Sine to Square - more info
I forgot to say that the signal I need to convert comes from a variable
reluctance pickup and hence can range form mV to tens of volts.
Is that going to make a big difference to what I am trying to do?
Sent: Tuesday, July 22, 2003 10:29 PM
Subject: [noparse][[/noparse]basicstamps] Sine to Square
> Whats the easiest waht to convert a low frequency sine (10-100hz) to a
square wave? Opamps or a comparator?
> [noparse][[/noparse]Non-text portions of this message have been removed]
>From: "Tim Stockman" <tim.stockman@s...>
One chip that is meant specifically for use with reluctance pickups
is the old LM2917. It is a tachometer IC that can output a voltage
proportional to input frequency. But if you leave off the
"integration" capacitor, it will output a series of pulses at a rate
of twice the sine wave input frequency. Those are pulses that can be
counted by the BASIC Stamp. It is not a symmetrical square wave, if
that is indeed what you need. The hysteresis is about 5 millivolts
at the input, I think.
-- Tracy
