Vb and stamp Rc time
Hi group:
I am building a shiting simulator for a driving school for 18 wheelers I
have got the whole thing working except the analog input I need to monitor 2
analog inputs one for tac and the other clutch to make sure they hit the
friction point each time and to make sure the rpm is not to high or low I am
thinking about using rc time in my code and please bear with me I have a dumb
question if I put this in a loop in the bs2 how can I get the processor to loop
at other loops conditional branch or if then but I need both loops to run
together I realize this processor is not multitasking but this project does not
really need high speed just 2 loops running together any Ideas and thanks for
all your help.Happy stamping. jimmy
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
Do you Yahoo!?
Sure hope you mean "shifting" (sorry).
I would think you could use RCTime and just read both inputs, do your
processing, and go again, right? So:
Loop:
do RC #1
do RC #2
do computations
goto loop
I'm not sure if that's the gist of your question or not.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: frog28043 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_Nc8vfl_-Ai--RdXc1CT9UZNAvK9OnNG57dA_x_3083BYZGSX60leVxF1VhvmVXkXzhYLCL1cVbo]frog28043@y...[/url
> Sent: Monday, July 14, 2003 9:14 AM
> Subject: [noparse][[/noparse]basicstamps] Vb and stamp Rc time
> Hi group:
> From: Jimmy
> for 18 wheelers I have got the whole thing working except the
> analog input I need to monitor 2 analog inputs one for tac
> and the other clutch to make sure they hit the friction point
> me I have a dumb question if I put this in a loop in the bs2
> how can I get the processor to loop at other loops
> this project does not really need high speed just 2 loops
> running together any Ideas and thanks for all your help.Happy
> stamping. jimmy
> Do you Yahoo!?
> from the same email address that you subscribed. Text in the
Al Williams <alw@a...> wrote:Hi Jimmy,
Loop:
do RC #1
do RC #2
do computations
goto loop
Al Williams
AWC
> From: frog28043 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cLaUPX5gNoSdlpH23YXjyTdCZPeAN-P7ihbPIBmPrvGM3ziM3dTb9WLTUXdjwMedpj5746NJZj73l2xk_dY]frog28043@y...[/url
> Hi group:
> From: Jimmy
> stamping. jimmy
> Do you Yahoo!?
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
Main:
Do_Important_Stuff
ON task GOSUB Get_RC1, Get_RC2, Do_Another_Task
Update task pointer
GOTO Main
This structure let's you handle important stuff and divide *background*
items into managable chunks -- a different chunk will run through each
iteration of the loop. This
And -- at the risk of sounding persnickety [noparse][[/noparse]I can't believe I'm actually
using that word] -- LOOP is now a PBASIC keyword (when using PBASIC 2.5
syntax) and should not be used as a label.
-- Jon Williams
-- Parallax
Sent: Monday, July 14, 2003 9:23 AM
Subject: RE: [noparse][[/noparse]basicstamps] Vb and stamp Rc time
Hi Jimmy,
Loop:
do RC #1
do RC #2
do computations
goto loop
Al Williams
AWC
> From: frog28043 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8m9HN9CrVpwf_BzLxht18mF3SX0uSI6UYe5EpoeylWgab1pm2Uf48psFX4tj0w1YO03zTmskzJkCbWDs]frog28043@y...[/url
> Hi group:
> From: Jimmy
> wheelers I have got the whole thing working except the analog input I
> need to monitor 2 analog inputs one for tac and the other clutch to
> make sure they hit the friction point each time and to make sure the
> rpm is not to high or low I am thinking about using rc time in my code
> and please bear with me I have a dumb question if I put this in a loop
> in the bs2 how can I get the processor to loop at other loops
> stamping. jimmy
> Do you Yahoo!?
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Larry Gaminde
Sent: July 14, 2003 7:22 AM
> Hi Jimmy,
> Loop:
> do RC #1
> do RC #2
> do computations
> goto loop
> Al Williams
> AWC
> > From: frog28043 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Cl9re_HyAs7w8XXoEPOIvr_Lr2PYWjYv1wQWdXEy6C4Y6rz0D1C6cJ-e73e4ry9JpbiQs1evW1cRN57Lsw]frog28043@y...[/url
> > Hi group:
> > From: Jimmy
> > stamping. jimmy
> > Do you Yahoo!?
This uses 'TaskID' and the 'BRANCH' statement
to do three 'tasks', then wait 100 mS and do
them all again.
This code can be condensed a little,
(The TaskID cycle can be simplified
using the 'mod' operator) but this
is a general expression.
TaskID VAR BYTE
MaxTask CON 3
TaskID = MaxTask
MAIN:
Do_Important_Stuff
TaskID = TaskID + 1
IF TaskID >= MaxTask THEN Skip1
' ELSE
TaskID = 0
Skip1:
BRANCH TaskID, [noparse][[/noparse]DoTask1, DoTask2, DoTask3]
' DoTask1 'GOTO' when TaskID == 0
MainContinue:
IF TaskID = (MaxTask-1) THEN Main ' do three rapidly
PAUSE 100 ' THEN pause...
GOTO MAIN
' Tasks...
DoTask1:
Do_Stuff
GOTO MainContinue
DoTask2:
Do_OtherStuff
GOTO MainContinue
DoTask3:
Do_YetOtherStuff
GOTO MainContinue
END
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Let me expand on Al's psuedo-code:
> Main:
> Do_Important_Stuff
> Update task pointer
> GOTO Main
*background*
each
actually
2.5
> -- Jon Williams
> -- Parallax
> From: Al Williams
> Hi Jimmy,
your
> Loop:
> do RC #1
> do RC #2
> do computations
> goto loop
> Al Williams
> AWC
> > From: frog28043 [noparse][[/noparse]mailto:frog28043@y...]
> > Hi group:
> > From: Jimmy
input I
to
the
code
loop
> > stamping. jimmy
> > Do you Yahoo!?
Subject
> abuse@p...
I don't have to direct my tasks back to another label -- the return is
handled by the GOSUB. And, by structuring tasks as subroutines, they
can be called from any point in the program; even from each other if the
situation warrants.
MaxTask CON 3
taskID VAR Byte
Main:
Do_Important_Stuff
ON taskID GOSUB Task0, Task1, Task2
task = task + 1 // MaxTask ' point to next task;
auto wrap to zero
GOTO Main
Task0:
Do_Task_Stuff
RETURN
Task1:
Do_Task_Stuff
RETURN
Task2:
Do_Task_Stuff
RETURN
This is a fairly simple structure. If we move the taskID update to the
task code, the program can be much more dynamic in it's operation --
this is particularly useful in robotics.
MaxTask CON 3
taskID VAR Byte
Main:
Do_Important_Stuff
GOTO Main
Task0:
Do_Task_Stuff
IF (some_condition) THEN
taskID = new_task ' run conditional next
task
ELSE
task = task + 1 // MaxTask ' run *normal* next task
ENDIF
RETURN
Task1:
Do_Task_Stuff
taskID = new_task
ELSE
ENDIF
RETURN
Task2:
Do_Task_Stuff
taskID = new_task
ELSE
ENDIF
RETURN
-- Jon Williams
-- Parallax
From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yA-QukNZhUMdjeRiElrp3Z7ZjOebR2_DVMi5yPKtfZ0M4McG_EuxbnYz75n4AQ4N26i2ogIcOn9ghNK_ivekmxyO]allan.lane@h...[/url
Sent: Monday, July 14, 2003 10:34 AM
Subject: [noparse][[/noparse]basicstamps] Re: Vb and stamp Rc time
And to expand a little more:
them all again.
TaskID VAR BYTE
MaxTask CON 3
TaskID = MaxTask
MAIN:
Do_Important_Stuff
TaskID = TaskID + 1
' ELSE
TaskID = 0
Skip1:
MainContinue:
GOTO MAIN
' Tasks...
DoTask1:
Do_Stuff
GOTO MainContinue
DoTask2:
Do_OtherStuff
GOTO MainContinue
DoTask3:
Do_YetOtherStuff
GOTO MainContinue
END
> Main:
> Do_Important_Stuff
> Update task pointer
> GOTO Main
*background*
each
actually
2.5
> -- Jon Williams
> -- Parallax
> From: Al Williams
> Hi Jimmy,
your
> Loop:
> do RC #1
> do RC #2
> do computations
> goto loop
> Al Williams
> AWC
> > Hi group:
> > From: Jimmy
input I
to
the
code
loop
> > conditional branch or if then but I need both loops to run together
> > not really need high speed just 2 loops running together any Ideas
> > and thanks for all your help.Happy stamping. jimmy
> > Do you Yahoo!?
Subject
> abuse@p...
abuse@p....
that he wants to do two separate quasi-tasks. Not sure though.
it be release and not beta?
Al Williams
AWC
* NEW: PAK-VIa - Read PS/2 keyboards or mice -- double the buffer, lower
current consumption.
http://www.al-williams.com/awce/pak6.htm
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=J_ZLs3GKmexjFAv7vVnLIxXenmzwBa1QcDHpxUDnUgXTOJ5weno34a_WJaGQNsRt4npjcHbn951q8W-vqw]jwilliams@p...[/url
> Sent: Monday, July 14, 2003 9:56 AM
> Main:
> Do_Important_Stuff
> Update task pointer
> GOTO Main
> *background* items into managable chunks -- a different chunk
> will run through each iteration of the loop. This
> I'm actually using that word] -- LOOP is now a PBASIC keyword
> -- Jon Williams
> -- Parallax
> From: Al Williams
> Hi Jimmy,
> do your processing, and go again, right? So:
> Loop:
> do RC #1
> do RC #2
> do computations
> goto loop
> Al Williams
> AWC
> > From: frog28043 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tMSKS6pNkolkN-kAQ-hN4JRDop6wQRhycmrW331gTKvgR8rpnqYo1sCDmo8WhNtjAnaniTTWKX14uaIPZnc]frog28043@y...[/url
> > Hi group:
> > From: Jimmy
> analog input I
> sure the
> in my code
> this in a loop
> together I
> does not
> > Do you Yahoo!?
> the Subject
abuse@p....
The only reason I would use the
'BRANCH' version is that it is 'native'
2.0 PBasic. Once the 2.5 PBasic becomes an
'alpha' version, I'll use it. Even then,
there's a lot of 2.0 code out there.
And your point about changing/incrementing
the 'TaskID' state variable inside the Tasks
does give you lots of flexibility with
how often tasks repeat, or what task runs
next. I would use it sparingly, though,
or you'll have the 'spagetti' factor --
it becomes hard to know what SHOULD
execute next -- which becomes hard to debug.
wrote:
> I personally favor ON task GOSUB over BRANCH these days because it
means
is
they
if the
> situation warrants.
> MaxTask CON 3
> taskID VAR Byte
> Main:
> Do_Important_Stuff
> auto wrap to zero
> GOTO Main
> Task0:
> Do_Task_Stuff
> RETURN
> Task1:
> Do_Task_Stuff
> RETURN
> Task2:
> Do_Task_Stuff
> RETURN
the
> MaxTask CON 3
> taskID VAR Byte
> Main:
> Do_Important_Stuff
> GOTO Main
> Task0:
> Do_Task_Stuff
> task
> ELSE
task
> ENDIF
> RETURN
> Task1:
> Do_Task_Stuff
> taskID = new_task
> ELSE
> ENDIF
> RETURN
> Task2:
> Do_Task_Stuff
> taskID = new_task
> ELSE
> ENDIF
> RETURN
> -- Jon Williams
> -- Parallax
> From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
> them all again.
> TaskID VAR BYTE
> MaxTask CON 3
> TaskID = MaxTask
> MAIN:
> Do_Important_Stuff
> TaskID = TaskID + 1
> ' ELSE
> TaskID = 0
> Skip1:
> MainContinue:
> GOTO MAIN
> ' Tasks...
> DoTask1:
> Do_Stuff
> GOTO MainContinue
> DoTask2:
> Do_OtherStuff
> GOTO MainContinue
> DoTask3:
> Do_YetOtherStuff
> GOTO MainContinue
> END
> > Main:
> > Do_Important_Stuff
> > Update task pointer
> > GOTO Main
> *background*
> each
> actually
PBASIC
> 2.5
> > -- Jon Williams
> > -- Parallax
> > From: Al Williams
> > Hi Jimmy,
> your
> > Loop:
> > do RC #1
> > do RC #2
> > do computations
> > goto loop
> > Al Williams
> > AWC
> > > Hi group:
> > > From: Jimmy
18
> input I
> to
> the
my
> code
a
> loop
together
does
Ideas
> > > Do you Yahoo!?
> Subject
> > abuse@p...
Subject
> abuse@p...
