--- In basicstamps@yahoogroups.com, "FalconWireless Tech Support -
KF4HAZ" <techsupport@f...> wrote:
> I need to be able to take 1.5% of a 16bit variable but X*.015 does
not work
yikes !
I deal with instruments that have 1.5% error in some cases.
that would make trying to measure 1.5% of the sensor output
(variable) equal to the expected reading. or, 100% error.
Someone check me on this, as it definitely depends upon the value of X.
In general, however, you want to multiply X by 15 and then divide by
1000, unless that would make 15 X too big. Then you might try to divide
by 1000 and then multiply by 15. I think you get the idea. Decimals are
not available.
On Tuesday, July 15, 2003, at 11:57 AM, FalconWireless Tech Support -
KF4HAZ wrote:
> I need to be able to take 1.5% of a 16bit variable but X*.015 does not
> work
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
> not available.
>> work
Y = X ** 983 ' to 1% of X
debug dec y,cr
or,
Y = X ** 9831 ' to 0.1%
debug dec y/10,".",dec1 y,cr
Y = X ** 49152 ' to 0.02%
debug dec y/50,".",dec2 y//50*2,cr
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
not work
yikes !
Dave
not available.
> work
> not available.
>> work
