Tlc2543 — Parallax Forums
Tlc2543
edited 2003-08-25 00:04 in General Discussion
Hi All,
I am getting odd results from a TLC2543. I can only get figures between 3000
or so to 4095. I have tried it on a 2SX and a 2P, same results. I am using
the code from Tracy's web site.
Jonathan
    edited 2003-07-21 21:58
    In a message dated 7/21/2003 4:49:28 PM Eastern Standard Time,
    jpeakall@m... writes:
    > 3000
    Do you have Ref+ tied to Vcc and Ref- tied to Vss?
    Sid Weaver
    W4EKQ
    Port Richey, FL
    edited 2003-07-21 22:07
    Ref+ is tied to Vdd, ref- to Vss.
    Jonathan
    Sent: Monday, July 21, 2003 1:58 PM
    Subject: Re: [noparse][[/noparse]basicstamps] TLC2543
    > > 3000
    using
    > Sid Weaver
    > W4EKQ
    > Port Richey, FL
    edited 2003-07-21 22:17
    In a message dated 7/21/2003 5:10:05 PM Eastern Standard Time,
    OK, Jonathan. I have used the TLC for a long time with great success. Since
    I can't see the setup you have I can only ask dum questions.
    Are you trying to input more that 5 VDC?
    Sid
    edited 2003-07-21 22:40
    Sid,
    No, I'm using the Vdd off the BOE for both Vref and supply. The schematic on
    Tracy's site shows no other components, and neither does the data sheet. I
    have Vss to p13 and p10 pf the TLC, Vdd to 20 and 14, pins 15-18 are
    coneccted to the Stamp pins 1-4 and that is it.
    Could it be that I need to be waiting for the end of conversion flag?
    Tracy's site says BS2 do not need to as they are too slow, but what about
    the 2SX and 2P? Perhaps they are fast enough to need this. Any idea how I
    would check?
    Jonathan
    Sent: Monday, July 21, 2003 2:17 PM
    Since
    > Sid
    edited 2003-07-21 23:58
    It should not be necessary to check the EOC flag when using any
    Stamp. The '2543 conversion time is less than 10 microseconds.
    Have the program run through channels 11, 12 and 13 for test
    purposes. The result should be count=2048, Vref/2, count=0 and
    count=4095. That is a good interface test.
    The example at <http://www.emesys.com/OWL2face.htm> uses connections
    to stamp pins p12 to p15, while you are using p1 to p4. Be sure pins
    are right! It's awfully easy to let a typo slip in, in particular
    with respect to the sense of sdo and sdi. Sid pointed out a typo on
    my web page a long time ago, but I hope I corrected that! (Thanks
    Sid!)
    With a 5.00 volt reference, the conversion from counts to millivolts
    is a little different.
    result = result ** 14464 + result
    or conditional on the flag, like in the example
    result = adv * result ** 14464 + result
    or PBASIC 2.5
    if adv then
    millivolts=result ** 14464 + result
    else
    millivolts=result
    endif
    The conversion factor is 5000/4096 = 1.2207
    -- Tracy
    >Sid,
    >would check?
    >Thanks,
    >Jonathan
    >From: <Newzed@a...>
    >Since
    >> Sid
    >Subject and Body of the message will be ignored.
    edited 2003-07-22 00:08
    Tracy,
    It seems to have been a bum chip. I tried another and it works fine. Odd
    thing though, any input that isn't connected to Vss via a pulldown resistor
    "follows" the input that I am testing by about 1/2. Meaning, an input that
    doens't have a pulldown will show 500 if I have 1000 on an input I am
    testing. Hope that makes sense.
    Thanks for the correction for a 5V Vref!
    Jonathan
    Sent: Monday, July 21, 2003 3:58 PM
    > Sid!)
    > or PBASIC 2.5
    > if adv then
    > else
    > millivolts=result
    > endif
    > -- Tracy
    > >Sid,
    on
    I
    > >would check?
    > >Thanks,
    > >Jonathan
    > >From: <Newzed@a...>
    > >Since
    > >> Sid
    and
    edited 2003-08-24 21:41
    Hi All,
    I just took a project off the breadboard and on to a PCB. I am getting very
    odd results from a TLC2543. At about 3.6VDC into one of the ADC inputs, the
    chip outputs around 1000. Below that it goes to 0. Above that it suddenly
    jumps to 4096. All of the channels act the same. I have a .1 and .01uF caps
    on the power leads, and the Vref pin is connected to the VCC pin. I have
    tried using another chip, with the same results. I have tried Tracy's code,
    and got the same results.
    Any ideas?
    Jonathan
    www.madlabs.info
    edited 2003-08-24 21:50
    In a message dated 8/24/2003 4:43:13 PM Eastern Standard Time,
    Can I see your code, Jonathan.
    Sid
    edited 2003-08-24 22:17
    Sid,
    Below are 2 snippets that give the same results. I am using a 2p40, and the
    pins are connected as follows-
    I/O pin 12 to pin 15, chip select
    I/O pin 13 to pin 16, data out
    I/O pin 14 to pin 17, data in
    I/O pin 15 to pin 18, I/O clock
    Snippet one:
    '{$STAMP BS2p}
    '{$PBASIC 2.5}
    ADch VAR Nib ' selects AD channel 0-10
    ADV VAR Bit ' selects result as 0:count; 1:millivolt
    result VAR Word ' result, 12 bit A/D conversion
    ADv=1 ' Puts the ADC in millivot mode, 0 puts it in raw
    count mode
    Main:
    ADCh =1 ' specify one of 11 input channels
    GOSUB ADread ' get millivOLT data FRom that channel
    PAUSE 1000 ' demo delay
    'DEBUG HOME ' repeat the demo, refreshes the debug screen
    GOTO MAIN
    ADrEAD: ' entry point to give result as millivolts
    MAINIO
    LOW 12 ' select chip
    PAUSE 5 ' Settling delay
    SHIFTOUT 14,15,MSBFIRST,[noparse][[/noparse]ADch<<8\12] ' mode, left justify ADch
    SHIFTIN 13,15,MSBPRE,[noparse][[/noparse]result\12] ' get result, 12 bits
    resulT = aDv * rESULt ** 14464 + result ' Does the integer math conversion
    DEBUG DEC ADch,": ",DEC result,REP 32\5,CR ' display results
    'ADCH=14 ' THIS command puts the ADC into sleep mode
    'SHIFTOUT 14,18,MSBFIRST,[noparse][[/noparse]ADch<<8\12] ' Send sleep command
    HIGH 12 ' deselect chip
    RETURN
    Here is snippet 2:
    '{$STAMP BS2p}
    ' ADread subroutine for OWL2c.
    ' On command, returns 12 bit digital data from one of 11 analog channels.
    ' The value of ADch from 0 to 10 selects external analog inputs.
    ' ADch=14 puts the converter into its sleep mode.
    ' converter has 5.120 volt reference, for 1.25 mV per bit
    sclk CON 15 ' SPI clock out from BS2 to AD2543
    sdo CON 14 ' SPI data out from BS2 to AD2543 sdi
    sdi CON 13 ' SPI data in from AD2543 sdo to BS2
    ADcs CON 12 ' AD2543 chip select, active low
    ADv VAR Bit ' selects result as 0:count; 1:millivolt
    demo: ' to show off the subroutine below.
    FOR ADch =0 TO 10 ' specify one of 11 input channels
    GOSUB ADread ' get millivolt data from that channel
    NEXT
    PAUSE 100 ' demo delay
    GOTO demo
    ADread: ' entry point to give result as millivolts
    ADv=1 ' in millivolts 0-5120
    ADread0: ' enter here for result as raw count 0-4095
    LOW ADcs ' select chip
    PAUSE 5 ' settling delay
    SHIFTOUT sdo,sclk,MSBFIRST,[noparse][[/noparse]ADch<<8\12] ' mode, left justify ADch
    IF ADch=14 THEN ADexit ' ADch=14 puts it to sleep
    SHIFTIN sdi,sclk,MSBPRE,[noparse][[/noparse]result\12] ' get result, 12 bits
    ADexit: ' finish up
    HIGH ADcs ' deselect chip
    result = 64*ADv+256*/result ' if ADv=0, result=raw count
    ' if ADv=1, convert count->mV
    ' 1.25 millivolts per bit
    ADv=0 ' default is raw count, not millivolts
    RETURN
    edited 2003-08-24 22:37
    Jonathan, do you have pin 13 tied to Vss and pin 14 tied to Vdd ?
    Sid
    edited 2003-08-24 22:45
    In a message dated 8/24/2003 5:17:36 PM Eastern Standard Time,
    Something else, Jonathan. See below.
    > MAINIO
    Why are you using MSBPRE instead of MSBFIRST ?
    > conversion
    edited 2003-08-24 22:59
    Remember, breadboards have a lot of natural decoupling. Do you have a
    decoupling capacitor very near the chip?
    Al Williams
    AWC
    * Easy RS-232 Prototyping
    http://www.al-williams.com/awce/rs1.htm
    > From: Jonathan Peakall [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G4k1xslw10gAe0sgLRuRIUlYI6BHk0AOu2YUq_bDx9MbQd1CA4tQf-IUVK1EtBOnnw4doiWOIYAd0U4Z]jpeakall@m...[/url
    > Sent: Sunday, August 24, 2003 3:42 PM
    > Subject: [noparse][[/noparse]basicstamps] TLC2543
    > Hi All,
    > am getting very odd results from a TLC2543. At about 3.6VDC
    > into one of the ADC inputs, the chip outputs around 1000.
    > Below that it goes to 0. Above that it suddenly jumps to
    > caps on the power leads, and the Vref pin is connected to the
    > VCC pin. I have tried using another chip, with the same
    > results. I have tried Tracy's code, and got the same results.
    > Any ideas?
    > Jonathan
    > www.madlabs.info
    edited 2003-08-24 23:01
    NEXT
    GOTO demo
    You say "Gosub ADread"
    > ADexit: ' finish up
    return
    Routine never sees "ADv = 0" Upon return, goes back to demo part, then
    gosubs ADread, where ADv is reset to 1.
    Sid
    edited 2003-08-24 23:59
    Sid,
    Duh, I forgot! One quick jumper on the bottom of the board, and we are in
    business! Can't believe I forgot that and didn't spot it! Many thanks, it
    works fine now.
    Jonathan
    www.madlabs.info
    Sent: Sunday, August 24, 2003 2:37 PM
    > Sid
    In a message dated 8/24/2003 7:01:09 PM Eastern Standard Time,
    > works fine now.
    It's always something simple, Jonathan. Have fun !
