully automatic
BB guns that are indistinguishable from their real-steel counterparts.
One of the great unsolved problems of airsoft is "How to simulate a
grenade or land mine?" Or even a rocket of some kind. The honor
system only goes so far, and fire crackers or other home made
pyrotechnics are not always the best idea.
So, I've had my Basic Stamp book laying around for a while now,
waiting for me to get to around to breaking it out of its blister
pack with its Board of Education. Fresh out of a divorce, I find
that I have time to indulge myself in such tinkering.
My question to the group is this: Is there a cost effective way to
create some kind of electronic gadget (probably based on a Stamp, I
would think?) That could send out a signal of some sort (radio, IR,
sonic?) to another (really really cheap) gadget we could wear on our
person in such a way that the distance could be calculated, and
anybody whose "telltale" was closer than varMaxLethalRadius would
flatline on them or something? I'd like this to be my first Stamp
project, but I wanted to check with more experienced people than I
before I waste a lot of time and money developing a toy like this.
Or is there another way I should go about it that doesn't require a
full fledged micro controller?
Robin
Robin
The only thing I can think of won't be cheap. Use a 433mHz
transmitter/reciver with the Stamp on the "gernade" . Each person wears a
reciever/transmitter pair that is broadcasting a unique ID. When the Stamp
recives the unique ID, it tells the individuals detection device to beep or
blink. To keep cost down you could use a PIC12F675 on the user end. Each
detector would be in the $30-40 range.
We used to play the same game as kids. We called it "BB gun wars" We did use
a plastic bag and paint with a firecracker for gernades. Stupid, but we had
a lot of fun.
Jonathan
www.madlabs.info
Sent: Wednesday, July 23, 2003 11:32 PM
Subject: [noparse][[/noparse]basicstamps] Electronic Grenades
> Hello, list.
> Robin
we didn't have BB guns, we would seek out sand piles at new houses and
find one ripe with soft dirt clods.
> a lot of fun.
the Vamps!
Not sure how they'd survive a throw, but having IR mantraps might be an option.
Some 'bouncy betty' type devices.
Just put a bunch of IR photodiodes and set a trigger.
Doesn't matter if it has a 'special' code. That's part of friendly fire isn't
it!!...weapons aren't prejudiced!!
sb
Date: Thursday, July 24, 2003 7:07 am
Subject: Re: [noparse][[/noparse]basicstamps] Electronic Grenades
> Robin,
> wears a
> the Stamp
> to beep or
> end. Each
> We did use
> but we had
> a lot of fun.
> Jonathan
> www.madlabs.info
> From: "loxley_72401" <loxley_72401@y...>
> > Hello, list.
> automatic> BB guns that are indistinguishable from their real-
> steel counterparts.
> simulate a
> Stamp, I
> on our
> than I
> require a
> > Robin
> Subject and
> http://docs.yahoo.com/info/terms/>
obstructions. But it probably wouldn't work for a thrown "gernade". The code
isn't to protect from "friendly fire", only to make sure that ALL in the
blast zone are targeted and counted as "zapped".
Jonathan
www.madlabs.info
Sent: Thursday, July 24, 2003 8:06 AM
> If you've seen 'BLADE 2', you'll remember them using those UV grenades to
kill the Vamps!
option. Some 'bouncy betty' type devices.
isn't it!!...weapons aren't prejudiced!!
> sb
> From: Jonathan Peakall <jpeakall@m...>
> > Robin,
> > wears a
> > the Stamp
> > to beep or
> > end. Each
> > We did use
> > but we had
> > a lot of fun.
> > Jonathan
> > www.madlabs.info
> > > Hello, list.
> > steel counterparts.
> > simulate a
> > Stamp, I
> > on our
> > than I
> > require a
> > > Robin
> > Subject and
i remembered a post a while back where someone was
asking to do a similar thing for a laser tag type game
with a throwable and reusable "electronic grenade".
anyway, not a lot of info was given (you can search
the archive for "grenade") or follow up on the
project.
off the top of my head i think it could be done w/out
a stamp for less $, but you could certainly use a
stamp and make it much fancier.
a possible non stamp approach:
you could use a pair of '555s on the grenade end, 1 as
a timer and 1 as a pulse emitter (astable mode) hooked
to an infared LED emitter array. when the timer times
out it triggers the "blast" simulated by the IR LEDs
for say 5 seconds driven by the astable '555. the
timer could also be adjustable, perhaps a nice
feature??
on the other end, all of the participants could wear a
set of cheap IR receivers hooked to another '555 which
would upon being hit, would flash some LEDs or maybe
drive a small pager vibrator for user feedback, thus
showing the "hit".
perhaps you could even make it 2 way, if the
participants also wore an IR emitter, and give the
grendade an IR receiver...then you have a claymore!!
there is TONS and TONS of info on the '555 timer,
entire web sites and books devoted to it. the Art of
Electronics has a nice section, radio shack has some
minibooks on the '555 which i found useful.
you should be able to achieve say a 10-25' radius
depending on the LEDs you use. '555s are very cheap
and easy to use with only a couple other components.
some experimenting is probably in order, especially
for how many IR LEDs to use for both emitting and
detecting, and how to mount the device so when thrown
it wont be damaged?? maybe embedded in a tennis
ball????
hope this long reply helps you out.
ross
--- loxley_72401 <loxley_72401@y...> wrote:
> Hello, list.
> bunch of guys
> use fully automatic
> "How to simulate a
> kind. The honor
> home made
> while now,
> of its blister
> divorce, I find
> tinkering.
> effective way to
> based on a Stamp, I
> sort (radio, IR,
> could wear on our
> calculated, and
> my first Stamp
> toy like this.
> doesn't require a
> Robin
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
> greetings,
> project.
<stuff deleted>
Thanks Ross, and everybody else. I shall certainly check the msg
archives. I really didn't think there would have been a similar
project, so I didn't check. [noparse]:)[/noparse]
The reason for doing more than just an IR grenade with IR telltales
is because distance matters... I want to be sure that everybody
within the predetermined "blast radius" is counted out, but people
further away than that should be un affected. It would really bite to
lob a grenade down way down the hall, and have the sensor I was
wearing catch sight of the IR LEDs as they "went off."
I like the idea of ultrasonics as well... get the lurkers behind
cover. [noparse]:)[/noparse]
I'm guessing that if the cost of such a system (grenade costing up to
100 bucks (it is reusable, after all) and the individual telltales
costing up to 20 bucks or so) weren't too high, my fellow airsoft
enthusiasts would go for it. Remember, we spend a few hundred bucks
on guns... and don't get me started on the "fashion aspect" of the
hobby. [noparse]:)[/noparse] Actual quote from our forum...
*paste*
Oh I can see it now, on the runway in gay Pari'
And here comes Naomi wearing a fashionable ensamble by Blackhawk and
various MilSpec contractors. Notice how her boots have been
accessorized with the gleaming gold speed lace loops. Her LBE has had
extra sequins added for that dazzling flair. Imagine how she sparkles
in the midst of a Afghan firefight.
Mike "Rennyfencer" Sisson
The first 8 seconds of this mission are working, we are ahead of the
curve
*end paste*
But I digress. [noparse]:)[/noparse] I saw something in one of the online Nuts and Volts
columns (Robot Eyes in Vol 4) that looked like the right general sort
of thing... it was about addressable sonic sensors that you could
read a list of distances from as their signal reacheds the stamp.
Looks like the way to go if there's a way for a smart grenade to tell
the dumb telltale "okay, YOU are deadm send your flatline audio
tone." I'm thinking it's okay for the grenade to be expensive, if I
can just keep the telltale cost down.
Loxley
Yea, I asked a while back about making a Lazer Tag grenade, but got
only one usefull reply (That suggested 555 timers)..
Now, I've worked out a system that uses 4 555 timers, that has an
adjustable delay before it starts firing, an adjustable lenght of
time while it fires, and pulse the fire using another 555 (Its
adjustable too).
I've yet to try it out (Need to order compenets, but want to get
other compnents for a few other projects)
You can get the circuit from www.dbrweb.co.uk/irgrenade_sys.jpg (38.2
KB).
I am working on a strip board version just now (In Stripboard Magic)
and will post here, if intrested, with the layout (Screen shots)
Hope this help
- Ben
--- In basicstamps@yahoogroups.com, Klutch <klutch66@y...> wrote:
> greetings,
> project.
> feature??
> showing the "hit".
> ball????
> ross
"radiation" grenade?
Use the 555 driving an IR array as they said, but make it's pulses
cumulative on the receiver. The idea is that the 555 sends pulses and the
IR receivers start to count the pulses they receive as long as they are
"exposed" to the grenade.
If your IR receiver receives more than a certain number of pulses, you're
then "dead". Use a pulse counter and an LED bar graph to indicate your
relative "health". As time goes on, and you're not exposed to the source
of radiation, you slowly begin to "regain" your "health"....
Using this model, the person who "throws" it would know to duck down
until it stops being "radio active". Maybe use a piezo sounder to let
people know that the unit is "active". Sort of a descending tone, starts
high... drops low then goes to a "warble" while "radiating" then goes to
a short beep series (so people can find it after the battle!) . Then
after a "recharge time" (5 mins or so to keep people from throwing it
right back at you!), it's ready to be lobbed back at the "enemy"... [noparse]:)[/noparse]
Vern
PS: More a "10,000ft view", no schematics in this post... [noparse]:)[/noparse]
PPSS: Ya know, if Carnivore
(http://www.fbi.gov/hq/lab/carnivore/carnivore.htm) sees these emails,
Ashcroft's goons may be knocking on all our doors demanding to confiscate
our "radiation grenades"!! Long live the E.L.F. (Electron Liberation
Front!) [noparse]:D[/noparse]
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
vern@t... www.txis.com | is up, then we obviously don't need
Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
Ben said:
> Hello,
> adjustable too).
> KB).
> Hope this help
> - Ben
>> greetings,
>> project.
>> feature??
>> showing the "hit".
>> ball????
>> ross
> Ok, here's a thought...Rather than a "blast" grenade, how about a
and the
are
Hrm... now THAT is an interesting idea. It would quite likely flush
them out. Even if they're behind cover, they're still likely to get a
dose... very very interesting. [noparse]:)[/noparse] I can see an easy application for
chemical weapons simulation, too... usually, we just toss smoke
grenades (nota bene: real smoke grenade smoke is toxic in confinded
spaces as we found out). But with IR led's, we can make an area "hot"
or "toxic" or whatever. "Your telltale goes off, you've got until it
flatlines to get your NBC gear on. Yeah, we've got some pretty
serious milsimmers in our bunch. [noparse]:)[/noparse] Thanks for the idea!
Loxley
I'd aim for having a bleep when it it's done radiating. That way the
unsuspecting enemy would stop and wait for the run-down tone to die.
Maybe have some 'fake' bleeps too! Like a quarterback giving fake 'Huts'....
Date: Thursday, July 24, 2003 10:52 am
Subject: Re: [noparse][[/noparse]basicstamps] Re: Electronic Grenades
> and the
> they are
> you'rethen "dead". Use a pulse counter and an LED bar graph to
> indicate your
> sourceof radiation, you slowly begin to "regain" your "health"....
> startshigh... drops low then goes to a "warble" while "radiating"
> then goes to
> Vern
> confiscateour "radiation grenades"!! Long live the E.L.F.
> Ben said:
> > Hello,
> > adjustable too).
> (38.2> KB).
> > Hope this help
> > - Ben
> >> greetings,
> >> project.
> >> feature??
> >> showing the "hit".
> >> ball????
> >> ross
> Subject and
