Unused BS2 pins question...
My current project only requires that I use 4 pins on the BS2 as
inputs. These pins are connected to 10K pull-ups, but my question is
should the other unused pins be pulled up also, or is it better to
pull them down to ground? Is there a difference in current
consumption of the BS2, whether unused pins are tied 'high' or 'low'?
Thank you....
Jim D. Martin
Thank you....
Jim D. Martin
lots of sense on TTL logic, where a floating,
unused input makes a really good noise-coupler
into your circuitry and other logic.
On the BS2, you're talking about the input
to a PIC chip. As long as your code ignores
the input values, the chip will also. This
means there won't be any current flow on
a 'floating' pin to worry about, so you
don't need to tie them anywhere.
Note the data pins on the PIC have various
protection diodes on them internally, which
also helps cut down on coupled noise into
the circuit.
--- In basicstamps@yahoogroups.com, "Jim D. Martin" <fw_econo@y...>
is
or 'low'?
> Thank you....
> Jim D. Martin
>Thank you....
>Jim D. Martin
Tie unused pins either high or low, it does not matter which, or have
your program set them as outputs, either high or low. The trouble
with floating inputs is that they will can float to intermediate
levels that make the input buffers draw useless power supply current.
I don't think it ever gets to a level that hurts the Stamp itself,
but it is a big concern if you are trying to conserve battery life.
By pulling the pins up or down or by making them outputs, the input
buffer is brought to a definite level that does not draw power supply
current.
-- Tracy
My only concern with this advice is that as the stamp pins are
*programmable*, you run the risk of a software mistake causing a hardware
failure (i.e. letting out the "magic blue smoke" [noparse]:)[/noparse]
If, for example, you tie all the unused pins to ground, then
inadvertently update the software where it toggles those pins to a
output/hi state, you would have a dead short that could damage/destroy
the chip. (remember Murphy watches for just this type of environment to
exploit! [noparse]:)[/noparse]
I suggest that if you're concerned about the state of the pins (power
draw, static electricity issues, erratic state, etc.) you could use pull
up resistors so a software problem wouldn't cause a direct short in a
worst case scenario... [noparse]:)[/noparse]
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're
Senior Systems Engineer | obviously incompetent so why are we
Texas Information Services | paying you? Of course, if the network
vern@t... www.txis.com | is up, then we obviously don't need
Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
>>Thank you....
>>Jim D. Martin
> current.
> -- Tracy
> Body of the message will be ignored.
or low *through a pullup or pulldown resistor of ~1k*, or make them
outputs, either high or low.". Making them outputs does not take
any hardware (the resistor), but it does take a program instruction.
Using the pullup/down resistor does not require at PBASIC
instruction, because the pins are all inputs by default after the
reset.
-- Tracy
>Vern
>>>Thank you....
>>>Jim D. Martin
>> current.
>> -- Tracy
>Subject and Body of the message will be ignored.
This is a very good question. If you want to ensure that the BASIC
Stamp consumes as little current as possible, make sure all unused I/O
pins are:
1) Set to inputs (default) and externally tied high or low
2) Set to output high or low but not electrically connected to
anything.
It doesn't matter in either case whether or not they are tied or driven
high or low (both states produce the same current consumption.
If, on the other hand, they are set to inputs and left floating (not
electrically connected high or low) they will cause the interpreter chip
to consume current erratically (in a non-deterministic fashion).
--Jeff Martin
Engineering Manager
> From: Jim D. Martin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aWuz-_9GcRj7gjhwgHFqhraX9E_czLhZMyPWpajK6eUWN3JjXKbz5TAFbp-fD0x7LdX0wqg0OPRbjrTl]fw_econo@y...[/url
> Sent: Tuesday, July 22, 2003 7:56 AM
> Subject: [noparse][[/noparse]basicstamps] Unused BS2 pins question...
> Thank you....
> Jim D. Martin
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
