4 servo control - smooth
I've searched the archives with no luck. I am attempting to control
4 servos at once to move simultaneously and smoothly - not at full
speed, but through full range. Yes, 4 DC gear motors with encoders
using PWM would probably be the best way to do this, but I've
already got the servos.
They have to be positionally accurate in their start and stop
points and start offset from each other. As in; 1 goes for 1/4 turn
then 2 starts and then 3 starts later, then 4, then they reverse the
sequence after 4 reaches its final position.
So I've got a counter variable for each servo that starts and steps
upward toward its finish pulseout frequency. I've always fed the
servos signals using a pulsout within a 'for' loop for X times with
a Xms pause within to make sure the signal is read by the servo. If
you shorten this - loops less than 10 times and pause less than 5ms,
the servos freak out. Is there a better way to do this?
But as is, it works but the stamp fires all 4 servos sequentially,
making them servo's staccato as the steps have to be large to make
them all go fast enough - maybe a BS2p would solve that.
Any good solution to using a BS2 and 4 high torque analog servos?
without depending on the Stamp. So your Stamp program sets it and
forgets it (until you want to change, of course). Have a look at
http://www.al-williams.com/pak8.htm and
http://www.al-williams.com/servobot.htm -- might give you some ideas.
It may be possible to do what you want with the Stamp directly, but I
don't know that we have enough info. Do you have a code snippet of what
you are trying to do? That might spur some discussions.
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
P.S. We are getting the edge of the hurricane here in Houston, so we are
having a "slow" day.
> From: damonhamm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8EnJ-MkJ_xqv7SvJ9FxUsDFulW9GypX3WFIr3SqvFfBuVIZHEmMauD7CuCKv7r5gWboi_9clTj5PNoUa]damonhamm@y...[/url
> Sent: Tuesday, July 15, 2003 1:38 AM
> Subject: [noparse][[/noparse]basicstamps] 4 servo control - smooth
> from the same email address that you subscribed. Text in the
> I wonder if you've looked at a PAK-VIII?
Looks like that might smooth out the stacatto motion a bit as the
PAK-VIII could offload the pulseout loops and run faster (see below)
but I don't know that we have enough info. Do you have a code
snippet of what you are trying to do?
I need to have 4 servos move slowly, so they are sequentially told
to go to different positions...
Here's some pseudocode to give you the idea:
increment Servo1 position
IF (Servo1 is at X position) AND THEN increment Servo2 position
IF (Servo2 is at X position) AND THEN increment Servo3 position
IF (Servo3 is at X position) AND THEN increment Servo4 position
... and to increment the servos, I send them position pulses,
however servos react slowly, so the signal needs to be sent
repeatedly. Is there a better way of doing this?
for y = 1 to signaltime
pulsout servo2, servo2Pos
pause signalpause
next
the for cannot be less than 10 loops and the pause cannot be less
than 7ms or the servos go nuts.
(the servos have a resolution of ~50ms)
so it operates extremely slowly and smoothly (fine position
increments) or fast and jumpy (big position increments) as there is
lag as the Stamp tells each one where to go sequentially.
I need a bit faster but also smooth... Thanks!
-D
moving one, then going to another, do them all at once. Not much delay
between signals for any of the motors.
Sent: Tuesday, July 15, 2003 10:07 PM
Subject: [noparse][[/noparse]basicstamps] Re: 4 servo control - smooth
> pause signalpause
> next
> -D
