Receiving data from modem...
When I send an ASCII char(in binary form) from a modem to a BS2, I
don't need to declare ASCII variables in BS2 rite? BS2 automatically
reads the binary data and know that it is an ASCII char? Am I right
about this?
As I will be sending data from my pc thru my modem and then to a
remote modem(this remote modem interfaces with my BS2), Can I make
use of RTS and CTS pin? From the manual, seems like the RTS pin and
DSR pin are connected together. This means they are always in the
receiving mode right?
about this?
a byte. It is 8 bits of binary information.
The BS2 does have a wonderful set of modifiers,
so you can load variables appropriately.
Let's use '0' as an example.
You can send the BS2 a CHR(0) (ie the actual
8-bits of 0). You can send the BS2 an ascii
character "0" (which is REALLY CHR(48)).
If you want to send the BS2 an ascii "0", and
want to BS2 to store a real 0 when it gets it,
you can put it into a string with:
MyStr(3) VAR BYTE ' Declare a 3-byte string
MyVal VAR BYTE ' Declare a single byte
SERIN SerPin, SerBaud, [noparse][[/noparse]STR MyStr\1]
' The above line will put the char "0"
' into MyStr.
' *** OR, you could do ***
SERIN SerPin, SerBaud [noparse][[/noparse]DEC MyVal]
' I believe the above will put the value
' 0 into MyVal
So the short answer is NO, the BS2 does
not 'automatically' know when you are sending
it a char "0" or a byte 0, you have to tell
it in the code how to receive and store what
you want. If you use the 'STR' modifier, it
will stick the bytes as sent into a byte array,
which is typically what you want done with a
string.
2. The DB9 RTS and DSR pins are tied together on
the BOE board so the IDE can detect it has a
BS2 connected to it. The BOE DB9 also has DTR
tied to the BS2 RESET(ATN) pin. This DB9 only
works for TX and RX, really, and even then it
echo's everything recieved on is RX pin back
out its TX pin.
(Note 232 'hardware handshake' standard is to use
RTS/CTS as a 'ready for bytes' handshake,
DCD for 'carrier detect' (the modem is connected)
and DTS/DTR for 'Data Terminal Ready'
handshake. The BS2 use of these signals
is ENTIRELY non-standard.)
If you can code around all these limitations, then
you can connect it to your modem. (I wouldn't use
RTS/CTS with the modem -- but they do support
XON/XOFF 'soft' handshakes, don't they?)
The alternative is to put in a MAX232 (for TTL to 232
and back signal conversion), and install your own DB9
with whatever hardware control pins you need.
automatically
> about this?
> Thanks
