2nd Line LCD Display
Hi Everyone: About an hour after I sent the request for help on this problem, I
figured it out!
To address and write to the 2nd line of a parallel LCD using Hitachi HD44780
Controller, you need to do go into LCD Command Mode, send a "control" character
of $C0, the next LCD Write command will send
the character to the first character space on the 2nd line of the LCD. To see
exactly how I did it, check out the latest program in the files section called
"SHT1xLCDwoutHtr.bs2". Of course I had a lot of help from the programs of Jon
Williams and stamptech@p..., which I suspect is also Jon Williams.
Kindest regards, Chuck Irwin
figured it out!
