Slot KEY
Tracy: If you have a local machine shop use them or make a holder for your
grinder lock up the piece in your lathe on your head stock should be able to
lock it then use cross rest to cut piece will need to grind stone to size of
hole use a diamond dresser any tool house will have this part cheap you will
need to go slow. hope this helps if no luck email me back I will do it for free
just send specs and return postage. happy stamping. jimmy
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
Do you Yahoo!?
