Vb (pulling out hair)
I am now using my vb program with a stamp in my visual basic interface it
works I wrote the code from scratch however not correctly here is whats going on
when look at my total text box and say to total value will be 800 then as I
increment my pot up it will go to number 7 and then reset but after 7 more it
double my value will be reached at 800 but it goes up and down it is not stable
what have I done. every seven bits it resets and starts over but is still
incrementing.
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
incrementing.
Do you Yahoo!?
It sounds like the problem is there.
On the other hand, what is this 'pot'?
I guess I need more information about what
you are doing to be helpful. What's on the
BS2 side? (sounds like a potentiometer).
What do you want on the VB side? (Timer
driven sample? Wait for serial input which
comes from the BS2?) How often does the
BS2 send values, and what event tells it
to send values? (Every time it reads a
value? It has a 'pause' before it reads
the next value?)
Also, more '.' and ',' characters in your
post, properly placed, would make it easier
to read. Also, less use of 'it' and more
use of 'BS2', 'PC', 'VB program', 'Display value'.
This will help in determining what is going
on, and what needs fixing.
--- In basicstamps@yahoogroups.com, frog28043 <frog28043@y...> wrote:
> FROM: Frog again
interface it works I wrote the code from scratch however not
correctly here is whats going on when look at my total text box and
say to total value will be 800 then as I increment my pot up it will
go to number 7 and then reset but after 7 more it double my value
will be reached at 800 but it goes up and down it is not stable what
incrementing.
> Do you Yahoo!?
