newbie questions about transistors
I'm putting a transistor on my prototype board to replace a reed relay
that's currently on it. I thought all that was necessary, was to apply
an output pin to the 'base' of the transistor, grounded at the
emitter, and then there were would be a path from the collector to the
emitter.
Well, this works, but ONLY when I put a resistor inline between the
output pin and the base. Without the resistor, the load current
that is allowed through the transistor is very weak, and 'pulses'
instead of remaining steady. I see now, that lots of the web-based
tutorials on transistors say you have to have that resistor.....I just
didn't read carefully enough before.
Will a resistor like that ALWAYS be necessary, or are there some
exceptions, based on the differences in voltage between the control
current and the load current? Can anyone explain why the resistor is
needed?
--Alex
emitter.
needed?
--Alex
the transistor base.
Assuming that you want to limit to 10 ma and that the High voltage of your Stamp
pin at this current is 4V, then
(4-0.7)/10 = 0.33 Ko or 330 ohms .
If the current flowing through the transistor is weak without resistor is
because the base shorts the BS to 0.7V.
Stop it, it can destroy the BS pin circuit.
Regards
ECO
Sent: Saturday, July 19, 2003 3:06 PM
Subject: [noparse][[/noparse]basicstamps] newbie questions about transistors
> emitter.
> needed?
> Thanks,
> --Alex
Yes, the resistor is necessary. It prevents too much current flowing from
the pin, and thus prevents the voltage from dropping too low, making the
erratic behavior you saw.
Doing it without the resistor is a sure way to burn out the pin.
Jonathan
www.madlabs.info
Sent: Saturday, July 19, 2003 6:06 AM
> emitter.
> needed?
> Thanks,
> --Alex
and I managed to correct it before ruining the Stamp.
Thanks again,
--Alex
--- In basicstamps@yahoogroups.com, "Jonathan Peakall" <jpeakall@m...>
wrote:
> Alex,
from
the
> Jonathan
> www.madlabs.info
> From: "atl_guy1138" <atl_guy1138@y...>
relay
apply
the
> > emitter.
the
just
control
is
> > needed?
> > Thanks,
> > --Alex
Subject and
A transistor is a current-switching device.
A 'small' amount of current into the Base,
allows a larger amount of current to flow
from the Collector to the Emitter. Yes, it
does have to have a larger voltage on the
base than on the emitter for this to happen.
Thus the purpose of the 10 Kohm or so Base
resistor is to limit the amount of current
from the BS2 to the Base. This protects
both the BS2 and the transistor, which also
has a limit on how much current can pass
through it without damage. So yes, you
always need this resistor.
Of course, you also need a resistor in the
Collector circuit, to limit the amount of
current from Collector to Emitter in the
transistor.
--- In basicstamps@yahoogroups.com, "atl_guy1138" <atl_guy1138@y...>
relay
apply
the
> emitter.
just
is
> needed?
> Thanks,
> --Alex
