Serial Interface
Archiver
Hello all,
After asking some questions few days ago about serial connection I have
already over come most of my problems with Max232 chip. The only occurred
problem is that when I receive massages with the BS2 like that:
SERIN Rpin, BMode,40000,NoConnection,[noparse][[/noparse]STR SerString\7]
when baud rate is set to 84 I get the characters that I expect not exactly
in the write position, Example:
The massage coming in is "CONNECT"
I Get in memory the next thing -> |D|A|C|O|N|N|E|C|T|
The letters D and A in the place of SerString(0) and SerString(1) where not
expected at all. It seems they always there when I am using serin.
I tried to change the rate to lower baud (2400) but the problem still
exists. Another occurred thing is when I print this string to debug window:
DEBUG STR SerString,CR
I get only the right characters from the third place in the array and on
like you would expect.
Is anyone bumped into this problem ? Am I doing something wrong ?
My Home Telephone Number is: +972-3-6021184
My Fax Number is: +972-9-9587360
My Home Telephone Number is: +972-56-546756
Azriel Roy
Azriel Roy
returns and line feeds...
Check the value f the two characters, if they are ASCII 10 or 13 decimal (I
think, could be $10 and $13), then this is the case.
Steve
Sent: Tuesday, July 22, 2003 2:30 PM
Subject: [noparse][[/noparse]basicstamps] Serial Interface
> Hello all,
not
window:
> Azriel Roy
You should know if you send ctrl-A (CHR(10))
and ctrl-D (CHR(13)) to the DEBUG window,
you'll get a line-feed for one, and a 'start of
line' for the other.
I assume the app that is putting out the
'CONNECT' string is:
printf ('\nCONNECT');
On a PC, the '\n' will give you the
Ctrl-A + Ctrl-D combination.
If you really want to know what's in a
string, do:
for i = 1 to 9
DEBUG DEC SerString(I)
NEXT
--- In basicstamps@yahoogroups.com, "Steve Ziuchkovski"
<zman97211@y...> wrote:
> Quite possibly the two characters you're receiving first are
carriage
decimal (I
> Steve
> From: "Roy Azriel" <royaz@z...>
> > Hello all,
I have
occurred
not exactly
where
> not
still
debug
> window:
and on
> > Azriel Roy
Subject and
