communication between two stamps
I just wanted to know how I would go about getting a stamp to loop
through a series of SERIN's - say on four pins - and then to branch
when one of those pins received data.
Paul
Paul
When the BS2 is doing 'SERIN' on one pin,
it will ignore signals being recieved
on the next pin, until the one SERIN is
completed.
What you could do is use the 'FPIN' option.
When the SERIN command runs in the BS2, it
will make the FPIN signal an output. You
can send this to the remote port as an
'CTS' signal. When the remote port recieves
this, it should send the byte, which the
BS2 is now ready to receive. See the
BS2 Programming Manual 2.0c, pg 289.
Combine this with a timeout, so if the
remote device does not have any data
the BS2 will not hang, and you can now
sample 4 ports. The data will 'sit'
in the remote device until the BS2
signals it is ready to receive it.
This does take 8 pins (4 rx, and 4 FPIN)
but it gets around the SERIN limitation
of the BS2.
So:
LoopTop:
SERIN P0\P1, Baud1, Skip1, 500, [noparse][[/noparse]MyByte1]
GOSUB Byte1Read
Skip1:
SERIN P2\P3, Baud1, Skip2, 500, [noparse][[/noparse]MyByte2]
GOSUB Byte2Read
Skip2:
SERIN P4\P5, Baud1, Skip3, 500, [noparse][[/noparse]MyByte3]
GOSUB Byte3Read
Skip3:
SERIN P6\P7, Baud1, Skip4, 500, [noparse][[/noparse]MyByte1]
GOSUB Byte4Read
Skip4:
GOTO LoopTop
END
Note you WILL have to have some kind of
RS232 driver on the 'FPIN' signals, if
you are talking to a PC, anyway.
Also, turn on Hardware Handshake on the
PC.
--- In basicstamps@yahoogroups.com, "justforgoyourmove" <pjw24@c...>
> Thanks
> Paul
after the time because the compiler is complaining that it expected
a label there?
Thanks - you've been very helpful
Paul
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> There is a problem with this approach.
> completed.
> of the BS2.
> So:
> LoopTop:
> GOSUB Byte1Read
> Skip1:
> GOSUB Byte2Read
> Skip2:
> GOSUB Byte3Read
> Skip3:
> GOSUB Byte4Read
> Skip4:
> GOTO LoopTop
> END
> PC.
<pjw24@c...>
loop
branch
> > Thanks
> > Paul
post is compileable and runnable. Just this
once, I didn't check it through the compiler,
sigh.
wrote:
> In your sample code should the label to branch to on time out come
> a label there?
> Paul
> > completed.
> > of the BS2.
> > So:
> > LoopTop:
> > GOSUB Byte1Read
> > Skip1:
> > GOSUB Byte2Read
> > Skip2:
> > GOSUB Byte3Read
> > Skip3:
> > GOSUB Byte4Read
> > Skip4:
> > GOTO LoopTop
> > END
> > PC.
> <pjw24@c...>
> loop
> branch
> > > Thanks
> > > Paul
