a little assistance — Parallax Forums
a little assistance
edited 2003-07-20 18:26 in General Discussion
Hi all!
Here is a program that I have running on my bot for collision avoidance.
The problenm I have with it is that the halls in the school where I
will be using this are bad to echo. The three sonars ping sequentially
about 150ms apart and from what I can tell, the sonars are picking up
the echoes from each other and getting false triggering. This makes the
bot erratic when traversing the halls.
Example:
scenario 1
left sonar fires and gets satisfied (recieves an echo)
center sonar fires and gets an echo but it may be the ping from the left
sonar that was echoing down the hall so it thinks there is an obstacle
in close range. Bot puts on the brakes. . .
scenario 2
center sonar fires and determines there is nothing in the way so the
right sonar fires and recieves an echo which may be the echo from center
echoing back from down the hall and it thinks there is a wall or
obstacle on the right so it veers left. There was no obstacle on the right.
Following is the entire code for the program.
Anyone who can assist or help me write it to be more stable, or just
give suggestions, I would appreciate it!
Doug Simpson
Code follows. . .
'Triple Sonar, Dual Motor Robot Vision and Guidance System
'For Basic Stamp 2sx only.
'Forward motor control only at this time. Strictly collision avoidance.
'No other functions at this time
'declaration of constants
pingl con 15 'Sets ping output left on pin 15
pingc con 14 'Sets ping output center on pin 14
pingr con 13 'Sets ping output right on pin13
retl con 10 'Sets echo input left on pin 10
retc con 9 'Sets echo input center on pin 9
retr con 8 'Sets echo input right on pin 8
ena con 11 'Sets output to enable (power to sonars) on 11
serv con 12 'Sets servo output on pin 12
ir con 7 'Sets infrared detect input on pin 7
timel var word 'variable for the rctime on left sonar
timec var word 'variable for the rctime on center sonar
timer var word 'variable for the rctime on right sonar
inchesl var byte 'variable for inches left
inchesc var byte 'variable for inches canter
inchesr var byte 'variable for inches right
inchl var byte 'variable for inches left for direction sensing
inchr var byte 'variable for inches right for direction sensing
vector var word 'variable for the location of the sonar servo
check var byte 'variable for
vcheck var byte 'variable for
stiml var word 'variable for directional determination
stimr var word 'variable for directional determination
stimc var word 'variable for collision avoidance
inchc var byte 'converted inches for collision avoidance
rot var word 'rotational variable
rot = 500 'sets duration of rotation - 500 is roughly 1/2 second
vector = 1800 'sets the servo to center DO NOT CHANGE
start:
output ena
output pingl
output pingc
output pingr
output serv
input retl
input retc
input retr
input ir
low pingl 'turn pingl off
low pingc 'turn pingc off
low pingr 'turn pingr off
high ena 'high turns off power to the sonar modules
gosub center 'jump to servo center routine
tping:
low ena 'turn power on
pause 5 'wait a tad
high pingl 'execute a ping
pulsout 0,1500 'wait 1.2ms (dummy line)
rctime retl,0,timel 'now, wait for echo pulse
timel = timel*2
inchesl = timel/375+11 'convert time in microseconds to inches
'could be done just on the timel, timec and timer data but
'easier to set the distances in inches than miliseconds
low pingl 'turn ping off
pause 50
high pingc 'same as above only on center sonar
pulsout 0,1500 'starts the rctime timer in the Stamp
rctime retc,0,timec 'to get the time in microseconds
timec = timec*2
inchesc = timec/375+11 'do some math to determine inches (approximate)
low pingc 'turn ping off
pause 50
high pingr 'same as above only on right sonar
pulsout 0,1500
rctime retr,0,timer
timer = timer*2
inchesr = timer/375+11
low pingr
high ena 'turn power off
pause 150 'wait a bit 'sonars must be powered off between pings and
'this delay assures ample time to discharge the
'filters on the sonar modules
display:
if inchesc <60 then sonar 'if inches on center are less than 60 then jump to
label sonar
if inchesc >60 then free 'if inches on center are greater than 60 then jump to
label free
sonar:
low 1:low 2:low 3:low 4 'stop motors
pause 2000
vector = 2700 'sets servo vector for directional determination DO NOT CHANGE
gosub seek 'jump to label seek
free:
'debug dec inchesl, " inches left ",dec inchesc, " inches center ",dec inchesr,
" inches right ",cr
if inchesl >50 and inchesr >50 then forward 'no errors
if inchesl <50 and inchesr >50 then veerr 'something close on left - veer right
if inchesl >50 and inchesr <50 then veerl 'something close on right - veer left
if inchesl <50 and inchesr <50 then sonar 'something close on both - examine
with servo seek
'goto tping 'ping again (unneeded line - left for revision history)
seek: 'routine to determine direction of least obstacles
low ena 'extra ping to make sure the <40 on center is actually an inanimate
object
pause 5 'and not a person or other moving object
high pingc
pulsout 0,1500
rctime retc,0,stimc
stimc = stimc*2
inchc = stimc/375+11
low pingc
high ena
''debug dec inchesc, " inches ",cr
pause 200
if inchc >60 then tping 'if center obstacle is cleared, continue on forward -
if not, determine
'path of least obstacles
vector = 2700 'servo vector right to ping for obstacle DO NOT CHANGE
for vcheck = 1 to 50 'DO NOT CHANGE
pulsout serv,vector 'DO NOT CHANGE
pause 20 'DO NOT CHANGE
next 'DO NOT CHANGE
low ena 'ping for obstacle
pause 5
high pingc
pulsout 0,1500
rctime retc,0,stimr
stimr = stimr*2
inchr = stimr/375+11
low pingc
high ena
'debug dec inchesr, " inches right ",cr
pause 150
vector = 700 'servo vector left to ping for obstacle DO NOT CHANGE
next 'DO NOT CHANGE
pause 5
high pingc
pulsout 0,1500
rctime retc,0,stiml
stiml = stiml*2
inchl = stiml/375+11
low pingc
high ena
'debug dec inchesl, " inches left ",cr
pause 150
center: 'Center servo centering routine
vector = 1650 'DO NOT CHANGE
next 'DO NOT CHANGE
if inchl < inchr then rotr 'if obstacle is closer on the left, then rotate right
if inchr < inchl then rotl 'if obstacle is closer on the right, then rotate left
rotr:
'debug " rotate right ",cr,cr
high 1: low 2:low 3:low 4 'Turns on left motor forward to rotate right
pause rot 'sets the rotate -on- delay
goto rotf
rotl:
'debug " rotate left ",cr,cr
low 1:low 2:low 3:high 4 'Turns on right motor forward to rotate left
pause rot
goto rotf
rotf:
low 1:low 2:low 3:low 4 'turns off motors
pause 500 'wait a bit for coastdown (no braking implemented yet)
return
forward: 'run motors forward
high 1:high 4
'debug " forward ",cr
goto tping 'return to start of main routine
veerr: 'run left forward motor only
high 1:low 4
'debug " veerr ",cr
goto tping
veerl: 'run right forward motor only
'debug " veerl ",cr
low 1:high 4
goto tping
    edited 2003-07-19 06:50
    I'm not too knowledgeable here but I'll give my 2 cents anyway, :-) 150
    seconds apart may be far to close together for the environment (hallway is
    an echo chamber) and the speed (slow) which a robot would normally want to
    navigate in a hallway presumably with human pedestrian traffic. You could
    get by with fewer pings with built in pauses in your code after each ping
    command. If you can't control the ping rate, would it be feasible to turn
    the sonar on and off to accomplish this? Ask the manufacturer if there is a
    resistor or cap you can place somewhere to reduce the ping rate(simple
    hardware fix unless its super miniaturized). Could you desensitize your
    "ears" with a sort of earmuff, how about giving your "ears" external sound
    absorbing tubes, giving them directional filtering?
    From: Doug Simpson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RR4bL1_57BBrEBpJ34-Xsa39mPPilYoCjHRGdQXDuvZxTUF863kMTjQDFVQ6T12bcO9eYetqQIzZ]veewee77@a...[/url
    Sent: Saturday, July 19, 2003 1:18 AM
    Subject: [noparse][[/noparse]basicstamps] a little assistance
    Hi all!
    Example:
    scenario 1
    scenario 2
    Doug Simpson
    Code follows. . .
    start:
    output ena
    output pingl
    output pingc
    output pingr
    output serv
    input retl
    input retc
    input retr
    input ir
    tping:
    pause 5 'wait a tad
    timel = timel*2
    pause 50
    timec = timec*2
    pause 50
    pulsout 0,1500
    rctime retr,0,timer
    timer = timer*2
    low pingr
    display:
    label sonar
    to label free
    sonar:
    pause 2000
    CHANGE
    free:
    right
    left
    examine with servo seek
    inanimate object
    high pingc
    pulsout 0,1500
    rctime retc,0,stimc
    stimc = stimc*2
    low pingc
    high ena
    pause 200
    forward - if not, determine
    next 'DO NOT CHANGE
    pause 5
    high pingc
    pulsout 0,1500
    rctime retc,0,stimr
    stimr = stimr*2
    low pingc
    high ena
    pause 150
    next 'DO NOT CHANGE
    pause 5
    high pingc
    pulsout 0,1500
    rctime retc,0,stiml
    stiml = stiml*2
    low pingc
    high ena
    pause 150
    next 'DO NOT CHANGE
    right
    left
    rotr:
    goto rotf
    rotl:
    pause rot
    goto rotf
    rotf:
    return
    high 1:high 4
    high 1:low 4
    'debug " veerr ",cr
    goto tping
    'debug " veerl ",cr
    low 1:high 4
    goto tping
    edited 2003-07-19 13:43
    An obvious solution: delay more than 50 mSec between
    different 'ping's. Clearly the echo-ness of your
    hallway means you need more time to let the
    echo's die. Try 100 mSec, or 200 mSec and
    see what happens.
    --- In basicstamps@yahoogroups.com, Doug Simpson <veewee77@a...>
    wrote:
    > Hi all!
    avoidance.
    I
    sequentially
    up
    makes the
    > Example:
    > scenario 1
    left
    obstacle
    > scenario 2
    the
    center
    the right.
    just
    > Thanks
    > Doug Simpson
    > Code follows. . .
    avoidance.
    15
    pin 14
    pin13
    10
    pin 9
    8
    to sonars) on 11
    on pin 7
    left sonar
    center sonar
    right sonar
    direction sensing
    the sonar servo
    determination
    determination
    avoidance
    collision avoidance
    CHANGE
    > start:
    > output ena
    > output pingl
    > output pingc
    > output pingr
    > output serv
    > input retl
    > input retc
    > input retr
    > input ir
    sonar modules
    > tping:
    > pause 5 'wait a tad
    > timel = timel*2
    to inches
    > pause 50
    sonar
    the Stamp
    > timec = timec*2
    > pause 50
    sonar
    > pulsout 0,1500
    > rctime retr,0,timer
    > timer = timer*2
    > low pingr
    > display:
    then jump to label sonar
    60 then jump to label free
    > sonar:
    > pause 2000
    > free:
    center ",dec inchesr, " inches right ",cr
    close on both - examine with servo seek
    <40 on center is actually an inanimate object
    moving object
    > high pingc
    > pulsout 0,1500
    > rctime retc,0,stimc
    > stimc = stimc*2
    > low pingc
    > high ena
    > pause 200
    cleared, continue on forward - if not, determine
    > next 'DO NOT CHANGE
    > pause 5
    > high pingc
    > pulsout 0,1500
    > rctime retc,0,stimr
    > stimr = stimr*2
    > low pingc
    > high ena
    > pause 150
    > next 'DO NOT CHANGE
    > pause 5
    > high pingc
    > pulsout 0,1500
    > rctime retc,0,stiml
    > stiml = stiml*2
    > low pingc
    > high ena
    > pause 150
    routine
    > next 'DO NOT CHANGE
    then rotate right
    then rotate left
    > rotr:
    rotate right
    > goto rotf
    > rotl:
    rotate left
    > pause rot
    > goto rotf
    > rotf:
    > return
    > high 1:high 4
    routine
    > high 1:low 4
    > 'debug " veerr ",cr
    > goto tping
    > 'debug " veerl ",cr
    > low 1:high 4
    > goto tping
    edited 2003-07-19 23:10
    This seems like an easy solution however this bot is as big as an
    electric wheelchair and moves at a better than a fast walk pace and the
    more delay in object detection the more likely it is to run over something.
    Thanks for the input, though. . .
    >see what happens.
    >wrote:
    >>Hi all!
    >avoidance.
    >I
    >sequentially
    >up
    >makes the
    >>Example:
    >>scenario 1
    >left
    >obstacle
    >>scenario 2
    >the
    >center
    >the right.
    >just
    >>Thanks
    >>Doug Simpson
    >>Code follows. . .
    >avoidance.
    >15
    >pin 14
    >pin13
    >10
    >pin 9
    >8
    >to sonars) on 11
    >on pin 7
    >left sonar
    >center sonar
    >right sonar
    >direction sensing
    >the sonar servo
    >determination
    >determination
    >avoidance
    >collision avoidance
    >CHANGE
    >>start:
    >>output ena
    >>output pingl
    >>output pingc
    >>output pingr
    >>output serv
    >>input retl
    >>input retc
    >>input retr
    >>input ir
    >sonar modules
    >>tping:
    >>pause 5 'wait a tad
    >>timel = timel*2
    >to inches
    >>pause 50
    >sonar
    >the Stamp
    >>timec = timec*2
    >>pause 50
    >sonar
    >>pulsout 0,1500
    >>rctime retr,0,timer
    >>timer = timer*2
    >>low pingr
    >>display:
    >>sonar:
    >>pause 2000
    >>free:
    >moving object
    >>high pingc
    >>pulsout 0,1500
    >>rctime retc,0,stimc
    >>stimc = stimc*2
    >>low pingc
    >>high ena
    >>pause 200
    >>next 'DO NOT CHANGE
    >>pause 5
    >>high pingc
    >>pulsout 0,1500
    >>rctime retc,0,stimr
    >>stimr = stimr*2
    >>low pingc
    >>high ena
    >>pause 150
    >>next 'DO NOT CHANGE
    >>pause 5
    >>high pingc
    >>pulsout 0,1500
    >>rctime retc,0,stiml
    >>stiml = stiml*2
    >>low pingc
    >>high ena
    >>pause 150
    >routine
    >>next 'DO NOT CHANGE
    >then rotate right
    >then rotate left
    >>rotr:
    >rotate right
    >>goto rotf
    >>rotl:
    >rotate left
    >>pause rot
    >>goto rotf
    >>rotf:
    >>return
    >>high 1:high 4
    >routine
    >>high 1:low 4
    >>'debug " veerr ",cr
    >>goto tping
    >>'debug " veerl ",cr
    >>low 1:high 4
    >>goto tping
    >from the same email address that you subscribed. Text in the Subject and Body
    edited 2003-07-19 23:15
    Thanks for the input.
    This must be as close to real-time detection as possible since the bot
    moves at a better than a fast walk pace. The sooner it detects
    obstacles, the sooner it will be able to decide not to run over them.
    ds
    >From: Doug Simpson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4lBg9MuGRr66hU-_awAKM4cp_rOLcRYYNoZ_VJdp9quknLfp_k0SHoxhTQGoMNwqYGqgUCPzGUnAZ-x42MY]veewee77@a...[/url
    >Hi all!
    >Example:
    >scenario 1
    >scenario 2
    >Thanks
    >Doug Simpson
    >Code follows. . .
    >start:
    >output ena
    >output pingl
    >output pingc
    >output pingr
    >output serv
    >input retl
    >input retc
    >input retr
    >input ir
    >tping:
    >pause 5 'wait a tad
    >timel = timel*2
    >pause 50
    >timec = timec*2
    >pause 50
    >pulsout 0,1500
    >rctime retr,0,timer
    >timer = timer*2
    >low pingr
    >display:
    >label sonar
    >to label free
    >sonar:
    >pause 2000
    >CHANGE
    >free:
    >right
    >left
    >inanimate object
    >high pingc
    >pulsout 0,1500
    >rctime retc,0,stimc
    >stimc = stimc*2
    >low pingc
    >high ena
    >pause 200
    >next 'DO NOT CHANGE
    >pause 5
    >high pingc
    >pulsout 0,1500
    >rctime retc,0,stimr
    >stimr = stimr*2
    >low pingc
    >high ena
    >pause 150
    >next 'DO NOT CHANGE
    >pause 5
    >high pingc
    >pulsout 0,1500
    >rctime retc,0,stiml
    >stiml = stiml*2
    >low pingc
    >high ena
    >pause 150
    >next 'DO NOT CHANGE
    >right
    >left
    >rotr:
    >goto rotf
    >rotl:
    >pause rot
    >goto rotf
    >rotf:
    >return
    >high 1:high 4
    >high 1:low 4
    >'debug " veerr ",cr
    >goto tping
    >'debug " veerl ",cr
    >low 1:high 4
    >goto tping
    edited 2003-07-19 23:18
    Would it be possible to stagger the ping frequency? I don't know if you
    have the ability to change the ping *tone* to something different, i.e.
    Left sonar ping freq = 45khz
    center sonar ping freq= 55khz
    right sonar ping freq = 65khz
    Or maybe change the order of the ping polling to Right side, then left
    side then center then small pause, repeat.
    Seems the best way would be to isolate the sonar modules in some way.
    Maybe send out a different waveform with each one? (r=square c=triangle
    l=sawtooth?) I'm just "typing out loud" so to speak. [noparse]:)[/noparse]
    Since I don't know as much about the environment and the hardware, it
    takes a bit of guessing. Ok, here's another idea, mount the sensors at
    different altitudes? Right side low, center high left low? Maybe
    supplement the obstical detection with some IR reflection sensors? This
    would allow you to ping the sonar, then check the IR for bounce, then
    ping the next sonar and then poll the next IR device. Maybe this would
    give the echos time to die or drop below a threshold of detection.
    Ok... I think I'm out of ideas... [noparse]:)[/noparse]
    Vern
    Vern Graner CNE/CNA/SSE | "If the network is down, then you're
    Senior Systems Engineer | obviously incompetent so why are we
    Texas Information Services | paying you? Of course, if the network
    vern@t... www.txis.com | is up, then we obviously don't need
    Cell 507-7851 Desk 328-8947 | you, so why are we paying you?" VLG
    > ds
    >> 150 seconds apart may be far to close together for the environment
    >> (hallway is an echo chamber) and the speed (slow) which a robot would
    >> normally want to navigate in a hallway presumably with human
    >> pedestrian traffic. You could get by with fewer pings with built in
    >> pauses in your code after each ping command. If you can't control the
    >> ping rate, would it be feasible to turn the sonar on and off to
    >> accomplish this? Ask the manufacturer if there is a resistor or cap
    >> you can place somewhere to reduce the ping rate(simple hardware fix
    >> unless its super miniaturized). Could you desensitize your "ears"
    >>From: Doug Simpson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XQAISzxka4O9GYlSxZA9ZPEWZr_-gJwwWGkO-a-REl5lQvH2OyE16LOyTg9e8FaLOsjAdPXsFLO9lQ]veewee77@a...[/url
    >>Hi all!
    >> avoidance.
    >> sequentially about 150ms apart and from what I can tell, the sonars
    >> are picking up the echoes from each other and getting false
    >> triggering. This makes the bot erratic when traversing the halls.
    >>Example:
    >>scenario 1
    >> left sonar that was echoing down the hall so it thinks there is an
    >> obstacle in close range. Bot puts on the brakes. . .
    >>scenario 2
    >> center echoing back from down the hall and it thinks there is a wall
    >> or
    >> right.
    >>Thanks
    >>Doug Simpson
    >>Code follows. . .
    >> avoidance.
    >>start:
    >>output ena
    >>output pingl
    >>output pingc
    >>output pingr
    >>output serv
    >>input retl
    >>input retc
    >>input retr
    >>input ir
    >>tping:
    >>pause 5 'wait a tad
    >>timel = timel*2
    >>pause 50
    >>timec = timec*2
    >> (approximate)
    >>pause 50
    >>pulsout 0,1500
    >>rctime retr,0,timer
    >>timer = timer*2
    >>low pingr
    >>display:
    >> jump to label sonar
    >> jump to label free
    >>sonar:
    >>pause 2000
    >> NOT CHANGE
    >>free:
    >> veer right
    >> veer left
    >> inanimate object
    >>high pingc
    >>pulsout 0,1500
    >>rctime retc,0,stimc
    >>stimc = stimc*2
    >>low pingc
    >>high ena
    >>pause 200
    >>next 'DO NOT CHANGE
    >>pause 5
    >>high pingc
    >>pulsout 0,1500
    >>rctime retc,0,stimr
    >>stimr = stimr*2
    >>low pingc
    >>high ena
    >>pause 150
    >>next 'DO NOT CHANGE
    >>pause 5
    >>high pingc
    >>pulsout 0,1500
    >>rctime retc,0,stiml
    >>stiml = stiml*2
    >>low pingc
    >>high ena
    >>pause 150
    >>next 'DO NOT CHANGE
    >> rotate right
    >> rotate left
    >>rotr:
    >>goto rotf
    >>rotl:
    >>pause rot
    >>goto rotf
    >>rotf:
    >>return
    >>high 1:high 4
    >>high 1:low 4
    >>'debug " veerr ",cr
    >>goto tping
    >>'debug " veerl ",cr
    >>low 1:high 4
    >>goto tping
    >> and Body of the message will be ignored.
    edited 2003-07-19 23:43
    Thanks for the input. The sonars I'm using are salvaged from Polaroid
    Sun 660 cameras. I don't know how to shift the frequency or that would
    be the easiest option. Each pings at a different frequency and then
    there would be no interference. But I don't think it is changeable easily.
    DS
    >Vern
    >>ds
    >>>From: Doug Simpson [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HNPU4CMdS2TLQ7oNeNxdqtabdcoEUcpSmC3EiC5Zec8_R7CgDZ9faTcBHcQWE_jTrNrkg-jmJ3qn7dDFb08]veewee77@a...[/url
    >>>Hi all!
    >>>avoidance.
    >>>Example:
    >>>scenario 1
    >>>scenario 2
    >>>or
    >>>right.
    >>>Thanks
    >>>Doug Simpson
    >>>Code follows. . .
    >>>avoidance.
    >>>start:
    >>>output ena
    >>>output pingl
    >>>output pingc
    >>>output pingr
    >>>output serv
    >>>input retl
    >>>input retc
    >>>input retr
    >>>input ir
    >>>tping:
    >>>pause 5 'wait a tad
    >>>timel = timel*2
    >>>pause 50
    >>>timec = timec*2
    >>>(approximate)
    >>>pause 50
    >>>pulsout 0,1500
    >>>rctime retr,0,timer
    >>>timer = timer*2
    >>>low pingr
    >>>display:
    >>>jump to label sonar
    >>>jump to label free
    >>>sonar:
    >>>pause 2000
    >>>NOT CHANGE
    >>>free:
    >>>veer right
    >>>veer left
    >>>inanimate object
    >>>high pingc
    >>>pulsout 0,1500
    >>>rctime retc,0,stimc
    >>>stimc = stimc*2
    >>>low pingc
    >>>high ena
    >>>pause 200
    >>>next 'DO NOT CHANGE
    >>>pause 5
    >>>high pingc
    >>>pulsout 0,1500
    >>>rctime retc,0,stimr
    >>>stimr = stimr*2
    >>>low pingc
    >>>high ena
    >>>pause 150
    >>>next 'DO NOT CHANGE
    >>>pause 5
    >>>high pingc
    >>>pulsout 0,1500
    >>>rctime retc,0,stiml
    >>>stiml = stiml*2
    >>>low pingc
    >>>high ena
    >>>pause 150
    >>>next 'DO NOT CHANGE
    >>>rotate right
    >>>rotate left
    >>>rotr:
    >>>goto rotf
    >>>rotl:
    >>>pause rot
    >>>goto rotf
    >>>rotf:
    >>>return
    >>>high 1:high 4
    >>>high 1:low 4
    >>>'debug " veerr ",cr
    >>>goto tping
    >>>'debug " veerl ",cr
    >>>low 1:high 4
    >>>goto tping
    Hi:
    Has anyone raised the subject of beam pattern?
    This could be a big factor - from an old Polaroid handbook, I see a 30 deg
    (inclusive) front central lobe then 2 pairs of side lobes covering beyond
    100 deg. If the receiver gain can be reduced, perhaps the effect of those
    wide side lobes could be eliminated.
    David Lawrence
    www.rhombus-tek.com/microgui.html
    Sent: Saturday, July 19, 2003 3:43 PM
    Subject: Re: [noparse][[/noparse]basicstamps] a little assistance
    easily.
