Dot Matrix Displays
I've picked up a few of those LED dot matrix displays... a few 8x8 and a few
5x7. I know the Max7219 can handle up to a 8x8 display but there is a problem,
I have an 8x8 dot matrix display BUT it is actually a 16x8 display because for
each dot there is a red and a green LED. I'm unsure how I could interface this
into a stamp. That's even to many I/O lines for anything but the BS2P40 to
handle and of course I don't want to dedicate an expensive BS2P40 to
multiplexing a 8x8 (16x8) Dot Matrix LED Display. Is there a chip out there
that can do this or is there another multiplexing technique that I'm not aware
of that I could use to achieve this? I would also like to, once I get the stamp
able to control one display, be able to control multiple displays side by side
to essential make one big display. I've also ran accross displays that do 8x8
with blue, green and red on each dot so that would make the wiring something
like 24x8 and I'd like the explore the possibilities of interfacing these too.
I know I could go get a nice Beta Bright/Alpha LED sign and use the code samples
that were posted to interface to it, but that takes some of the fun out of the
idea.
Any suggestions?
Chris Shuster
idea.
Any suggestions?
Chris Shuster
light the Red versus Green LED's.
What's the part number of your display?
Do you have a link to a PDF document?
Brute force, you can use multiple
74HCT595 Parallel Out chips to drive the
beast -- but there's probably a more elegant
solution.
--- In basicstamps@yahoogroups.com, "Chris Shuster" <cpuman3@h...>
and a few 5x7. I know the Max7219 can handle up to a 8x8 display but
there is a problem, I have an 8x8 dot matrix display BUT it is
actually a 16x8 display because for each dot there is a red and a
green LED. I'm unsure how I could interface this into a stamp.
That's even to many I/O lines for anything but the BS2P40 to handle
out there that can do this or is there another multiplexing technique
that I'm not aware of that I could use to achieve this? I would also
like to, once I get the stamp able to control one display, be able to
control multiple displays side by side to essential make one big
display. I've also ran accross displays that do 8x8 with blue, green
and red on each dot so that would make the wiring something like 24x8
code samples that were posted to interface to it, but that takes some
of the fun out of the idea.
> Any suggestions?
> Chris Shuster
follows one row of 8 controls the colom/row selection (depending on which
way the display is orientated) then 8 pins control the red part of the LED
dots for that colom/row and then 8 control the green for that colom/row. I
don't know the part # or have a data sheet off hand, I'll see if I can find
one later.
Chris
Sent: Wednesday, July 16, 2003 7:31 AM
Subject: [noparse][[/noparse]basicstamps] Re: Dot Matrix Displays
> Depends on the pin-out, and how they
> solution.
> > Any suggestions?
> > Chris Shuster
TB62713N with single color 5x7 displays with great success and I believe
they have a bicolor driver chip too but I'm not sure. Maybe they could be
multiplexed if they don't have a bicolor driver?
Very easy to interface with, take 2-3 stamp lines (depending on what all you
want to do). I think they still offer free samples.
I used it to display current gear # in my WRX.
http://www.digitalimpreza.com/
Rob
To: "Stamp Mailing List" <basicstamps@yahoogroups.com>
Sent: Wednesday, July 16, 2003 3:03 AM
Subject: [noparse][[/noparse]basicstamps] Dot Matrix Displays
few 5x7. I know the Max7219 can handle up to a 8x8 display but there is a
problem, I have an 8x8 dot matrix display BUT it is actually a 16x8 display
because for each dot there is a red and a green LED. I'm unsure how I could
interface this into a stamp. That's even to many I/O lines for anything but
the BS2P40 to handle and of course I don't want to dedicate an expensive
BS2P40 to multiplexing a 8x8 (16x8) Dot Matrix LED Display. Is there a chip
out there that can do this or is there another multiplexing technique that
I'm not aware of that I could use to achieve this? I would also like to,
once I get the stamp able to control one display, be able to control
multiple displays side by side to essential make one big display. I've also
ran accross displays that do 8x8 with blue, green and red on each dot so
that would make the wiring something like 24x8 and I'd like the explore the
samples that were posted to interface to it, but that takes some of the fun
out of the idea.
> Any suggestions?
> Chris Shuster
