Debug Display options (Was: Sending Data from QBasic to BS2sx)
I had a similar problem trying to develop a prototype for a company I was
working for. ALT-TABing does work, but it's cumbersome and confusing. I
got around this by purchasing a serial LCD to use for all my "debug"
output. It comes in really handy when you are trying to arbitrate serial
port activity.
Plus, to see the result, you just look over at the device you're working
on which somehow seems more "natural" to me. I'm used to looking over for
status leds or servo positions etc. [noparse]:)[/noparse]
Scott Edwards electronics was the one I bought which I think you can get
through the parallax web site. There are now some other vendors that
offer the same type thing with different size displays. I opted for the
back-lit display and it really is easier to read than the non-lit (I got
one of those for a later project and missed the back lighting dearly!).
Check Nuts and Volts mag for ads (http://www.nutsvolts.com) or parallax
(http://www.parallax.com) or even Scott Edwards (http://www.seetron.com)
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
vern@t... www.txis.com | is up, then we obviously don't need
Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
Newzed@a... said:
> In a message dated 7/23/2003 5:45:57 PM Eastern Standard Time,
> hard-on@t... writes:
>> no, I'm alt-tab'ing between screens. So after I start the Qbasic
>> program running (endless loop), I switch to the BS2sx programmer
>> screen and I can see the bs2sx debug screen, and I've made sure
>> that's it's active by reseting the stamp and seeing pre-serin-loop
>> debugs (which are not in the code I posted) re-apear.
> OK - there is one other possibility. I had this problem using a
> FlashLab77
> with Hyperterminal. On the FlashLab I had to open up the RST line, which
> I
> think is the same as the ATN line on Stamp. Hyperterminal was holding
> the RST
> line low so FlashLab couldn't receive anything. I think I would try
> opening the
> ATN line to see if that helps. One thing you could try before you do
> that is
> turn off the Stamp, start QBasic, switch to the debug screen and then
> turn
> the Stamp on. If you don't see your "startup debugs" then that is the
> problem.
> If you do see them then it must be something else.
> Sid
> [noparse][[/noparse]Non-text portions of this message have been removed]
> Body of the message will be ignored.
port activity.
Vern
> FlashLab77
> I
> the RST
> opening the
> that is
> turn
> problem.
> Sid
this when I started up my qbasic program after the stamp programmer
was open, I got an error saying 'two devices are trying to use the
same port'. So I hooked up a led and told the stamp to light it up
when it got the string of text I was sending from the laptop. The LED
went off, so I guess it was working all along, the debugs just
weren't showing up; probably conflict between qbasic and the stamp
programmer which may occur differently on different computers, mine
is pretty old, and I was running everything from windows 95 (although
the DOS mode bs programmer always has worked from within win95).
Thanks for the help guys.
I was
confusing. I
serial
> port activity.
working
over for
can get
the
(I got
dearly!).
parallax
> Vern
loop
> > FlashLab77
line, which
> > I
holding
> > the RST
try
> > opening the
you do
> > that is
then
> > turn
is the
> > problem.
> > Sid
Subject and
